StatusBar & Navigaion Bar Transparency Custom BootAnimation Option to Disable BootAnimation Custom Carrier Label Notification Background Notification Count Option to Vibrate on expanding a Notification Control StatusBar brightness slider Hidden StatusBar Pull-Down Option to hide/show IME Switcher Allow 180-degree Rotation Allow 270-degree Rotation Wake up on charging CRT Effect Controlling system Kill-All Button in Recents Menu Recents RAM Bar
Lockscreen
Control Locscreen Text color Lockscreen Battery Percentage Control Lockscreen Rotation Volume music controls Wake device via Volume Rocker Control Amount & allowed Widgets Use Widget Carousel Lockscreen Shortcuts on ring
Power Menu
Option to add Screenshot button in power menu Option to add Torch button in power menu Option to add Airplane more in power menu Option to add Volume States in Power menu Option to add button giving option to hide both SystemBAR and Navigation Bar Option to control whether Reboot is shown on Lockscreen or not
Navigation Bar
Control Menu Button Location on Navigation Bar Control Buttons Visibility Add Arrow Keys while typing Control Button Colors Control Glow Color when button pressed Hidden Navigation Bar Widgets on Navigation Bar Add extra buttons on Navigation Bar
Navigation Ring
Option to add up to 5 Navigation Rings Control extra options on Longpress
Ribbons
Add Shortcuts for various apps, functions on Lockscreen, Left/Right on swipe, Quick Settings Panel, Notifications Panel
Toggles
Control Amount of toggles enabled Extra Toggles like StayAwake, Pie Enabling, Sleep and more Control their size Control amount of Toggles in one line Fast Toggle Custom Toggle Toggling between Traditional, Scrollable or Tiles
Battery
Battery Icon only Battery Icon Text only Battery Icon with Text Battery Icon with Centered Text Special CircleMOD Don’t Show battery BatteryBar on SystemBar or navigation Bar
Clock
Control Clock Color in Status Bar AM/PM Style Day of the week Clock Short Click , Long click and double click options Centered Clock
Signal
Signal Indicator Style Signal Indicator Color WiFi Signal Indicator Style WiFi Signal Indicator Color GingerBread Style Signal Cluster Hide Signal bard
LED
Control LED Color Control Duration and when to light on
Sound
Volume Panel Frequency of Notification Sounds Headphone plugged-in action Phone Call silence Face down audio mode
ReVolt Features
Dark ReVolt (Thanks To SlimROMs) Font Size Controlling system Expanded Desktop Lockscreen Shortcuts (Thanks to ParanoidAndroid) Enhanced Screen Security Features cLock by CyanogenMod Notification shortcuts (by SlimRoms) PowerWidget (by CM) DPI Controlling System Camera Shutter sound controlling MultiUser CyanogenMod Profiles Open-Sourced SuperUser (by Koush)
Installation
SI VOUS VENEZ D'UNE ROM STOCK :
1- Rooter votre tablette & installer un recovery custom comme le PhilZ Touch disponible sur le forum. 2- Redémarrez dans le recovery 3- Faites un wipe data + cache + dalvik cache 4- Flasher la ROM (+ GApps si nightly) 5- Faites un Wipe cache et dalvik cache 6- Redémarrez normalement.
SI VOUS VENEZ D'UNE AUTRE ROM CUSTOM :
1- Redémarrez dans le recovery 2- Faites un wipe data + cache + dalvik cache 3- Flasher la ROM (+ GApps si nightly) 4- Faites un Wipe cache et dalvik cache 5- Redémarrez normalement.
SI VOUS METTEZ A JOUR LA ROM ReVolt :
1- Redémarrez dans le recovery 2- Faites un wipe cache + dalvik cache 3- Flasher la ROM (+ GApps si nightly) 4- Faites un Wipe cache et dalvik cache 5- Redémarrez normalement.
