description[SOFT] Perfectly Clear for Android [Payant] Empty[SOFT] Perfectly Clear for Android [Payant]
[SOFT] Perfectly Clear for Android [Payant] Unname12
Perfectly Clear est une application qui va vous permettre de nettoyer automatiquement tous vos clichés tels que les photos délavées ou encre les photos sous-exposées.
[SOFT] Perfectly Clear for Android [Payant] A12 [SOFT] Perfectly Clear for Android [Payant] B12 [SOFT] Perfectly Clear for Android [Payant] C12 [SOFT] Perfectly Clear for Android [Payant] D12 [SOFT] Perfectly Clear for Android [Payant] F11 [SOFT] Perfectly Clear for Android [Payant] H10
-Fixed: Intent issue with DropBox
-Improved stability
V. 1.05
**NEW**: PerfectlyClear can receive (and send) images via intents. eg - you can open images from gallery direct to Perfectly Clear
-Fixed: Increased size of exported images
-Fixed: Instability issues with a certain type of images
-Improved stability in Editor
description[SOFT] Perfectly Clear for Android [Payant] EmptyRe: [SOFT] Perfectly Clear for Android [Payant]
Juste, c'est gratuit? Payant? les Deux?
Payant!
Vu Wink et merci pour la balise cheers
