[CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1]
+7
jdiamsss
iSlash75
gaetan15
zmintchon
11 participants
description[CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1] Empty[CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1]
PhoeniX ROM
[CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1] Logoxda2
Le mot du créateur de la rom "Tamirda" :
"Je vous présente la rom Phoenix pour le Samsung S4 I9505."
Détails :
Based on the lastest stock firmware: Android 4.3 - XXUEMJ7
Stock Kernel XXUEMJ7
Fully Deodexed
Added latest BusyBox
Added latest SuperSU+Bin files
Added Flashplayer support (Note: Flash doesn't work on stock browser, use dolphin or something.)
Updated all stock apps to their latest version(Gmail, Google search, Google Maps ,Play store etc.)
Removed debug info - system is faster by 30% from stock!
Unique PhoeniX bootanimation & shutdown animation - Huge thank to the artist anbech
Mods:
   Call Recorder
   Hacked Stock Email App
   Disables NFC Payment
   CRT Animation enabled
   Sysro & sysrw support
   Enabled touchwiz wallpaper scrolling
   Disabled scrolling cache
   Phone with no increasing ringtone
   All supported languages enabled
   All supported languages for Samsung Keyboard enabled
   Enabled init.d scripts
   Shutter Sound menu Enabled to stock camera
   Big APN list
   Enable sub Symbols on Stock Samsung keyboard
   Added exit menu to stock web browser
   Dialer search matches numbers in contacts and call logs along with contacts
   data/app enabled
   NFC Hack - You can use your NFC while the screen is off, and at lockscreen.
   4 ways to reboot menu - Extended power menu
   Enable call button in contact list
   Disabled Converting Effect Between SMS MMS
   Automatic SMS encoding (Arabic and other utf-8 encoding support)
   Automatic efs backup when flashing the rom.
   Multiwindow Manager by bjbinc
   Pie Control
   Exclusive! Only to PhoeniX ROM!:
   * New Amazing Wallpapers in Wallpaper Chooser Wallpapers! Beautiful Wallpapers! How to use? Click on Menu-> Set Wallpaper-> Home/Lock/Both-> Wallpaper Picker/chooser-> Select your Wallpaper!
   * New Settings app: Huge thank to ficeto!
   PhoeniX Settings App includes the following features:
   Samsung Secret Codes
   Fast Dormancy
   Faster Fix GPS
   CSC Select
   CPU Spy Plus
   Idle Wifi Time Manager
   Logcat
   OS Monitor
   PhoeniX OTA Center - now you can update the rom without plugin into the computer!
   The downloads will be save on the internel SD card under the folder OTA updates.
   Reboot options - Normal, Recovery, Download.
   And more coming soon
Tweaks :
-Kernel Tweaks
-zipalign script
Removed from the rom :
-Bloatware - around 550MB of bloatware.
Images et Vidéos
[CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1] Ul1q [CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1] R7h[CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1] 41k[CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1] Jno
Installation
1) Démarrez dans le CWM Recovery en maintenant les touches "Volume +", "Power" et "Home".
2) Faîtes un NANDROID Backup via le Recovery en allant dans "Backup et Restore/Backup" ou "Backup et Restore/Backup to External SD".
3) Allez dans "Mount and Storage" et choisissez "Format system" puis faites un "Wipe Data Factory Reset" (pas nécessaire si vous venez d'une version précédente de la Rom), "Wipe Cache Partition" et dans "Advanced" "Wipe Dalvik Cache" ou cochez l'option "Full Wipe" lorsque vous êtes dans l’installeur Aroma.
4) Flashez la ROM et redémarrez.
5) Enfin amusez-vous  Very Happy
Changelog
07 janvier 2014 - v7.3 OTA Update :
  • Fixed LTE Support(set value from false to true)
  • Added New Note 3 Features:
    - Note 3 Calculator
    - Note 3 One Handed operation(With all options!)
  • Fixed missing MW Manager
  • New improved Action Memo
Anciennes versions :
Spoiler :
Téléchargements
PhoeniX ROM v7.0 - Lien 1 + Phoenix ROM v7.3 OTA Update
PhoeniX ROM v7.0 - Lien 2 (Miroir)
(MD5 : 011e7c058a1133dccd2fbd68368260d6)
Spoiler :
[Comment uploader et partager un fichier?] - [Vous êtes développeur ou cuisto?][/center]
description[CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1] EmptyRe: [CUSTOM][4.3][I9505][09/01/2014] PhoeniX ROM v7.3 [XXUEML1]
Mods
-Super wipe
(ATTENTION : Faîtes un NANDROID Backup avant via le Recovery car cet outil formate la mémoire interne du téléphone "Internal SD Card").
