[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1)
+184
Jackob 51
durion62
fashionweed
likan03
gescc
abdel75015
cyrius3
voileuxcool
RollOfTheDice
eoliens
Diouc
padpaniq
palcojazz
faillure
Sirusse
butterflystephy
tack
darknetwork
alexis.200789
shosh
TeteDeNoob
mimio37
flavietristan
HTC1559
heg428
xtb62
Yonathân
B@ron_S@medi
jifonk57
abouassia13
maillot 974
hd2stone
djspartex
nina89
wikilman
Fredoah
Seed111
looping92
Inj3ct0r
plexus
Shad77
BiV
korlochan
pascal32
devil51
mekoar
wolfen01
kreekpack
mithos07
alphaplus
Lulucz
KEROZ3N
cmpuissance3
MaTaool
pierrickf
stratdogs
Dawid64
djtunex
franck44
Rusherman
Alphomega
beybey001
Chnoup
mat6817
lolovtt
alan42
karko1988
jake42
nedim
Pilou73
Bouricko_666
simer
valeryhugo
link130
Daviduck
ZeroCooL
cyril2smc
funkysoul
HIND
valzz360
tony8877
puppetmaster
poucinette
Leptitking
proxima
+Stunty+
sobersong
pOma
steve78
darkyork
freezy973
WiLi
thephoenix972
Vynke_974
Toots
Yuen
dedelamenace
sboiiing
lben64
Sheard
ali htchd2
goze91
bullrott
fana75
evydou
shadow007
Bylkaroc1
dwaithc
TaGueli
zeta73160
benrennes
bigbangidfm
Sonee97360
Simon65
toubabou
guidonar
chrystos
rafxiphone
Saft
cedric074
zitoun
styling
yoyo312
bibis08200
bobstgely
Gegedj
Trikap
greg64
icobi
lauky
kostilus
blades
smobydick
chob
Twipeep
jujug
davidhebert
SpartanSteal117
link-40
WhiTe-WiiDoW-FR
jay991
Zack
Duma
elmika
yonni
rickou
spyoner971
fabiano
michd
Eazyy
adishats
JEZ69
snakeplisken
DiabloCorps
T0maT0
flouch
yepiyo
Amedinho
mack13
leleup
marus
croftman
bramss
le.doms
philippeb
matuvu
geebee
liroy06
Azu
1bert
croustibat
csercl
kevin69800
barjel
jeanmarce
Fabio
biotoxic937
188 participants
description[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 41 EmptyRe: [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1)
nexusHD2
Ok
je pars de l'hypothèse que tu as bien installé MAGLDR... Wink
Installation de ClockworkMod Recovery; MAGLDR_CWM_Recovery_v3.2.0.0_for_NexusHD2_135M.zip à télécharger...
Entrer dans MAGLDR 1.13 en maintenant la touche power (touche raccrocher) lors du redémarrage du téléphone, et sélectionner "USB Flasher" à l'aide des touches VOL bas et VOL HAUT pour vous déplacer. Confirmer avec la touche décrocher (appel).
◦Exécuter DAF.exe en mode administrateur (bouton droit de la souris) sur le PC pour installer ClockworkMod Recovery 3.2.0.0
Installation de la ROM Android
◦Entrer dans MAGLDR 1.13 (appuyer sur la touche "Power" (touche raccrocher) lors du redémarrage du téléphone) et sélectionner "AD Recovery" pour entrer dans ClockworkMod Recovery à l'aide des touches VOL bas et VOL HAUT pour vous déplacer. Confirmer avec la touche décrocher (appel).
◦Sélectionner Mount&storage, usb , une fentre va s'ouvrir sur le Pc ouvrir le dossier et y placer le Zip de la rom téléchargée... la copie finie bouton gauche du hd2 pour unmount , la fenêtre sur le Pc doit se fermer...
◦Sélectionner "install zip from Sdcard" puis "choose zip from sdcard"
◦Dans votre carte SD choisir NexusHD2-Gingerbread_V3.1a_NAND_(Android-2.3.5)_update.zip, yes...
A la fin de l'installation reboot et laisser la rom finir de s'installer au premier démarrage...
