[ROM JB 4.1.1 / SENSE 4+]03/05/13 Nik Project X Rebirth OneX v1.7 | Stable , Fast , Battery Efficient | 3.20
Poster un nouveau sujet   Répondre au sujet
Message par 4oohz le Dim 5 Mai 2013 - 13:30
Latest Base 3.20.401.1
Fixed All Widget FC Issues
Added option to Odex rom at first boot with official permission
You wont be able to flash any themes after odexing
Odexing benifits are that it improves performance and better Ram Memory Management ( Special Thanks to tommytomatoe )
Added Lyapotas Modpack 6.6,ResManager 2.7 ,Camera Extrim Mod Optional Aroma Installer
Added Playstore 4.0.27 by default
Added Option to Install AlexMail PhotoCall Mod ( Thanks AlexMail )
Sense 5 Incoming Call Screen Added ( Thanks AlexMail , smokin901 )
More Sense 5 Themed System
Fixed All Aroma Installer Issues
More System Stabilization
Updated all Latest Apps
Updated hosts file
v1.7
Updated hosts file
v1.6
Fixed All Issues
Added Lyapota's Modpack 6.5,ResManager 2.7 ,Camera Extrim Mod Optional Aroma Installer
Added Playstore 4.0.26 by default
Added Option to Install AlexMail's PhotoCall Mod ( Thanks AlexMail )
Updated hosts file[/B]
v1.5
Fixed All Icon Issues
Added Lyapota's Modpack 6.1 , ResManager 2.6 ,Camera Extrim Mod Optional Aroma Installer
Added Option to Install Playstore 4.0.25 White-Dark
( Thanks to matt95 , Daniel )
Added Option to Install Sense 5 keyboard
( Thanks smokin901 )
Added ALL Htc Sense 5 Wallpapers by Default
Updated hosts file
v1.0
Based on 3.19.401.1 RUU. - Thanks dragonesdenano
Android 4.1.1 with Sense 4+.
Sense 5 AddOns.
Lyapota's Modpack 5.8 , ResManager 2.6.
Adaway with Hosts file Updated.
Multi-language (WWE).
Deodexed & Zipaligned
SuperUser, Busybox, SQLite.
sysrw & sysro binaries.
Improved RAM management.
Enhanced I/O performance.
SQLITE Vacuum on boot or at every 2 days.
Interactive AROMA Installer.
Option to remove apps (AROMA installer).
Option to install additional mods (AROMA installer).
Bloatware FREE.
Stripped Debugging info.
Special Thanks mike1986 , lyapota ,
baadnewz , jarein95 ,
lesscro , Smokin901 ,
and all the Developers involved .
Ofcourse thanks HTC , GOOGLE , XDA
Nik Project LINK
Please make a full wipe when coming from other ROMs !
Please Flash boot.img included in the rom
SOURCE XDA
4oohz
Re: [ROM JB 4.1.1 / SENSE 4+]03/05/13 Nik Project X Rebirth OneX v1.7 | Stable , Fast , Battery Efficient | 3.20
Message par 4oohz le Dim 5 Mai 2013 - 13:31
C'est une très bonne ROM, surtout la seule qui me permet de faire marcher FRIENDSTREAM. En plus de ca, elle a sa petite TOUCH que j'aime beaucoup.
Keryboard sense5, lockscreen sense5, font sense 5, wallpaper sense5 ect ...
4oohz
Message par 4oohz le Lun 6 Mai 2013 - 22:40
2 jours dessus, c'est du bonheur, batterie très très correct niveau conso, très rapide, réactive, la sense5 touch style niquel, j'adooooooooooooooorrrrrrrrrrrrrrreeeeeeeeee Very Happy
Elle marche d'enfer
4oohz
Message par HTCNico le Lun 6 Mai 2013 - 23:21
En cours de DL je vais essayer sa Very Happy
HTCNico
ROMs : InsertCoin 19.0-3
Message par Robytek le Mar 7 Mai 2013 - 23:15
Salut, je l'ai installé hier soir, et première impression : j'adore sense 5 ! ça donne une seconde jeunesse à mon HTC one X ! et le clavier et trop bien aussi ( ça me fait penser à un iphone niveau précision des touches pour taper les sms etc..)