Mods compatible avec la v1.0 :
-Hide Call Button on Contacts and Logs
-Disable CRT Animation
-Remove Wallpaper Scrolling
-Removed bloatwares XXUBMF8
Voir la liste ci-dessous :
Le développeur de cette rom ne possède pas le Samsung Galaxy S4 I9505.
Par contre il possède le I9500 et le Note 2, les deux threads sur ces téléphones sont disponibles ici Rom Note 2 et ici Rom S4 I9500
Merci du partage cheers
Je modifie le titre pour être conforme à la section.
Mais de rien Sccip, c'est un plaisir Very Happy
Pas de soucis n'hésite-pas si tu vois d'autres anomalies.
Post 1 mis à jour : Ajout du lien de la rom
Post 2 mis à jour : Ajout de plusieurs mods pour cette rom
Merci beaucoup pour cette rom et le travail effectué.
Néanmoins il semblerait qu'il soit impossible d'activer le wifi, cela reste en "activation". J'ai pourtant bien flashé la ROM en effectuant un wipe cache/dalvik avant.
Bonjour Zmintchon,
Je pense que ton problème vient du faîtes que tu n'as pas fait le "WIpe Data Factory Reset ".
Si tu veux installer cette rom il faut faire un Full WIpe avant en faisant un WIpe Data Factory Reset + Wipe cache partition + wipe dalvik cache + dans "Mount et Storage" un "Format System" et un "Format Preload".
Fais bien un NANDROID Backup avant via le Recovery, sinon regarde la procédure d'installation disponible dans partie "Installation" post 1.
Après ça tu ne devrais plus avoir de soucis.
Topic mis à jour : Mise à jour du 21 juillet 2013 - PhoeniX ROM v2.0 [XXUBMGA]
Topic mis à jour : Mise à jour du 19 août 2013 - PhoeniX ROM v3.0 [Big Aroma| Fast| Stable| Clean| De/Odexed]
Je ne peut pas regler la luminositer est ce normal ?
Bonjour Gaetan,
Tu as bien fais un Full Wipe avant de flasher la rom ?
Quand tu vas dans "Paramètres/Affichage/Luminosité" tu ne peux pas régler ?
Moi je lai tester et ces pas terrible ma barre de notif descend pas tout le temps ces quand elle veut, autant tamirda était bon sur note 2 autant là, je trouve qu'il est pas au top....
C'est une ROM MH8, tous les cuistots préconisent de flasher une rom stock avant.
Vos problèmes viennent peut être de là.
Apres un reboot tout les probleme on ete regler
Bonjour Gaetan,
Merci pour ton retour et content que ton problème soit résolu cheers
cheers
Topic mis à jour : Mise à jour du 28 octobre2013 - PhoeniX ROM v4.0 [Big Aroma| Fast| Stable| Clean| De/Odexed] [XXUEMJ5]
Topic mis à jour : Mise à jour du 02 novembre 2013 - PhoeniX ROM v5.0 [Big Aroma| Fast| Stable| Clean| De/Odexed] [XXUEMJ7]
Je viens de passer sur Phoenix v5 et pour l'instant j'en suis tres content.
J'ai cependant un petit souci avec l'indicateur de pourcentage batterie...
Je le coche dans les options mais dès que je sors des paramètres, le pourcentage disparait...
Quelqu'un aurait une idée ?
Merci d'avance !
Bonjour Jdiamsss,
As-tu essayé de redémarrer le téléphone et de réessayer ?
Oui oui, reboot plusieurs fois.
En fait, j'active l'option et si j'appuie sur le bouton HOME, le pourcentage reste, sauf qu'il ne se met pas a jour... donc aucun interet.
Pour l'instant j'ai mis un autre compteur qui vient d'une appli (BAttery doctor) mais bon, je prefere celui d'origine ;o))
Bonjour Jdiamsss,
Bizarre des que possible je remonte l'information au dev de la rom pour voir si un dix ou quelque chose existe.
Dois je tenter de reflasher la ROM ?
Tu peux toujours tenter en faisant un full Wipe et flash de la rom
