description[ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013] Empty[ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013]
Poppuri
Le mot du membre "xaoc747" :
"Je vous présente la rom Poppuri pour le Samsung Galaxy Note 3 compatible SM-N900 uniquement."
Détails :
- XXUCMK2 deodex
- Root, Busybox , etc.
- Kernel and modem from Firmwares XXUCMK2
- Full date
- Background of Apps themed in Simple
- Toggle switches in Simple Theme
- Blue ticks and circles in choosing
- Battery "Circle" gray-white with percents
- Semi-transparent samsung windows
- Semi-transparent panel of notifications
- White icons in shortcut like in statusbar
- Transparent weather widget
- Added newest Poppuri Gallery
- In Dialer VideoCall changed to Message
- In the pop-up menu in dialer Message is replaced by VideoCall
- Added mod full photo with autorecording
- In extended Power Menu added Recovery and Download
- Slightly increased the volume of the headphones for Players
- Added my set of hidden possibilities in other.xml
- Icon of audio player replaced to right one
- Removed a request by the player on high volume
- Video player with transparent background of Management buttons
- Support AC3 sound in the video player by Pako777
- All samsung apps (except SMS) with hiding statusbar
- Keyboard with additional characters as amended by location
- Icon Eye removed from StatusBar
- In the lockbar word "charging" shifted down closer to the operator
- Lowered the threshold for disconnecting of camera and alarm for low battery
- In many places, fixed background from gray to right, to tone of entire theme
- And Much More Other Changes ...
Images et Vidéos
[ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013] Zr9 [ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013] Qw5k
[ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013] 3vhm[ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013] 2scx
Installation
Clean Installe de la rom :
1) Important : Faîtes un Backup EFS (IMEI) via ce tuto [OUTIL][SM-N9005] Backup et Restore EFS (IMEI) pour le SGNIII
2) Démarrez dans le Recovery custom (CWM) en maintenant les touches "Volume +", "Power" et "Home" et vérifiez que vous avez la dernière version via ce Regroupement.
3) Faîtes un NANDROID Backup via le Recovery en allant dans "Backup et Restore/Backup" ou "Backup et Restore/Backup to External SD".
4) Faites seulement le "Wipe Data Factory Reset" via le Recovery.
5) Ensuite flashez la ROM.
6) Redémarrez et amusez-vous  Very Happy
Installation des modems :
1) Attention, les modems ne se flashent pas par le Recovery custom
2) Ils sont disponibles sur la rom dans "Menu/Paramètres système/AppareilXNote extra menu/XNote Update/Rom update/Modem"
3) Flashez le modem via Odin PC.
Activer le débogage USB :
1) Aller dans "Paramètres/Général/A propos de l'appareil".
2) Tapez 7 fois sur "Numéro de version", un message apparaîtra en disant que "le mode développeur a été activé"
3) Allez dans "Paramètres/Général" et vous verrez au-dessus de "A propos de l'appareil" le nouveau menu "Options de développement".
4) Allez dans ce menu et vous allez pouvoir activer le débogage USB cheers
Changelog
31 décembre 2013 - v3.0 :
- New build XXUCMK2 Deodex
- Root, Busybox, etc...
- English Aroma
- EFS Backup automatic
- Modem from MK1
- Kernel from alexseyuh #4 with disabled SeLinux
- Fixed work of Simple widget
- Some other things...
Anciennes versions :
Spoiler :
Téléchargements
ROM POUR LE N900 UNIQUEMENT
Poppuri v3.0
Spoiler :
description[ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013] EmptyRe: [ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013]
Topic mis à jour : Mise à jour du 11 novembre 2013 - Poppuri Aroma Simple Theme Note3 V2.0 [XXUCMJ7]
Topic mis à jour : Mise à jour du 31 décembre 2013 - Poppuri Aroma Simple Theme Note3 V3.0 [XXUCMK2]
et merci pour ce topic!
En mode découverte...avec mon N900, je m'y colle!
En Fr aussi je présume...
merci!
B  [ROM 4.3][SM-N900] Poppuri Aroma Simple Theme Note3 v3.0 [XXUCMK2] [31.12.2013] 61393
De rien,
Toutes les roms présentent sur XDA et le forum sont multilang
