Yoda's ICS v8|| 4.0.3 ||DE-Sense 3.6 || 3.28.401.1 RUU
Ceci est ma première ROM publique Android, j'ai déja modé sur WM phones (samsung i900 and i8000). Cette ROM est faite pour moi...
mais j'aime partagé
I will thanks to:
Turge, anryl, mwakious - for inspiration ! (Turge, please don't be angry that my thread looks similar to you
LeeDroid, coolexe, j4n87, Lothaen - For Tweaks !!
MrPaveL - For HTC_Europe 3.27.401.2 ROM
lyapota - For Beats audio mod
pwnyourace, coolexe - For camera mod
predator_395, bassini - For music mods
XxXPachaXxX - for xLoud + bravia engine + PlayStation Cert
Football, anryl - for new RUU 3.28.707.1
Base: RUU 3.28.401.1 RUU release Europe HTC Evo 3D GSM X515m (SHOOTER_U)
Android Version: 4.0.3
HTC Sense: 3.6
Kernel: Stock 3.0.16
Recommended Radio: 11.77.3504.00U_11.25.3504.06_M
Recommended Recovery: 4EXT Recovery
![[ROM/KERNEL][04 Feb]Kernelv10.9 OC/S2W/3.0.62/ ROMv8 DE-Sense 3.6/Tweaks/APM/SRS Androidyoda](https://2img.net/r/ihimizer/img528/9536/androidyoda.png)
![[ROM/KERNEL][04 Feb]Kernelv10.9 OC/S2W/3.0.62/ ROMv8 DE-Sense 3.6/Tweaks/APM/SRS 20120621103207](https://2img.net/r/ihimizer/img341/4419/20120621103207.png)
![[ROM/KERNEL][04 Feb]Kernelv10.9 OC/S2W/3.0.62/ ROMv8 DE-Sense 3.6/Tweaks/APM/SRS 20120621103216](https://2img.net/r/ihimizer/img822/3158/20120621103216.png)
![[ROM/KERNEL][04 Feb]Kernelv10.9 OC/S2W/3.0.62/ ROMv8 DE-Sense 3.6/Tweaks/APM/SRS 20120621103230](https://2img.net/r/ihimizer/img826/4775/20120621103230.png)
![[ROM/KERNEL][04 Feb]Kernelv10.9 OC/S2W/3.0.62/ ROMv8 DE-Sense 3.6/Tweaks/APM/SRS 20120621103237](https://2img.net/r/ihimizer/img59/165/20120621103237.png)
It is recommended to do a full wipe before install v6.0 !!
ROM don't wipe DATA, only dalvik-cache and system partition, but if you have problems its recommended to make data wipe on first install this ROM
fast, clean, smooth Sense 3.6 ROM
deodexed and zipaligned
rooted and busybox installed
percent battery mod
boot image with init.d support
Leedroid Full Tweaks + APM
Camera mod
Beats audio, SRS,
Full APN list
removed unnecessary (for me, i like clean ROM's) apps from HTC - Full list in second post
added and updated some apps - Full list in second post
init.d and build.prop tweaks
CPU1 go offline when no needed...
Sense 4.0 skin - thanks alper.s
adfree hosts file
gps tweak - changed NTP server to europe.pool.ntp.org
... some things that i don't remember
Spoiler :
v8.0 - 10 January
It is recommended to do a full wipe before install de-sensed version of this ROM !!
updated apps,
removed Sense lockscreen from de-sensed ROM,
added/changed moded apps from Vlads ROM ! thx
nova launcher moved to data/app, now you can uninstall it,
added Apex launcher, now you can choose between Sense/Nova/Apex,
added HTC Ebook Reader and HTC News to AROMA installer,
updated hosts file
v7.5 - 31 December
updated Yoda's kernel to v10.4,
fixed 3D not switching off after bootanimation,
added bootanimation type select in aroma (3D/Stock),
removed Apex Launcher,
added Nova Launcher,
added more AOSP like apps, - Settings and SystemUI are from Vlads AOSP like ROM !
updated apps,
reworked AROMA installer...
