description[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014] Empty[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014]
Base AOSP Google.
Odexed for faster performance (only in official releases, nightlies are deodexed)
Incremental updates
OTA updates - update on the fly!
Native exFAT support (Samsung devices only)
ListView animations
Multi window
Calendar - with lunar and solar calenders
Lunar calendar in lock screen
Task switching sidebar in recent apps (the list will increase if you install supported apps)
Bulk SMS recipients
Adjustable SMS font size
SMS sending delay
Smart dialing
Speed dialing
IP dialing
Custom carrier name
Network speed in status bar (upload and download!)
Built in timer in Apollo - determine when to stop playing music
MoKee NotePad
MoKee Setup Wizard
Active Display
HALO
Adjustable navigation bar height
Unique Power Saver functions!
Custom screen off animations
** Not yet merged
PIE control
Auto hide status bar
Smart capture
Preview option in launcher (similar to the preview function in launchers found in Play Store)
Many more! Since we are constantly adding new features, see changelogs to keep updated!
Images
[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014] 2tFSpek[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014] 35Y6QnH[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014] TREm3P6[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014] 6iphQej[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014] TtUH12L[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014] IyfbYjN
Spoiler :
Autres infos
• Site web : http://www.mfunz.com
• Google Plus : https://plus.google.com/communities/...88317801966872
• Stats : http://stats.mfunz.com
• Nightly Build Statuts: http://build.mokeedev.com
• Bug Tracker : http://issues.mfunz.com
• Changelog : http://changelog.mfunz.com
• GitHub : http://github.com/MoKee
• Kernel Sources : https://github.com/MoKee/android_kernel_lge_hammerhead
• Code Review : http://review.mfunz.com
• Source
Téléchagrement
Releases officielles (une fois par semaine, odexées, plus stable : http://download.mfunz.com/?device=ha...d&type=release
Mises à jour incrémentales - Instructions :
1. Déterminez votre numéro de version en allant dans Paramètres > A propos (exemple MK43.0-i9100g-130904-RELEASE)
2. Téléchargez le zip approprié (exemple : si vous êtes sur la MK43.0-i9100g-130904-RELEASE et la plus récente est MK43.0-i9100g-130908-RELEASE alors téléchargez le OTA-MK43.0-i9100g-130904-130908-RELEASE.zip)
3. Flashez dans la recovery comme d'habitude
• Mises à jour incrémentales - Téléchargement pour Realeses officielles : http://download.mfunz.com/ota.php?de...d&type=release
Nightlies (mises à jour quotidiennes, fonctions en-cours de développement, bugs possibles, déodexées) : http://download.mfunz.com/?device=ha...d&type=nightly
• Mises à jour incrémentales - Nightlies : http://download.mfunz.com/ota.php?de...d&type=nightly
GApps MoKee 4.4.x : http://www.androidfilehost.com/?fid=23329332407566631
Installation
Commencez par déverrouiller le bootloader et installer un recovery custom (TWRP recommandé et à JOUR) : Déverrouiller bootloader / Recovery / Root puis sauvegardez votre partition EFS.
  1. Placez la ROM & les GApps dans le dossier /sdcard
  2. Redémarrez dans le recovery
  3. Faites un NANDROID BACKUP
  4. Faites un FULL WIPE
  5. Flashez la ROM puis les GApps
  6. Redémarrez.
Pour appliquer un thème, il faut lire ceci : http://forum.xda-developers.com/show....php?t=2577469
description[ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014] EmptyRe: [ROM 4.4.2] MoKee OpenSource Project - Officielle / Nightly [11.02.2014]
RESERVE
