description[ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013] Empty[ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013]
WanamLite
L'une des plus célèbres ROMs Android pour votre Samsung Galaxy S4 i9505 !!! Very Happy
 Based on the latest FW
Deodexed & Rooted & Zipaligned & Busybox
Unlimited SMS recipient list
Adam Kernel
Automatic SMS encoding (Arabic and other utf-8 encoding support)
Tweaked Ondemand Governor for better Battery life
Disabled scrolling cache
Removed bloatwares (Available on separate patch)
Large APN list
No incremental ringtone
Enabled Call recording
Enabled Call button on Contacts list
4 Way reboot (Recovery,Download…)
Clean build.prop for best Market compatibility
Stock Keyboard with all supported languages enabled
Kies support
Hacked Stock Email App
Latest SuperSu update
Enabled all supported languages
Enabled call button on Contacts list
More Free Ram
Auto wipe cache & dalvik-cache before flashing
Busybox (installed on “/system/xbin”)
Disabled NFC Payment
More to come…
[ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013] Attachment
[ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013] Screenshot_2013-08-24-22-29-09 [ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013] Screenshot_2013-08-24-18-22-43[ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013] Screenshot_2013-08-24-17-22-35  [ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013] Screenshot_2013-08-27-10-51-42[ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013] Screenshot_2013-08-26-00-22-01
Based on XXUBMGA
Enabled More languages
Adam kernel 1.5
Updated LTE white-list (more carriers)
Disabled Crt-Off animation (available on a separate patch)
Other things i don’t remember
Installation
Copiez le fichier .Zip de la ROM sur votre /sdcard
Redémarrez dans votre recovery custom.
Faites un Nandroid Backup.
Faites un Wipe data + dalvik + system.
Flashez la ROM.
Redémarrez.
Applications supprimées :
  • GT-I9505_WanamLite.XXUBMH1.V1.5.NO-WIPE.zip (MD5:034109C7945D1BC7FB6424315FA647FD)
  • Removed Apps (MD5:01A40FD3BE037DD431AF370CCB498150)
  • Adam Kernel 1.6 (already include on this Rom)
  • Mirror1  -  Mirror2
description[ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013] EmptyRe: [ROM 4.2.2][GT-I9505] WanamLite [Rapide|Propre|100% Stable][MH1][14.10.2013]
Merci :d:d:d
Merci du partage cheers
Merci pour le partage;)
Je tourne dessus depuis 2 jours, tous semble fonctionner même le wifi...
Pour l'autonomie, je la trouve plus que correct pratiquement 4 h de fonctionnement ecran et il me reste 25%...(je limite le processeur à 1566mHz et elle reste bien fluide:D)
C'est du stock en light, moi derrière je supprime encore des appli inutiles...
hello les i9505 smile je sais que je suis hs avec mon i9500   mais je vous suis de temps à autres...
Je suis sur la dernière wanam pour le i9500 et ça tourne vraiment super bien, je suis parfois à 3 jours d'autonomie avec mon usage habituel et plus la moindre trace de lags ou de surchauffe avec sa dernière version. Bref wanam a "dompté" ce exynos octa (pas trop bien étudié par sam lors de sa mise en service), je l'ai mis depuis tjrs sur mes anciens gs2, gs3, gs3 LTE et maintenant sur mon gs4 i9500 qui est vrai bijou ! je pense que sam devrait engagé ce développeur... smile
a+
Mise à jour de la rom.
[ROM][18/07][MGA V1.4] WanamLite Fast | Clean & Rock Stable
Changelog:
Based on XXUBMGA
Adam kernel 1.5
WanamLite XXUBMGA V1.4
(MD5: 01006E02D12D4F4861D6563B82B197DB)
Post 1 à jour merci.
Merci pour le partage Wink
Je crois que je vais me laissé tenter malgré que l'omega soit pas mal Very Happy
La 1.5 est en ligne Very Happy
Ca fesait un moment que cette Rom n'a pas était mis a jour... je vais laissé de coté MIUI et retourné sous la WanamLite ^^
Quelqu'un pourrait-il me dire comment faire pour avoir le panneau de notification en transparent ?
J'ai beau changer les réglages dans l'application Wanan exposed et rebooté mon tel mais le panneau reste identique.
Merci par avance pour votre retour.
Il n'y a personne pour me répondre ?
Merci quand même en tout cas.
Bonsoir Zmintchon,
As-tu essayé de faire un wipe cache partition + wipe dalvik cache.
Tu actives l'option et tu reboot
Bonjour Mendicant Bias,
Je te remercie de me répondre, tu es d'ailleurs bien le seul a le faire.
J'avais déja tenté un wipe cache + partition mais cela ne fonctionne toujours pas.
En fait en allant dans l'applis xposed installer j'obtiens le message suivant :
"This module requires a newer Xposed version (30) ans thus cannot be activated".
J'ai également complètement désinstaller l'applis Wanam et l'ai réinstallé via le play store mais malgré les réglages que je fais, cela ne fonctionne toujours pas.
Merci encore Mendicant Bias et bonne journée.
Bonjour Zmintchon,
De rien c'est un plaisir Very Happy
En espérant qu'on trouvera une solution à ton problème
Alors essaye d'aller dans "Xposed Installer", puis dans "Framework" tu appuis sur "Installer/Mettre à jour".
Quand c'est fait tu vas dans "Modules" et tu coches le module "Wanam".
Vérifie bien que ce soit la v2.2.2 qui soit bien installé.
Si ce n'est pas le cas dans "Téléchargements" tu cliques sur "Wanam Xposed" et tu fais "Télécharger/Installer la v2.2.2".
Enfin dans Wanam réessaye de faire ta configuration et tu redémarres pour voir si c'est ok.
Salut Mendicant Bias,
Malgré toutes les modif effectués, rien n'y fait.
Je vais en rester la pour le moment.
Je te remercie encore pour le temps pris a me répondre.
Ah mince, dommage que ça ne fonctionne pas Sad
Si tu es partant tu peux toujours essayé de refaire une clean installe et essayer la méthode que je te propose
J'au un soucis: j'ai tout installé mais le tel reste bloqué sur l' écran SAMSUNG...
J'ai fait tous les wipes mais rien ne se passe....
HELP...
Bonjour Rocco,
L'installation de la rom a bien fonctionné ?
Tu n'as pas eu de message d'erreur lors de l'installation ?
Non sans soucis.
Bon là c'est good!
J'ai le réseau 3G mais plus d'internet!!
Je peux passer les appels et sms ..
Tu as réussis à installer la rom ?
Qu'est-ce qui bloqué ?
Pour ton problème d'Internet as-tu vérifié tes APNs ?
Voila c'était les APN!!!
Full wipe de malade et ça à marché!
Ah excellente nouvelle, content que ton problème soit résolu cheers
Amuse-toi bien avec ta nouvelle rom smile
Bonjour a tous et bonne année 2014,
J'ai un petit soucis avec le client mail de cette ROM.
La couleur de fond des paramètre est noir et l'écriture l'est également donc difficile de paramétrer un compte mail.
J'ai coché la case fond blanc dans l'application Wanam Xposed mais rien n'y fait.
Quelqu'un aurait-il une astuce ?
Merci par avance
