description[ROM 4.4 KIT-KAT] [EXPERIMENTAL] OmniROM 4.4 for GT-N7000 Empty[ROM 4.4 KIT-KAT] [EXPERIMENTAL] OmniROM 4.4 for GT-N7000
    THIS IS AN EXPERIMENTAL BUILD FOR EXPERIMENTED USERS
    Just to discover out Kitkat
Instructions d'installation
Avant de commancer, assurez-vous :
  • d'avoir sauvegarder votre dossier EFS
  • d'avoir installer un recovery custom
  • d'avoir fait un nandroid backup depuis votre recovery
  • d'avoir un kernel SAFE !
A disposition pour toute question, posez vos questions. smile
Installation de la ROM :
    First time installing OmniROM to your Galaxy Note, or coming from another ROM:
    - Read known issues and FAQs
    - Make sure you're running a proper working ClockworkMod-Recovery - WITH SELINUX SUPPORT!
    - Copy GApps and OmniROM ZIPs to your SDCard
    - Boot into Recovery
    - Flash OmniROM zip from SDCard
    - Flash GApps zip from SDCard
    - DO A DATA WIPE / FACTORY RESET (otherwise your device will be stuck at boot)
    - Reboot
    - Don't restore system data using Titanium Backup!
    - Restoring Apps + Data might cause problems and is not recommended, avoid it if possible!
    Upgrading from earlier version of OmniROM:
    - Copy the OmniROM ZIP to your SDCard
    - Flash the OmniROM zip from SDCard
    - Reboot
Note mise à jour de la ROM : Wipe data et system INUTILES. Faire un wipe cache et dalvik cache uniquement.
=> La ROM : http://nuclear.ouverta.fr/omni-4.4-20131107-n7000-HOMEMADE.zip
=> Les Slim GApps : http://www.mediafire.com/download/153zj70oez0gnd2/pa_gapps-full-4.4-20131105b-signed.zip
Images
Derniers changements
First nightly:
- Fixed rotation
- Fixed sound
- Fixed recovery
- Fixed sensors
- Fixed storage
- Fixed lots of other stuff
- Omni general enhancements
Autres infos
[quote]4.3 mini-FAQ
- Video might be problematic in some cases
description[ROM 4.4 KIT-KAT] [EXPERIMENTAL] OmniROM 4.4 for GT-N7000 EmptyRe: [ROM 4.4 KIT-KAT] [EXPERIMENTAL] OmniROM 4.4 for GT-N7000
rapide Very Happy
tu as testé?
je le passe au peigne fin, mais un truc me gêne entre les 3 omnis, de dispo
Bonjour tout le monde,
Merci pour le partage Rayman.
Par contre peux-tu faire une fiche en t'appuyant sur ce tuto Mise en page des sujets
Merci par avance
Bently a écrit:
rapide Very Happy
tu as testé?
y a 3 omni en kit kat ou 3 omni en tout?????
pour le moment je n'ai trouve que celle-la en 4.4
@mendicant : tu as vu le post sur XDA, comment veux tu que je fasse un post correct ici, il y a rien a mettre a part de faire attention a beaucoup de choses........
Bonjour Rayman,
Tu peux déjà inclure dans le post 1, la partie "Changelog", "Installation", "Téléchargement", "Source", "Les bugs connus", ....
- ben c'est pas compliqué : KitKat attend une mise à jour déjà!
- perso, même si je respecte le boulot, je ne la toucherais... wait and see
- 3 Omnis en tout, celle d'Asylum, Celle d'Herna, et celle d'Xploid (qui est une évolution de celle d'herna).
good luck, bro!
oui c'est bien ca
les roms de asylum et herna sont en 4.3 et il n'y a que celle d'xploid en 4.4
mais outre le fait qu'elle soit archi-buguee, les versions officielles ont deja droit a une MAJ
il est urgent d'attendre.....
je ne te le fais pas dire!
un truc me chiffonne, mais je n'ai pas le niveau technique pour chercher et trouver :-(
c'est juste du "feeling"...
Sa majesté a parlé c'est cool...
http://forum.xda-developers.com/showpost.php?p=47266630&postcount=9548
:merci: pour la mise en page du post 1 Rayman [ROM 4.4 KIT-KAT] [EXPERIMENTAL] OmniROM 4.4 for GT-N7000 750705
Trois tentatives infructueuses : je reviens toujours sous le kernel Safe...... J’abandonne ! Mon backup !!!!! Ouf !
installé la rom du 21 et c'est sympa
plus lourd que slimsaber , 200 Mo en +, mais bien et sans bugs
pas mal cette rom
un peu moins fluide que la slim mais sympa
restauration possible avec titanium backup sans plantage par contre desinstaller pro plante
mise a jour de la rom
tous les jours il y a une MAJ
elle est quasiment sans bugs
http://dl.omnirom.org/n7000/omni-4.4-20131123-n7000-NIGHTLY.zip
post 1 mis a jour
encore une MAJ de la rom et on peut choisir les gapps avec
http://fs1.codefi.re/herna/test/omni-4.4-20131123-n7000-HOMEMADE.zip
http://forum.xda-developers.com/showthread.php?t=2397942
Par ici pour le changelog officiel : N7000
