[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma
+20
marcopolo_22
yakko29
Bently
neokiller
elfrager
davfunk
Luzifer
enzo43162
jifonk57
phil34
klown_2
comprare2010
yamrr1
snach21
ludskyrider
bigbosshin
Gizmodu74
dave62
phil10
24 participants
description[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma Empty[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma
AOSP CM10.1 ROM
Features
+ Based on CM-10.1
+ PA's hybrid engine for a full user experience
+ Switch between three different UI modes
+ Change the system DPI
+ Add apps to different DPI groups
+ Change the navigation bar height
+ No reboot needed for UI changes
+ More features and improvements
+ This is always a work in progress
In AROMA:
3 kernels
6 DPIs
3 launchers
GPS locale
Some apps
and more...
Extra changes:
Suport for /data/local.prop (only JB ROM that supports this?, maybe )
Removed CM wallpapers, LiveWallpaper and LiveWallpapersPicker
Removed some tones
Removed videos
Removed ROMManager
Added ZipInstaller (Multi zip installer!!!)
GooManager support
Battery save tweaks
Tweaks ui/launcher/performance (compiled by jmico)
Recovery: removed some confirmation "No"
CM tablet options activated when in TabletUI
The Beer Gang presents...
[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma Note_110
+ BeerGang's github for a complete changelog
+ Per App Layout
+ Clock Mods
+ Notification Background
+ Circle Battery Tweaks
+ Wake up when device is plugged or no
+ Fixed Hiding clock and it going from top of notifications
+ CRT Off Animations
+ Notification Behaviours
+ AOKP navigation bar
+ Latest CM10.1 Merges
+ and maybe more.
Spoiler :
Lien de Téléchargement
description[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma EmptyINSTALLATION
Marche à suivre pour une installation clean sur votre Note GN7000 premier du Nom
Copy the ROM to the SD
Install the ROM
Follow the AROMA instructions taking into account that:
If you come from a CM10 ROM, do a cache wipe and dalvik cache wipe
If you come from any other ROM, do a wipe data
Reboot
En Français :
- Copier la ROM que vous avez téléchargées
- lancer l'installation de la ROM
- suivez les instructions de AROMA
- Si vous venez d'une ROM CM10, juste faire Wipes Caches et Dalvik
- Si vous venez de n'importe quelle autre ROM, Faire FullWipe (sous cette installation, ne pas le faire avant l'installe de celle-ci)
- Finir l'installation et Reboot..
Enjoy your new ROM.
DIVERS
Pour ceux que cela intéresse, vous pouvez utiliser le market Samsung c'est ICI que cela se passe. [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 978827
description[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma EmptyRe: [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma
Merci Mr !!
De rien, j'espère que je suis assez clair, pas évident!!! [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 978827
Niveau conso c'est toujours la cata ?
Niveau consommation, je dirais cela dépend de quel kernel tu installes...
ici, j'ai installé la version overclock, ba, ça consomme, comme tout kernel overclock, mais sinon, la nuit, il dort bien (deepsleep) et ne consomme quasi pas. Mais bon, tout est relatif.... [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 978827
phil10 a écrit:
Si vous venez de n'importe quelle autre ROM, Faire FullWipe (sous cette installation, ne pas le faire avant l'installe de celle-ci).
[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 123544 Bon si mon petit cerveau à compris.
-flasher la V3,
-je l'installe,
-reboot en Recovery et Full Wipe,
-Flash du Kernel et Reboot.
C'est bon ?
- EDIT:: Pour quoi, lorsque je regarde les fichiers de cette Rom V 3, il est noté V 3.1 [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 887500
tu flashe la rom et tu suis les instructions, tu verras c'est simple, pas de reboot en recovery, juste suivre...
V3.1, aaaa, nouvelle version, je vais voir.
Ba, j'ai rien vu en version 3.1????? Peut être une erreur de frappe, mais rien de grave, t'inkiète.
AVANT de FLASHER, N'OUBLIEZ PAS DE FAIRE UN BACKUP!!!!
En haut sur la 2eme image, tu vois aussi B.J V3.1. Aller, je me lance, sauvegarde faite et batterie à 100% Wink .
Spoiler :
Merci.
Merci phil10 beau boulot
C'est bien la V 3.0 ...
Merci pour les indications, mais elles sont en English. No Le Full Wipe se fait pendant l'instal, si vous le sélectionnez.
J'ai donc du louper quelque chose, car les écritures se lisent avec une loupe. C'est dommage, je n'arrive pas à faire de capture d'écran.
Si non c'est très fluide et réactif, tout fonctionne apparemment, photos, vidéo, etc ...