Lien de la Rom pour rappel: http://www.multiupload.com/JZIXSE5KBG
Lien du topic de cette Rom; http://htc-touch-hd.1fr1.net/t54779-nand-zip-237-no-sense-nexushd2-gingerbread-v32-05112011-presentation-en-francais
merci beaucoup
je n'arrive pas a telecharge ca MAGLDR_CWM_Recovery_v3.2.0.0_for_NexusHD2_135M.zip
merci beaucoup de ton aide
il est 3h et je suis en train d'avancer
en fait il fallait que j'aille sur le gestionnaire pour appareil mobile pour desactiver la connexion usb
et apres tout est rentre dans l'ordre
merci encore encore
Ya PadKoi... Wink
Nouvelle sur le forum et novice pour ne pas dire nulle en HTC manip, je me suis aventurée dans le flash d'une rom nand android sur mon HD2 en essayant de suivre le tutoriel de caramel.Tout va bien jusqu'à l'étape 2 ... [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 41 803859 Il redémarre bien mais bloque sur l'écran blanc avec le logo en vert.
Sinon si je passe en bootloader
Voilà ce qui s'affiche
PB81100 HX-BC
SPL-2.08.HSPL 8G XE
0x05
CotullaHSPL 0x30
Comment faut-il faire pour accéder au menu MAGLDR? Enfin, que dois-je faire à présent? (Hormis le piétiner avec des talons [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 41 944737 )
Merci par avance
Redémarrez votre HD2 en maintenant le bouton "ON" appuyé pour obtenir le menu MAGLDR
merci Casper de t'être penché sur mon problème mais rien ne se passe en faisant cette manip
Il c'est installé le MAGLDR?
le MAGLDR c'est le fichier DAF.exe ? parce que celui-là , impossible de l'installer, message d'erreurs.
Sinon le "ROMUpdateUtility" a fonctionné.
je sais pas si c'était ta question
Tu l'as bien installé en partant du mode bootloader et executé en tant qu'adminitrateur si tu es sous vista/seven?
oui je l'ai exécuté en tant qu'administrateur.(j'ai seven) Je l'ai fait aussi pour le truc task29 qui refusait l'install et pour lui ça a marché.
Les erreurs affichées sont les suivantes lorsque j'éxécute DAF.exe, si ça te permets de comprendre le problème..
An error has occurred
Error Description: Config load failed.
Info: .\RSPL\RSPL.cpp (725)
Error Description: CONFIG: can't open config file
Info: .\RSPL\RSPL.cpp (304)
C'est ROMUpdateUtility qu'il faut exécuter, pas le DAF
Et donc quand tu démarres
tu en vois pas sur un écran noir des lettres et chiffres mais le logo htc?
si c'est le cas du Logo c'est que Magldr n'est pas installé...
si cela ne marche pas avec ROMUpdateUtility du dossier de MAGLDR
Tu peux alors essayer de faire avec HD2toolkit. ici
A ben te voila enfin toi [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 41 978827
Tu es sauvé wacom1, super fourmi arrive [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 41 69699
ok merci je vais essayer ça parce que la ROMUpdateUtility du dossier de MAGLDR a été installée.
-----[center]
Je crois que ça va me prendre un peu de temps, je reviendrai vers vous pour les nouvelles, en tout cas merci pour votre aide,c'est sympa.
J'osais pas intervenir ...Dans la partie haute du forum... Si jamais je dis une connerie .... j'ai un peu peur de Sniper-ice ... lol!
Parceque tu crois que j'en dis pas des connerie? il etait tant que tu arrives, sinon ça aurais étais un feu d'artifice [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 41 69699 , te laisse continuer, j'ai jamais mis Android en nand sur mon HD2 [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 41 803859
pas de risques qu'il débarque dans la partie HD2/Android, il est allergique
Very Happy
c'est re-moi...
"Installation of MAGLDR Complete"....mais toujours au meme point Sad
et donc là si tu reste appuyé sur le bouton power (celui à droite), tu n'arrives pas dans le menu de MAGLDR?
par wacom1 le Mer 1 Fév - 21:06
c'est re-moi...
Edit ; grillé
C'est à dire que lorsque tu démarres en maintenant appuyé le bouton de droite tu n'arrives pas dans le menu de Magldr??
par VM54 le Mer 1 Fév - 20:59
@ Casper78
Hs on
Ton Galaxy c'est un Gt ou avec une puce d'origine?,cela me refroidit une peu cette histoire de puces changées... Obligé de regarder dans la gamme des Sensation...
Hs off
non toujours ce foutu écran blanc avec htc vert. je commence à avoir une crampe au pouce [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 41 73683
C'est que Magldr n'est toujours pas installé
Puisque tu as Hd2toolkit
Essaye dans l'ordre
De faire avec
le Wipe
d'installer la rom radio
puis de réinstaller Magldr
