CivZ_FlexKat
Le mot du créateur de la rom "Civato" :
"Je vous présente la rom CivZ_FlexKat pour le Samsung Galaxy Note 3 compatible SM-N9005 uniquement."
Détails :
- CivZ_SnapKat kernel or stock kernel
- InktEffect thanks to mythtrandyr
- 4-Way-reboot
- Rotate all angles enabled in framework
- MMS/SMS mods :
- DISABLE THE SMS TO MMS AUTO-CONVERSION
- SCHEDULED MESSAGING
- SAVE / RESTORE
- GROUP MESSAGING
- ENABLE SPLIT-VIEW MODE ON/OFF TOGGLE - ExternalSD card R/W fixed
- Deodexed & zipaligned (will zipalign new apps on reboot if init.d is enabled)
- Busybox 1.22.1 included
- SuperUser 1.93 included
- SpenWindow manager & MultiWindow manager included
- Xposed framework & Xblasted module included
- ViperFX supported and included (modded build.prop) Updates follow this thread.
- Xperia wallpapers added
- energyBar added
- Universal init.d
- AppsOpsXposed
- EnableCallRecording Xposed module
- Xad & YouTube AdAway xposed modules
- CSC hidden features enabled: Camera sound; Key_symbols;........
- Init.d tweaks for I/O (If you enable the init.d support with the universal init.d app)
- Apps updated and google apps placed in data to keep a clean system all the time.
- Aroma installation to pick the apps you want and the region you need.
- etc.........
Kernel Features :
- Selinux status = Permissive
- NTFS R/W support with the use of Paragon (see playstore)
- ExFat
- XZ compressed
- Build in init.d support
- insecure & adb insecure
- Power suspend driver_1.2 @ Faux123
- Synapse control added with various options: CPU control; Kernel controls...
- Led control_1.1 @ Yank555.lu
- mdnie control_1.3 and synapse support @ Wootever
- Faux Sound_3.2 @ Faux123 & Wootever
- 2.8GHz Maximum overclock (unlock with Synapse app)
- TouchBoostdriver Min frequency locked = no more jumping to 1.1GHz as minimum frequency
- Voltage control thanks to myfluxi & synapse voltage control thanks to wootever.
- Intelli HotPlug_2.0 & ECO Mode @ Faux123
- GPU Overclocking up to 533MHz
- Governors: Intellidemand , Conservative , Adaptive , ondemand , wheatly , powersave , interactive , performance.
- Schedulers: cfq , noop , bfq , deadline , vr , row , fiops , fifo , sio , zen.
- OC Unlock / lock setting in Synapse = Default is set at 2.265GHz stock speed. = Replacement for maximum frequency lock (Based on angelom max_limit)
Regions disponibles dans Aroma :
Spoiler :
"BGL", "BULGARIA"
"BTU", "UNITED KINGDOM"
"CYO", "CYPRUS"
"DBT", "GERMANY"
"ERO", "BOSNIA-HERZEGOVINA"
"EUR", "GREECE"
"ITV", "ITALY"
"MSR", "SERBIA"
"ORX", "SLOVAK"
"PHE", "SPAIN"
"PHN", "NETHERLANDS"
"PRO", "BELGIUM"
"ROM", "ROMANIA"
"SEB", "LATVIA"
"SEE", "SEAD"
"SIO", "SLOVENIA"
"TEB", "Bosnia and Herzegovina"
"TOP", "SERBIA"
"TPH", "PORTUGAL"
"TRA", "CROATIA"
"TSR", "SERBIA"
"TWO", "CROATIA"
"XEF", "FRANCE"
"XEH", "HUNGARY"
"XEO", "POLAND"
"XSK", "SLOVAK",
Options disponibles dans Aroma :
Spoiler :
"AsusWeather"
"AllShare"
"Bloomberg"
"Chaton"
"AntService"
"SammsungApps"
"SamsungGo"
"Yahoo"
"GroupCast"
"Facebook"
"DropBox"
"AcerDNLA"
"GENIE"
"Scloud"
"SecAlarm"
"SecCalculator"
"SecFile"
"SecClocks"
"Secmagazine"
"SecMusic",
"SecVideo"
"EverNote"
"SecWeather"
"SHealth"
"Mobile print"
"Samsung Voice"
"Travel "
"VoiceRecorder"
"WatchOn"
"StoryAlbum"
"Pinboard"
"S_translator"
"QuickMemo"
"Sketchbook"
"PhotoShop"
"SamsungHub"
"KNOX"
Images et Vidéos
Installation
Pré-requis :
- Avoir installé la rom stock Android 4.4.2 [ROM 4.4.2][SM-N9005] Pre-Release Rom Stock Samsung Android KitKat 4.4.2 [XXUENA6]
Installation :
1) Important : Faîtes un Backup EFS (IMEI) via ce tuto [OUTIL][SM-N9005] Backup et Restore EFS (IMEI) pour le SGNIII
2) Démarrez dans le Recovery custom CWM Android KitKat 4.4.2 en maintenant les touches "Volume +", "Power" et "Home" et vérifiez que vous avez la dernière version via ce Regroupement.
