• Based Samsumg firmware XXUEMK8 android 4.3 • CSC OXAEMK8 choose in aroma default Set • Kernel ==> Choose in Aroma - Abyss v1.7.1F (thx @angelom) - Ausdim Google 4.3v11 (thx @ausdim) - Hacker Kernel V7 (thx @thehacker911) - Talexop v1.3 (thx @talexop) • Deodexed busybox • Zipalign new applications at boot and db optimize • Knox free • Modded settings with link to BoBCaTROM Control , it include many options: - Ad Away - Multi Window Manager - Cpu monitor - Torchlight in lockscreen - Cpu monitor - Cpu spy - Language Enabler Thx @wanam - Fast Dormancy - aLogCat - Change battery icon on the fly and select battery charge animation (+70 battery to choose) thx @OsamaGhareeb - OTA Update Home with link to WUALA folder for Updates, Extra, Themes , link to XDA thread and donation button - OTA Update Pro, automatic alerts of new release with possibility to download it directly - OTA Updateme, Extra, Applications, Theme, Mod,Fix ..., Pooldown images ....other - Reboot menu three way (normal, recovery, download) - Xposed installer + modules * App DPI settings * Greenify * MultiwindowManager * Network Speed Indicator * Wanam Xposed (Credits @wanam and his great application) - Features list: •Call Recording •4 Ways Reboot (Reboot, Recovery, Hotboot, Download) •Full Color/Transparency customization for Status bar and Notification drawer elements •Secure Samsung Keyboard •Option to keep "Add Call" button with Call recording menu •Disable Camera shutter sound (+Screen Capture) •Flashlight trough volume button UP •Skip Music with Volume buttons •Save Call Logs View •Enable Keyboard Symbols •Enable Hangouts Calls trough cellular •Enable Camera while calling •Unlimited and Customizable Multi-View support •Bypass Exchange Lock check •Notification Panel Customization •Long Home key behavior •Long Back key to kill App (+ white list) •Disable increasing ringtone •Messaging Tweaks (raise limits and conversion) •Disable Scrolling cache •Enable Full rotations •White/Colored Circle Battery •Transparent Notifications panel •Customize Clock format and size •Customize Battery text helper size •Customize Quick Settings buttons number per row •Collapse Quick Settings after toggle •2 line formatted date on the panel header •Dark themed Multi-Window •Disable Boot sound •Customize Two line date header format •White/Black Email App background (Supported on some devices) •Transparent Quick Settings buttons background •Default hidden SMS logs •Add Call button to Logs and Contacts list •Disable Accounts icons on Contacts list •Custimize Wifi AP Clients number •Disable Launcher page rotation •Add Exit button to browser •SMS Automatic input mode •Disable Call number formatting •Enable unlimited Contacts joining •Enable Gallery Rotation trough button •Set default Browser view to Desktop •Hide Wireless charging popup •Hide Full Battery Notification •Clock position Status bar (Hide, Left, Right, Center) •NFC behaviors (UN/Locked on Screen ON/Off) •Hide Headset icon and notification bar •Disable TW DVFS •Enable TW DVFS Boost Benchmark mode •Hide Smart Stay, Alarm, NFC icons on status bar •Launcher: Enable Scroll wallpaper and Hide Dock labels •Disable Wake Home button •Use separate Address field on Contacts •Add Fast PIN unlock (to be used with caution) •Added SMS sent time details •Enable Screen ON options on Messaging App •Disable low Battery warning •Add custom carrier label on notification label •Set low Camera battery level •Change System Holo Dark/Light background •Acces hidden Lockscreen shortcuts menu •Disable SEAndroid/Knox notifications •And much more to come
• NEW BOOTANIMATION QMG and icons 180battery (thx) @pas2001) • Enabled secondary symbols on stock samsung keyboard • Camera with shutter sound on/off option • Browser with exit option • Unlocked lockscreen torch option • Sms will display sent time instead off received time • Unlimited contacts join • Fix NFC Payment • Long Press Menu Button to kill app • Hide sms from call logs • Disable scrolling cache • Email with Exchange Security Disabled • Greenify app • 4Way reboot menu • Automatic Phone Recording Mods (Thx @mythtrandyr) http://forum.xda-developers.com/show....php?t=2498473 - Auto Call Recording on-off for incoming calls - Auto Call Recording on-off for outgoing calls - Increasing ringtone on-off • more to come
Installation
ATTENTION - DOWNLOAD FILES - Si vous avez déjà les bons modems, ignorez cette étape. - cette étape est nécessaire car le modem LTE XXUEMJ5 endommagera votre son sur l'ancien Bootloader. L'installation du modem varie selon le bootloader que vous avez.