Téléchargements
n8000 Builds | Google Apps (Requis pour les Nightlies)
n8013/10 Builds | Google Apps (Requis pour les Nightlies)
Images
Derniers changements
Version 4.4: ---- NEEDS A FULL CLEAN INSTALLATION ---- 1- Added support for various devices (officially support over 25 devices now !) -m7ul, m7tmo, m7att, m7spr, jfltecan, jfltetmo, jfltespr, jflteusc, jfltevzw, jflteatt, and more !! 2- Added BAMF Theme Engine 3- Memory Leak Fixes (in frameworks_base and in frameworks_native) 4- Various updates and fixes for HTC One users 5- Addition of HALO multi-window notification system (By PA) 6- ReVoltControl has been added : - ReVolt Control is an application based on ROMControl (By AOKP) which features various features specially for ReVolt ROM 7- Added Welcome app to help users know the ROM 8- Added option to share with people you use ReVolt ROM (In Settings => About Phone) 9- ReVoltLauncher has been added with various features 10- Replace CircleMOD with CM's Circle Battery with more functions 11- Added Rush Battery (Thanks to Rootbox) 12- Update Roboto Font (From Android 4.3) 13- LTE Toggle Fixes 14- Add Network Speed Indicator (Thanks to Team ThinkingBridge) 15- Added TeamBACKED's Toggle colouring system (Thanks to them and daxxmax) 16- Added HALO Colourizing engine (Thanks to daxxmax) 17- Halo could save it's place and can be disabled 18- MultiUser Selector has been cleaned up 19- Add 2G/3G option to Profile Connections 20- Added Music Toggle 21- Option to launch apps from Recents in Floating mode 22- Privacy Guard has been added 23- More Pie Options and optimizations 24- Various fixes and deadlock fixes 25- Fix Lockscreen FC/Reboot 26- Option to pause Underlaying app in Halo 27- Fix BatteryBar showing in all 3 places at same time 28- More Battery Friendly 29- New Auto-Brightness Controlling system 30- Lockscreen see Through 31- Low Battery Sound Policy Controller 32- Show date on 2 lines in Notification Center 33- Pie : Angle Chooser 34- Smoother and Faster Notification pull down 35- AOKP Ribbons updated 36- Fix Tablet UI Battery showing 0% 37- WirelessADB Toggle 38- AOKP Ribbons Toggles 39- Fix IME Switcher staying on top 40- Fix StayAwake Toggle 41- Don't Enable WiFi when AirPlane Mode is on 42- Added Hybrid Toggle 43- Added ReVolt Statistics 44- Added Hardware Key Remapping 45- Add CMFileManager (Except for AROMA Devices) 46- Add Apollo Music Player (Except for AROMA Devices) 47- ReVoltLauncher support Per-App-Color 48- MMS Updates 49- More Features added to Camera (Except for Nexus Devices_ 50- Update Dark ReVolt for EMail app and add it for Calculator 51- HTC One users have a powerful kernel 52- Use PA's Custom Kernel for Nexus 4 Users 53- Fix Grouper Build and Fix n7000 and n7100 builds 54- Added optimizations for mako users 55- Specific Fixes and features for devices 56- Gesture Lockscreen Added 57- Add Custom Lockscreen BackGround option
Je voudrais l'installer sur ma galaxy note 10.1 wifi (N8010) mais j'ai un doute quand au choix à faire
Dans la procédure il est indiqué "4- Flasher la ROM (+ GApps si nightly)"
Je sélectionne donc la ligne "n8013/10 Builds | Google Apps (Requis pour les Nightlies)":
- Le premier lien ("n8013/10 Builds") me renvoi sur la page qui propose: ALPHA / Nightlies / ReVolt-JB-4.4-n8013.zip --> A quoi correspondent ces répertoires ALPHA et Nightlies? Et dans quel cas les utiliser?
- Le lien ("Google Apps (Requis pour les Nightlies)") renvoi vers une page qui propose des Packages et des Files --> A quoi correspondent-ils?
Sachant que je voudrais installer la rom la plus récente et la plus complète que me faudrait-il choisir?
Voilà avec ces questions je ne peux pas cacher que je suis un peu perdu et que j'ai vraiment besoin de votre aide svp?
Je viens d'installer la rom et je vais la teste. Par contre une petite question: c'est une version pour une N8013 alors que j'ai une N8010. Cela ne pose pas de problème?