Un truc bien, c'est qu'il y a un fichier pour régler le CPU que j'ai mis en 1400Mhz (le meilleur rapport qualité/autonomie sur la Crash V10).
Je la garde pour le moment. Si vous avez une combine pour calibrer les caractères d'écriture, je prends Wink
@Pluche
Pour les écriture, tu dois aller dans paramètres et réglage , puis dans ROM control et dans general ui, tu regardes tout en bas et tu as le réglage DPI, normalement tu es à 240dpi, si tu mets à 320 dpi, tout rentre dans les ordres... (tu récupères des écritures normal pour les yeux qui voient pas bien) [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 978827
Je dis ça mais, j'ai installé la ROM CP7 ghost ridder, donc j'ai plus le même menu, vois plutot dans setting et tout en bas ou si y a pas general ui
J'ai fais joujou toute la journée avec cette jelly beer et c'était que du bonheur en ... buvant des bierres Mort de Rire
Je teste cette semaine en condition de "boulot" pour voir en particulier la conso
Je donnerai un feedback
juste une question, ya la radio fm ?
Non, moi je m'en sert pas.
Il n'y à pas les applis SAMSUNG, c'est de l'android pur.
J'ai vu des post ou certains on installé de applis samsung sur JB avec succès, à tester.
Moi je reste sur la cm-10-20121014-NIGHTLY-n7000, par contre j'ai installé le KERNEL jelly-beer OC, j’espère gagner un peu en autonomie....
Bonjour et merci pour vos bon conseilles.Wink
Ce matin à mon taf, impossible d'avoir une connexion wifi et la data n'est pas trop mieux sur le Note. J'ai cru que ce-la venais de la rom, que j'ai reflashé en 360 DPI et en effet les icônes et les caractères sont plus accessible pour bibi, mais toujours pas de wifi. C'est marrant, car je capte le wifi avec mon PC et pas avec le Note [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 887500
J'ai voulu restaurer ma rom CRASH v10, mais sans passer par un kernel Abyss, pas possible.
Bon ben, j'ai plus qu'à tout réinstaller.
@ Very Happy Pluche.
Tu dois pouvoir restaurer depuis un kernel Hydracore.
A condition d'avoir précisé "tar" en format.
Ce matin 75% de batterie, fin de la journée 56% avec quelques appels tel et 2 compte mail en push en permanence.
Conso très correcte et toujours pas trouvé de bug Wink
Tu peux m'expliquer un peu plus, Pat stp ? Toutes mes Màj on échoués.
Mais au Taf, j'avais pas trop le temps de bidouiller. Chez moi, avec mon wifi, c'est mieux pour installer.
pour le wifi, tu dois aller dans les option du wifi, je m'explique " tu ouvres la page wifi et ensuite tu fais "page" le bouton physique de gauche, là tu as option que tu ouvres ensuite tu décoches l'option ne pas se connecter au wifi si mauvaises connection (ou quelque chose comme ça) à partir de là, plus de blèm de connection wifi....
je n'ai pas eu ce problème, j'ai reflasher le kernel hydra et restoration normal, sans aucun problème de restoration.... [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 978827
Actuellement, je suis sous CP7 et c'est vraiment mieux que jelly beer, les icones "classes" et beaucoup de couleur, les fond d'écran, quand on change de menu, de Ghost ridder... Mieux fini que jelly, je reste sous cette rom pour l'instant... [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 978827 :geek1:
tiens PAT7 quelques images ici -->[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 2012_116[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 2012_117[ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 2012_118
@Pat
Lorsque tu veux faire un Nandroid Backup, tu redémarres en recovery
-Backup and restore
-Choose Backup format
-tar
-Go Back
-Backup
ou
-Backup to internal sdcard
Si tu choisis ce format, tu ne devrais pas avoir de problème pour restaurer ton backup
Merci BigPat, après "Backup and restore" je ne connaissais pas. [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 750705 Même la sauvegarde de dimanche de la Crash a échoué à trois reprises... J’essaierais avec la CRASH, car avec Titanium ... [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 653903
@ Phil10, mouais, mais ce n'est pas l'appellation que j'aurais donné, si c'est pour améliorer le Wifi. Option coché, voir lorsque je retournerais au travail.
Si ça me vire le Wifi de la clinique, çà ne me conviens pas, j'vais voir si je garde cette rom, car en peu de temps, elle me les à cassés menue. [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 3571724197
Bonne soirée ! Wink EDIT:
@ BigPat, Lâcheur !!!!!! [ROM 4.2.2 / AOSP][02-04-2013] JellyBeer-v4.14 [Hybrid] [BeerGang] - Intallation par Aroma 69699