Dans l'ensemble cette Rom est cool pour l'instant.
Robytek
ROMs : android 2.3.3 GRI40
: : nokia 5800 (bloqué sfr)
Message par flo59650 le Mer 8 Mai 2013 - 23:12
quand je clic qur le lien pour la dl il m'affiche un message d'erreur
*est ce normal ?
flo59650
Appareil principal : SAMSUNG Galaxy S3 - 4G
ROMs : stock rom 4.3
Message par 4oohz le Jeu 9 Mai 2013 - 8:21
Je viens d'essayer cela fonctionne très bien.
4oohz
Message par dinguy le Jeu 9 Mai 2013 - 14:08
J'ai enfin trouvé une rom qui me convient parfaitement. Bravo au développeur et :merci: pour la découverte. Wink
dinguy
ROMs : à remplir
Message par formyppc le Jeu 9 Mai 2013 - 18:48
SOURCE XDA
Comment procede-t-on ?
j'extrait le fichier boot.img et je le mets dans mon dossier fastboot puis je lance la cmde "fastboot flash boot" ?
N'y a-t-il pas de fichiers "Fastboot" spécifiques pour flasher le fichier boot.img car mon dossier c:/fastboot date un peu ... ?
ensuite pour installer la rom je dois remettre le fichier boot.img dans le fichier zip (celui qui se trouve dans le dossier fastboot) ?
et ensuite je lance le recovery pour installer le zip contenant le nouveau boot.img flashé ?
Désolé mais j'ai du mal a comprendre cette histoire de flash du boot.img ...
Merci de votre aide
formyppc
ROMs : Nik Project X Rebirth 1.7
: : Nand'Droid Z v5.0 By bich
Message par 4oohz le Jeu 9 Mai 2013 - 19:09
Je te conseille de regarder dans les TUTOS, tout y est bien expliqué concernant le boot. En meme temps je vois que tu es en ARHD 21, donc no souci. Tu extrait le boot IMG
ensuite
fastboot erase cache
fastboot flash boot boot.img
Recovery FULL WIPE
install via recovery.
Honnetement c'est une super ROM, meme niveau autonomie elle est excellente, sa "touch" sense 5 est superbe
4oohz
Message par formyppc le Jeu 9 Mai 2013 - 19:14
Merci 4oohz pour ta réponse
formyppc
Message par bao091 le Jeu 9 Mai 2013 - 19:19
En cours de DL, je vais tester ça !!
bao091
ROMs : Venom Viper X 3.6.0
Message par formyppc le Ven 10 Mai 2013 - 11:16
Bonjour à tous
Bon ben la ROM est installée depuis 24h et je dois dire que je suis agréablement surpris par ce développement qui répond parfaitement à mes attentes, avec en prime le sense 5 qui donne à mon Htc One X une nouvelle jeunesse smile
Bravo aux développeurs et un Grand Merci !
formyppc
Message par formyppc le Ven 10 Mai 2013 - 11:56
(Re)bonjour,
Savez-vous quel kernel il faut utiliser pour pouvoir faire de l' UMS avec cette ROM ?
Merci de votre assistance.
formyppc
Message par vic69 le Ven 10 Mai 2013 - 12:04
Pour être en mode disque il faut un kernel custom comme le XM qui le fait très bien.
vic69
ROMs : Skydragon v12
Message par Silv3rbl0w le Ven 10 Mai 2013 - 14:25
Salut à tous, cette ROM m'a l'air vraiment bien sympa, cependant je suis sur Cyanogenmod 10.1 avec Android 4.2.2, est-ce possible d'installer cette ROM qui a une version d'android inférieure (4.1.1) ? merci !