Utilisez ODIN 3.4 => ANCIEN BOOTLOADER XXUB : flashez le fichier GSM_Modem_XXUEMJ5_and_LTE_Modem_XXUBMH1.tar avec Odin / Champ PHONE. => NOUVEAU BOOTLOADER XXUD : flashez le fichier GSM_Modem_XXUEMJ5_and_LTE_Modem_XXUEMJ5.tar avec Odin / Champ PHONE.
Suivez ces instructions / testé avec le PhilZ Recovery : 1. Sauvegardez votre appareil 2. Vérifie le MD5 du zip et copiez-le sur votre appareil 3. Eteignez le téléphone et retirez la batterie pendant quelques minutes 4. Démarrez en mode Download 5. Flashez le modem 6. Démarrez dans le recovery et flashez la ROM (FULL WIPE bien sûr) 7. Ignorez le message pour le fix du Root quand vous êtes dans le recovery. Si vous n'avez plus le root une fois sous Android, flashez le SUperSU
Si vous ne pouvez pas flasher le modem, suivez ce guide.
[GT-i9505]XXUEMK8_BoBCaTROM_EVO_V9.0 XDAFileServer - AndroidFileHost - MEGA - Mojosmirror - xda.base-mail.us
franchement la bobcat 2.1 est parfaite aucun bug tous est fonctionnel ( wifi , 4g , bluetooth , carte sd 64go ) bref tous fonctionne et visuellement elle est superbe
bonjour a tous bobcatrom v3.0 en FM8 dispo depuis ce matin
http://www.androidfilehost.com/?fid=23017610006234293 ou http://www.xdafileserver.nl/index.php?dir=Samsung%2FGalaxy+S+IV%2FBoBCaT%2FV3.0_XXUBMF8 ou https://mega.co.nz/#!ZkQTnQSb!H3V6VQ1VEV8NiWswNYg2K2e7_sQluwjaGvp8TQBsD8Y
Je viens d'installer cette Rom, et je suis beaucoup moins enthousiaste que vous. En effet, depuis quelle es sur mon tel, je ne rencontre que des bugs : - Redémarrages intempestifs - Sorti de veille du tel très longue (quand il sort de veille) sinon obligé de redémarrer complètement le tel. - Affichage récurrent de la mention : Paiement NFC s'est arrêté
Bref, grosse déception pour moi.
J'ai fait l'installation à partir d'une ROM Stock rootée avec CF Root, Phil Z touch recovery
Si vous avez une idée, c'est avec plaisir que je prendrais conseil.
Edit : Je me réponds à moi même, je viens de trouver pour le problème de sortie de veille et l'affichage récurent "Paiement NFC..." Il s'agit de bugs reconnus par le développeur, il a sorti des correctifs à télécharger (voir sur xda)
Edit 2 : malgré l'installation des patchs correctifs, cette V3 est très buggée (chez moi) j'ai des blocages intempestifs, des lags...
étrange ton histoire je n'ai aucun problèmes de mon coté parti d'une fm8 stock après un full wipe, puis root , recovery et install bobcat v3 avec wipe cache et dalvik par contre je ne suis pas trop présent sur ce forum car très pris sur un autre ou on est pas mal sur cette rom et personne ne se plaint sinon tu peut essayer la pyrana qui est ma deuxième rom favorite
Voici un patch pour le NFC Fix NFC, I had forgotten to remove apk NFC Payment that does not work DOWNLOAD added in Ota section MOD FIX
Edit:
Pour le recovery j te conseille le TWRP qui fonctionne très bien.
Salut tout le monde, avez vous remarquez quelque chose de différents au niveau de la qualité photo de votre appareil, avec la v3.0 , l'appareil photo ne prends plus de photo en 13 mpixels.
