[ROM][4.1.2 JB]Ultimate N7000 XXLSZ JellyBean 4.1.2 v5.2 | ONLINE | 23/02/2013
+30
bimbim46
phil34
bigbosshin
matosman
aziane
VTR
guict
aladinfr
jeanmarce
Gizmodu74
vinc62
AKASHIK
didier13
phil10
dede425
alexnote
shinj59
philmeri
BiV
joan62
Bamlot
rayman95
phil_rouge
motus_&
neokiller
ludskyrider
vignousse
Aeolus68
yamrr1
Andlam
34 participants
description [ROM][4.1.2 JB]Ultimate N7000 XXLSZ JellyBean 4.1.2 v5.2 | ONLINE | 23/02/2013 Empty [ROM][4.1.2 JB]Ultimate N7000 XXLSZ JellyBean 4.1.2 v5.2 | ONLINE | 23/02/2013
Ultimate N7000
 [ROM][4.1.2 JB]Ultimate N7000 XXLSZ JellyBean 4.1.2 v5.2 | ONLINE | 23/02/2013 XXLSZ_N7000_1
Version 5.2 is OUT!
New XXLSZ!
OTA Updates Changelog [23/02/2013]
Costantly updated! Just click above to see.
New Changelog v5.2: [UPDATED 23/02/2013]
ROM Based on NEW XXLSZ Firmware
NEW Philz Safe Kernel 4.63 for XXLSZ with CWM 6.0.2.8 Touch and exFAT Support
NEW Modem XXLSO
Updates Over The Air – OTA UpdateMe added on Settings
Jelly Bean 4.1.2
SuperSU Added
Fully Rooted
Fully Zipaligned
Fully Deodexed
Deleted some useless apps
Added and fixed some more Build.prop tweaks for better optimization, battery life, 3G signal and network, camera, media and more…
Added some more init.d optimizations
Switched to MTP instead of Mass Storage, you can also use Mass Storage
Fixed CRT OFF and fully working on XXLSZ
Ultimate 4 Way Reboot Options for XXLSZ (just long press power button and decide what you want to do)
SystemUI Soft Themed with semi transparent notification drawer background and cyan circle battery
Fully working Lockscreen Shortcuts (thanks to eybee1970)
Notification Panel into Settings with possibility to change Toggles order
Call Recording
Multiwindow Hack is available for unlimited apps
Ink Effect Mod
Dedicated app to change INK Effect Colours (thanks to mythtrandyr)
SNote work also with productivity tools
Airview Fix Available
Airview in Gallery
Added S-Voice
Added new Android 4.2 keyboard
Added some utilities on settings
…and more to come!
Download Link v5.1:
Mirror 1 http://sourceforge.net/projects/ultimatejb/files/Ultimate_N7000_XXLSZ_JellyBean_4.1.2_v5.2/Ultimate_N7000_LSZ_JB_4.1.2_v5.2.zip/download
Mirror 2 http://d-h.st/SDB
Mirror 3 [url=galaxyrom.ph0enyx.de/Galaxyrom/JBRoms/Ultimate/Ultimate_N7000_LSZ_JB_4.1.2_v5.2.zip]içi[/url]
description [ROM][4.1.2 JB]Ultimate N7000 XXLSZ JellyBean 4.1.2 v5.2 | ONLINE | 23/02/2013 EmptyRe: [ROM][4.1.2 JB]Ultimate N7000 XXLSZ JellyBean 4.1.2 v5.2 | ONLINE | 23/02/2013
Visiblement la consommation est tres bonne (77% ce soir).
Des tas de peites choses sont agreables.
Le paiement par telephone et le partage de fichier avec telephone proches semble etre de la partie. J'ai supprime un certain nombre d'apk (Bluetooth, youtube, social hub etc...)
La radio capte mieux je dirais. Le demarrage semble plus rapide qu'avec la Chrak's.
Peu de problemes. Ici et la des chargements intempestifs de l'appareil photo ou autre. Peut etre est ce de ma faute.
Voila pour le moment.
Lami.
:merci: J'arrive juste pas à la DL...:lol
Je le met en miroir sur dropbox.
Lien : lalala
Je l'ai installée depuis dimanche et moi par contre, si tout va bien lors de l'utilisation, il arrive que le téléphone vibre grave à outre mesure lorsque je le sors de veille en appuyant sur Home ou l'alimentation!
Je sais pas pourquoi. Je suis obligé de le rebooter pour corriger le problème... :/
Bonjour dans cette rom je ne trouve pas les raccourcies appli sur l'écran de déverrouillage. merci
Apparemment elles ne sont pas disponibles à ce que j'ai lu sur XDA...
teste le lien dans ma signature, ça a marché pour d'autres xxsl7
Je reviens avec un ou deux complements.
La batterie est a 50% apres deux jours d'utilisation standard.
Ce qui me convient particulierement bien.
L'ensemble des fonctionnalites dont j'ai besoin s'y trouvent (hormis la charge rapide
qui n'existait que sur la Stunner...). Donc pour ma part je suis satisfait.
Je regarderais les autres tout de meme.
Cette Rom n'est pas la plus fluide mais cela me suffit et parfois ca s'ameliore avec le temps.
Voila.
Plus de probleme de Fc ou autres aujourd'hui.
allez on se lance dans l'installation..
Oui moi je l'aime cette Rom.
(Tu dors pas beaucoup toi) ^^
(si le matin..lol..je travaille pendant que d'autre dorment..chhuuutttt... Wink )
installation faite, elle est fluide, pour l'instant rien a dire..
j'ai 2 petite questions ! on télécharge la la v4 puis on fait les mises a jour via ota et on a la version complète ?
il y a le mode 240 DPI ?
Question complémentaire à celle de yamrr1 :
Comment fait-on les mises à jours Ota ? Je n'ai rien touver en ce sens.
Sinon, pas de airview dans la galerie pour moi. Sad
Pour Ota et galerie je ne peux repondre j'utilise Quickpick et ai desactive OTA...
Desole.
@Andlam il y a le mode 240 dpi ?
@yamrr1 : a priori oui.
Je n'avais jamais change l'affichage.
Je suis alle dans system puis build.prop et ai change le 320
en 240 sauvegarde puis sortie.
Pas de message particulier donc pour moi c'est OK.
Voila.
Dis moi si j'ai fait une mauvaise manip ou fait un test incomplet.
A quoi te sert ce mode (est ce simplement de pouvoir mettre plus de choses a l'ecran) ?
je trouve ca plus jolie et plus fin sur un ci grand ecran !la pour le moment je suis sur AllianceROM JB XXLS7 elle marche très bien , mais j'ai envie de changer !
Ah ok je vais tester alors.
C'etait bien la bonne manip ?
je peux pas te dire , je suis pas sur cette rom !! mais sur la rom Aliance via ota il y a un mode 240 dpi a téléchargé puis ca s'installe en recovery tout seul
Ah ok. Ben tiens moi au courant si tu veux bien.  [ROM][4.1.2 JB]Ultimate N7000 XXLSZ JellyBean 4.1.2 v5.2 | ONLINE | 23/02/2013 61393
Edit : la Rom m'a tenu 3j et 10 heures c'est vraiment agreable.
D'autant que je n'ai jamais recharge depuis et que je fais un 'battery calibration' a chaque fois.
cheers
En cours d'installation ! Very Happy
merci pour les infos !
De rien.
Plaisir de pouvoir apporter un petit quelque chose pour une fois.
 [ROM][4.1.2 JB]Ultimate N7000 XXLSZ JellyBean 4.1.2 v5.2 | ONLINE | 23/02/2013 61393 Wink