Silv3rbl0w
Message par formyppc le Ven 10 Mai 2013 - 15:44
Je ne suis vraiment pas doué, ou puis-je trouver le kernel XM pour pouvoir faire fonctionner mon One X en UMS
En recherchant sur le forum je suis tomber sur une page qui regroupe les kernels custom pour le One X
* [KERNELS] Repacked pour les roms SlimICS et CM9 Builds
* [KERNELS] Repacked pour InsertCoins Evolution
* [KERNELS] Repacked pour Android Revolution HD
* Ncx-kernel
* Kernel EternityProject
* Bricked-Kernel
* Franco Kernel
* Faux Kernel One-X Sense 4.0 (001 BETA - 3)
* Advanced Stock Kernel
* Kernel TripNDroid Unleashed
mais je n'ai pas trouvé le lien vers le kernel XM
[EDIT]
Sur XDA j'ai trouvé un lien dans lequel sont repris les kernels XM
>> http://forum.xda-developers.com/showthread.php?t=1654982
XM
NOTE: From XM-Kernel #227 onwards repacking is not necessary
- Kernel: v226 | Modules: Here
md5: 2EBDAC1BF7A614CBBC9C2FA56F5FBE9A
- Kernel: v210 | Modules: Here
md5: CB45BCD985896E953B87C3CE184874DD
- Kernel: v206 | Modules: Here
md5: 39A8ADB142BD32643379572A0D0A340E
- Kernel: v192 | Modules: Here
md5: 2D8B42FFDDDFDC5EC2852FB0A80B2F77
- Kernel: v106 | Modules: Here
md5: AD29D5FEFFB24F58F2B87E7039CAB5D5
Le hic c'est que je ne sais pas ce que je dois faire des Modules, j'ai cherché mais je n'ai pas trouvé un tuto qui détaille l'installation des kernels et modules
Merci de votre aide
formyppc
Message par vic69 le Ven 10 Mai 2013 - 15:58
@Silv3rbl0w oui c'est tout a fait possible Wink
@ formyppc il faut aller sur xda. Voilà le lien Very Happy
[url= http://forum.xda-developers.com/showthread.php?t=2136731] http://forum.xda-developers.com/showthread.php?t=2136731[/url]
vic69
Message par formyppc le Ven 10 Mai 2013 - 16:17
@vic69 : Merci, ok je vais regarder ton lien ce soir au calme à la maison car ça m'a l'air compliquer cette histoire de kernel custom ....
formyppc
Message par vic69 le Ven 10 Mai 2013 - 16:48
C'est vrai qu'au début c'est assez galère mais on s'y fait très très vite. Il suffit de le faire une fois et c'est bon Rolling Eyes
vic69
Message par Silv3rbl0w le Ven 10 Mai 2013 - 17:12
@vic69 d'ac merci, je n'ai aucune manip spécial à faire à pars flasher le boot.img et installer la ROM ?
Autre question : je ne comprends pas, d'après la question de formyppc, cela signifie que de base cette ROM ne permet pas d'utiliser son appareil en stockage USB de masse lorsqu'on le connecte au PC (chose que je fais très souvent pour faire le tri, mettre de la musique, des vidéos etc...) ?
Silv3rbl0w
Message par vic69 le Ven 10 Mai 2013 - 19:39
Non juste ces deux choses à faire.
Pour utiliser le stockage de masse il faut un kernel custom. C'est un kernel qui a été modifié car depuis la dernière maj de HTC le kernel stock ne le permet pas. Et dans cette rom c'est le kernel stock qui est inclus. Pour le changer tu flash le boot.img en mode fastboot du nouveau kernel ainsi que les modules (fichier zip) dans le recovery.
vic69
Message par formyppc le Dim 12 Mai 2013 - 21:42
Bonsoir
bon ben voila kernel XM (188v4) installé et mon lecteur H:\HTC STORAGE retrouvé !!!!
Encore merci pour votre asssitance
formyppc
Message par 4oohz le Lun 13 Mai 2013 - 7:34
Formypp, tu nous fera un petit retour sur la conso ect ....
avec ton kernel Very Happy
4oohz
