[MOD HTC ONE M7] SOUNDMOD SENSE/GPE | Dragon-Fi Audio v27 ex Project ERA
Un Mod que l'on doit à ZeroInfinity Enjoy...
Le mot du Chef ; "Fatigué de la qualité sonore du HTC One? Pas assez de basses, des aigus, de la clarté? Eh bien ne souffrez plus Voici mon dernier projet de son moddé: Extreme Rezounded Audio! "
-System Wide audio (NO NEED TO TURN ANYTHING ON, IT WILL WORK ALREADY LIKE NORMAL SOUND) -Completely replaced stock android resampler with SRC (Secret Rabbit Code) (Best audio resampler out there) -New soundfx libraries from various devices -Enabled Qualcomm Surround-Sound recording -Custom compiled libasound.so library (Thanks to aznrice2k4) -Custom made asound.conf specifically for [apq8064tablasnd] soundcard -10240x48000 Oversampling (491.52MHz) -24Bit Quantization -Automatic PCM audio dump in /data/audio -Linear PCM conversion -Forced HiFi audio mode -Fully working MultiMedia1 Playback with ALSA -SRC mode set to Best -No distortions -Very powerful ALSA processing (At the cost of Battery and Performance) -Super-High Quality Audio -Greatly reduced noise via oversampling -Greatly Improved audio anti-aliasing via oversampling + quantization -Compatible with Sense 5.5 Android 4.4/GPE Android 4.4/Sense 6.0 Android 4.4.2 -Disabled LPA completely -New ADSP firmware from Nexus 5 -The Beats Experiment (Heavily Tweaks Beats Audio) (It is LOUD so turn down volume before listening to music) -Enabled HTC Hardware AEC (Automatic Gain Control) -Fine-Tuned SRS/Dolby/HTC effects -BeatsBass library re-introduced from HTC Rezound -Enabled MPQ8064 Audio Decoding (Taken from an older 4.1.2 Xperia Z firmware) -Greatly Improved Audio resolution via oversampling -Much cleaner audio
Installation
1. Télécharger le Zip et la copier sur la mémoire interne du ONE 2. démarrer et aller dans le Recovery, 3. faire un backup puis flasher le zip...
Dragon-Fi Audio v27: - Better Marshmallow Support - End support for KitKat (Android 4.4) - Atmos working for Marshmallow - Added InfinitySound v2.0 and PsychoRealism v2.0 presets - Increased audio offload buffer from 32 to 128 (still good low latency performance, better stability) - Stopped 192KHz experimental feature for M9, kept forced 24 bit output
Dragon-Fi Audio v26.1: - Fixed Dolby Atmos for APQ8064 devices
Dragon-Fi Audio v26: - Fixed Volume Leveller bug in Atmos - Added Atmos for M9 - Retuned profiles for Atmos M9 only (Different sound to previous HTCs) - Fixed Dolby Uninstallation - Added IntenseBLAST for Atmos, HTC BoomSound with Dolby and Atmos for M9 - Removed old Dolby Atmos presets, kept PsychoRealism and added new Speakers preset - Slight preset name edits in AsUi
v27 (AFH) Download
Anciens téléchargements :
v24.1 (sur MEGA) v24 (sur AFH)
Project ERA v23.1 Miroir pour la v23.1
v22 Sense/GPE/AOSP AROMA DOWNLOAD, MIRROR v22
v21 Sense/GPE/AOSP AROMA DOWNLOAD, Miroir v21
Dolby fix for AOSP ROMs, Miroir for Dolby Fix
UPDATED DOLBY CONFIG, Miroir ALT DOLBY CFG
Project ERA v20 Project ERA v20, Miroir v18.1 Sense & GPE Edition AROMA DOWNLOAD (Si vous êtes sur mobile, passez en mode bureau pour télécharger) Miroir pour la V18.1
v17.1 Sense & GPE Edition AROMA DOWNLOAD (Si vous êtes sur mobile, passez en mode bureau pour télécharger) Miroir v17.1
v17 Sense & GPE Edition AROMA DOWNLOAD (Si vous êtes sur mobile, passez en mode bureau pour télécharger) MIROIR v17
v16.3 Sense & GPE Edition AROMA - MIRROR v16.3
v15.2 Sense & GPE edition
v14.2 Sense & GPE Edition AROMA sur votre One ne pas utiliser le mode mobile de votre navigateur pour télécharger MIRROR v14.2
v13.2 Sense & GPE Edition
v12 Sense & GPE Edition AROMA DOWNLOAD BUGS: GPE Andorid 4.4: - MusicFX and any other 3rd Party DSPs will cause the whole system to go haywire and laggy (No solution for that yet...) Sense Android 4.4: - None at all
v9.0 (Sense 4.3) DOWNLOAD v9.0 Sense 4.4 KitKat Edition DOWNLOAD v9.0 AOSP KitKat Edition (GPE 4.4 KK should work too) DOWNLOAD POUR TOUS LES NOOBS ET PERSONNES PARESSEUSES DANS LE MONDE, VOICI LE LIEN POUR MUSICBOX (UNIQUEMENT POUR Sense 4.3)
Amélioration Oui aucun changement sur la base après ce son des amélioration du still ---> 48Khz ... renforcement bass diminution Aigu et plus si infinité
Salut, la version 5.0 est dispo ! Quelqu'un l'a testé ou je m'en charge ? J'ai CodeXsound en ce moment... Je me demande si il va simplement être écrasé ou si je risque des conflits de drivers/appli comme avec Noozxoide...
Ah oui, pardon... Oui j'ai mon forfait qui s'est réinitialisé hier matin... Il me reste 500mo sur 2go :X Ça craint lol J'ai surtout remarqué le volume maximum qui était un cran plus haut sur CodeXsound en restant relativement clair... Là je viens de flashé la v5.0 et je me suis rendu compte qu'il y a une très faible différence quand on switch avec le mode Beat alors qu'avec l'autre la différence était flagrante... Je sais pas trop si ça a une importance particulière sur le rendu final mais bon... Je teste :-)
