description[SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Empty[SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit]
LOCUS Localisation et Navigation
Application de localisation et de navigation en ligne et hors ligne avec une grande offre de cartes (possibilité de les créer dans l'application)
* online maps (OSM, Google, Yahoo, Bing, OVI/Nokia, … more then 40 types)
* offline maps (SQLiteDB format, updated TrekBuddy TARed format)
* direct download Online -> Offline (defined area – rectangle, path, state, around points, …)
* track recorder (GPS logger)
* POI handling => import, export, categories, guiding, …
* complete support for offline Geocaching (import PocketQuery files)
* parking service
* use Google Street View, Google Navigation, c:geo, GPS Status
* support for Bluetooth GPS
* and many more…
[SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Screenshot01-180x300 [SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Screenshot02-180x300 [SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Screenshot03-180x300 [SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Screenshot04-180x300 [SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Screenshot05-180x300 [SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Screenshot08-180x300
* 1.3.0 - 31.3.2011
- added French translation
- added Greek translation
- (PRO) charts for tracks
- improved quick POI adding from right panel
- new GPS screen
- improved search dialog
- many new settings
Download map along defined track doesn't work right now... If you need this, wait for next version, it'll be fixed!
Tapez Locus sur le Market
Via QRCode :
[Comment scanner ce code?]
[SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Img.php?s=6&d=http%3A%2F%2Flocus.asamm.cz%2F%3Fdownload%3DLocus%2520Free%25200.9
Site du developpeur: http://www.asamm.cz
description[SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] Empty[Manuel] Créer des cartes pour Locus en utilisant le PC
Pour cela, j'utilise une application appelée Mobile Atlas Creator (MOBAC).
Version originale du manuel: http://forum.asamm.cz/viewtopic.php?f=21&t=4 (Anglais)
Traduction et simplification:
Il existe deux méthodes
description[SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit] EmptyRe: [SOFT] LOCUS : Application de localisation et de navigation online & offline [Gratuit]
merci pour le partage Wink
Merci à toi Wink
Interessant merci.