v7.0 - 14 December
added 2 Installation types in AROMA, Sense 3.6 and De-Sense (Apex Launcher),
updated Yoda's kernel to v10.3,
updated apps (FB, Kernel Tuner, Total Commander, YT, Gmail etc...),
updated supersu,
updated hosts file,
v6.5 - 1 December
enabled back screenshoot by power+home button,
new in settings: 3D View, Letter size - coolexe,
new in phone: recording during call - coolexe,
added 3D boot animation - thx binux-project
updated Yoda's kernel to v10.2,
updated AROMA installer,
updated apps,
updated supersu,
updated BusyBox to v1.20.2,
updated hosts file,
updated Sense 4 skin to v2.0
v6.0 - 27 September
Back to BassMod v17.xx, no problems with poor sound,
Updated OC Kernel to v4.5,
Now only one OC kernel (with GPU OC),
Added Kernel Tuner app,
Added USB OTG Helper,
Updated LeeDroid Tweaks app, no SystemUI FC anymore ,
Updated apps (google maps, market, etc...)
v5.1 - 2 August
Repaired AROMA script
Updated GMail app
Updated OC Kernels to v2.1
v5.0 - 2 August
It is recommended to do a full wipe before install v5.0 !!
New base ROM - 3.28.401.1 RUU release !
added AROMA installer !!!! oooo yea !
added OC kernel by... me
(you can select stock, with GPU OC and w/o GPU OC)
updated BASSMOD by bassini to v18.00 (xLOUD and alsa update)
updated Camera-Mod to v3 thx coolexe !!
updated apps
added friendstream - you can choice what do you want install in AROMA
few other things that i don't remember now
v4.5 - 7 July
It is recommended to do a full wipe before install v4.5 !!
New base ROM - 3.28.401.1 OTA release !
updated apps (supersu, dropbox, market etc)
some changes in init.d scripts
BASSMOD v16.10 - thx predator_395, bassini
...now waiting for kernel sources
v4.0 - 23 June
It is recommended to do a full wipe before install v4.0 !!
New base ROM - Asia WWE 3.28.707.1 release ! (yes yes, not test !)
updated apps (supersu, dropbox)
v3.5 - 20 June
It is recommended to do a full wipe before install v3.5 !!
Full tweaks + working APN !!
fixed keys backlight problem (i think so
updated apps
hosts file updated
added SRS mod
added xLoud + bravia engine + PlayStation Cert - THX XxXPachaXxX !!
apn's updated - thanks malymon !!
new camera mod - thanks coolexe !!
removed more unnecessary files from HTC/Android
removed some tweaks and add new...
v2.0 - 02 June
new base ROM RUU 3.28.401.1 test-keys
more tweaks
low keys backlight - less power consumption
updated apps
no need to install separately tweaks !! - now it's only one zip to install
hosts file updated
apn's updated - thanks anryl !
working Beats audio added (go to settings -> beats audio -> switch it on, and chose headset type ! after make settings you must perform reset) - thanks lyapota
camera mod - thanks pwnyourace
Add panoramic camera
Add HDR to camera
Enable option for disabling camera sounds (focus and shutter)
Enable ISO1250
other tweks
removed lot of unnecessary files from HTC/Android (HTC/Android Spyware and other rubbish)
v1.0 - 29 May
initial release
updated apps,
updated hosts file
v7.5 - 31 December
updated apps,
v7.0 - 14 December
updated supersu,
updated hosts file,
v6.5 - 1 December
updated apps,
updated supersu,
updated hosts file,
v6.0 - 27 September
v5.1 - 2 August
Updated GMail app
v5.0 - 2 August
updated apps
v4.5 - 7 July
v4.0 - 23 June
v3.5 - 20 June
updated apps
hosts file updated
added SRS mod
v2.0 - 02 June
more tweaks
updated apps
hosts file updated
Add HDR to camera
Enable ISO1250
other tweks
v1.0 - 29 May
initial release
ROM V8
Kernel v10.9
ROM Installation:
update your firmware (if you didn't make this earlier) to newest 11.77.3504.00U_11.25.3504.06_M (link above, rename it from PG86IMG_3.xx.xxx.x.zip to PG86IMG.zip and put it on sd)
restart Evo at least once after update firmware, wait for full system boot
copy yodas_ICS_vX.X.zip to sd,
boot to recovery, and install yodas_ICS_vX.X.zip
ROM will format dalvik-cache and system partition,
wait for boot, first boot can take few minutes
enjoy Yoda's ICS
