"Ce Mod pack permet d'améliorer les performances audio des roms AOSP mais il fonctionne pour toutes les roms (AOSP, Paranoid, Samsung, ...). Il est basé sur le mod "Purexaudio développé par ZeroInfinity pour les roms Sense.""
Fonctionnalités :
- System Wide audio - New Powerful custom compiled audio libraries - SoX Codec for Superior Audio quality - MP3 LAME Codec for Superior MP3 Quality - Audio Fluence mode set to Broadside - Qualcomm Fluence mode set to FluencePRO - Custom made ALSA with auto config feature - Audio Resampling from Android 4.1.x with level set to maximum of 4 - SRS Effect ENABLED (But does not load TruMedia effects so it's just a simple SRS virtualization) - Custom tuned snd_soc_msm main audio configs - Slightly louder audio - Live and Beating Drums - Super Bass (Best feature of the mod) - Surround Sound - Clear Audio+ but true !!!! - Clear Bass - Clear Stereo - New Walkman From Xperia Z - New Walkman Visualizer From Xperia Z - Noozxoide EIZO as DSP - TrackID From Xperia Z - Dynamic Normalizer - ClearPhase (Actived by default) - xLoud ported for HOX by zero (Actived by default) - auto remove DSP/MusicFX - More ..
Images et Vidéos
Installation
1) Démarrez dans le CWM Recovery en maintenant les touches "Volume +", "Power" et "Home". 2) Faîtes un NANDROID Backup avant via le Recovery. 3) Faites un "Wipe Cache Partition" et dans "Advanced" "Wipe Dalvik Cache". 4) Flashez le Mod. 5) Amusez-vous
Changelog
27 septembre 2013 - v5.2 :
- Latest Sony Walkman v7.12.A.0.0 supported AOSP 4.3 :: screen shout - Latest Sony Movies & Album 5.1.A.0.8 supported AOSP 4.3 - Digital Dolby - Audio FX Widget - Beats Audio for headphone - New Sound lib compatible with AOSP 4.3 - Support Voodoo sound for clear bass - X-Reality Engine - Audio Performance Tweaks - bulid.prop auto patch
Anciennes versions :
Spoiler :
03 septembre 2013 - v5.0 :
- Latest Sony Walkman supported AOSP 4.3 - Latest Sony Movies & Album supported AOSP 4.3 - Digital Dolby - Audio FX Widget - Beats Audio for headphone - New Sound lib compatible with AOSP 4.3 - Support Voodoo sound for clear bass - X-Reality Engine - Audio Performance Tweaks - bulid.prop auto patch
21 juin 2013 - v4.3 :
- compatible with Poweramp !!! - even when stay in the music app. when turn on the setting and then leave the player lose his settings . - System Wide audio - xLoud ported for N7100 - SoundEnhancement full working From Xperia z - Super Bass (Best feature of the mod) - Surround Sound - Clear Audio+ but true ported for N7100 - ClearPhase feel sounds improvement when open walkman - Clear Bass - Clear Stereo - New Powerful custom compiled audio libraries - SoX Codec for Superior Audio quality - MP3 LAME Codec for Superior MP3 Quality - Audio Fluence mode set to Broadside - Qualcomm Fluence mode set to FluencePRO - Custom made ALSA with auto config feature - Audio Resampling from Android 4.1.x with level set to maximum of 4 - SRS Effect ENABLED (But does not load TruMedia effects so it's just a simple SRS virtualization) - Custom tuned snd_soc_msm main audio configs - Slightly louder audio - Live and Beating Drums - New Walkman From Xperia Z - New Walkman Visualizer From Xperia Z - Noozxoide EIZO as DSP - TrackID From Xperia Z - Dynamic Normalizer - ClearPhase - auto remove DSP/MusicFX - More ..
21 juin 2013 - v4.0 :
Open Noozxoide EIZO-rewire™ PRO and configure it according to guide below.
▼ SETUP AS DEFAULT FILTER (reboot when necessary) ----------------------------------------------------------------------------------------- Settings > Sound > Music Effects > Choose “Noozxoide EIZO-rewire™ PRO Series”
▼ ADVANCED MODELING for MUSIC ----------------------------------------------------------------------------------------- TURN ON Noozxoide Balanced X-EQ™, Choose “UNIQUE III” from Digital Presets. TURN ON Noozxoide LogicSurround ES™, set your VSUR room size “Focus/Studio”.
▼ ADVANCED MODELING for MOVIE/GAME ----------------------------------------------------------------------------------------- TURN ON Noozxoide Psychoacoustic™ II, set the effect strength “Large”. TURN ON Noozxoide Balanced X-EQ™, Choose “Cinema/Game” from Digital Presets. TURN ON Noozxoide LogicSurround ES™, set your VSUR room size “Focus/LIVE I/II”.
N'oubliez pas de changer les effets de sons dans les paramètres si EQ ne fonctionne pas.
Comment activer CleaAudio+
Ouvrez l'application "Walkman" puis allez dans "Paramètres/Settings" et activer "Sound enhancement".
Je pense avoir trouvé, il faut que tu ailles dans l'application "Walkman" que tu ailles dans "Settings" et tu pourras activer l'option "Sound Enhancement".
Bonjour bonjour, Je me permets un ptit détour chez vous ! Oui exacte dans Walkman paramètres / AudioClair + surtout pas ! c'est un mod inclus Walkman... Settings > Sound > Music Effects > Choose “Noozxoide EIZO-rewire™ PRO Series” ok pour mettre par defaut ! Sur poweramp ok mais : PowerAmp > Settings > Audio > Advanced tweaks > Décochez direct volume control. Cette appli est juste une tuerie ! surtout décoché tout améliorateur de son Xpure / Beats pour les autres ! (je parle uniquement de l'appli Noozxoide EIZO-rewire™ PRO) Avec des réglage aux poiles deviens un must !!! (les réglages en HomePage sont un début...). Vraiment a tester en long large et travers sur tous périphériques chacun aura des réglages bien spécifique casque/line/HP... Testé sur ONE / ONE X / Sensation / EVO3D / GT5110... (One en ce moment).
moi je n'utilise que l'appli DEEZER et en fait je n'ai pas su déterminer si ce mod améliorerait quelque chose ou si ça ne fonctionne qu'avec les appli Walkman et autres lecteur MP3?
Phil backup bien avant ! Si vraiment l'addon ne passe pas tu peux tjr installer l'app Noozoid seul après le mod rajoute surtout certaine ligne dans la build.prop et autre 48kZ ...