3) Faîtes un NANDROID Backup via le Recovery en allant dans "Backup et Restore/Backup" ou "Backup et Restore/Backup to External SD".
4) Faites le "Wipe Data Factory Reset", "Wipe Cache Partition" et dans "Advanced", le "Wipe Dalvik Cache" via le Recovery.
5) Ensuite flashez la ROM.
6) Enfin redémarre et amusez-vous
Activer le débogage USB :
1) Aller dans "Paramètres/Général/A propos de l'appareil".
2) Tapez 7 fois sur "Numéro de version", un message apparaîtra en disant que "le mode développeur a été activé"
3) Allez dans "Paramètres/Général" et vous verrez au-dessus de "A propos de l'appareil" le nouveau menu "Options de développement".
4) Allez dans ce menu et vous allez pouvoir activer le débogage USB
Changelog
29 avril 2014 - v2.5 :
Rom :
- Based on new ND5 source
- Apps and lib files updated
- All direction/Screenlock rotation enabled (again)
- CPU boost when scrolling enabled
- Screen mirror (allshare) fix included , now it even works with custom kernel @ sorg removed as this was for JB.(still testing)
- New kernel SneakyKat Rev1.5 included
Kernel :
- Build optimization added for cortex-A15
- Ramdsik changes also for the 900T
- Hyper and nightmare governor enabled again and tweaked
- Intellidemand governor tweaked for battery performance
- GPU OC up to 550MHzIt is not doing what it should so removed, Thanks @ sorg for pointing it out and explaining why.
Anciennes versions :
Spoiler :
16 mars 2014 - v2.1 :
- New base KOT49H.N9005XXUENC2
- Kernel Rev2.4 is in aroma
- sms/mms tweaks @ _alexndr
- Disabled SMS to MMS auto-converting
- Increased SMS/MMS recipient limit (10 -> 1000)
- Increased SMS/MMS hour limit (100 -> 1000)
- Disabled SMS / MMS log history in call logs - 2-way Call recording function @ mythtrandyr
- Chinese samsung keyboard included
- Apps updated
Kernel v2.4 :
- Extra driver support
USB_RTL8150
USB_HSO
USB_DUN_SUPPORT - FrontSwap and CleanCache
- Compiled in release mode = stripped of all debugging
07 mars 2014 - v1.9 :
- New base KOT49H.N9005XXUENB7
- Kernel Rev2.2 is in aroma
- Chinese Samsung Keyboard available in settings
- Apps updated
Kernel v2.2 :
- Fixed 533MHz GPU OC on Andreno governor @ Wootever
05 mars 2014 - v1.8 :
- New base KOT49H.N9005ZHUENB5 = International CSC support in aroma = ro.build is N9005XXUENB5 en HTLEXX
- Kernel Rev2.1 is in aroma
- Apps updated
Kernel v2.1 :
- 900T Based on the NB4 T-Mobile KitKat source from now on
- Updated ExFat driver for both 9005 & 900T
02 mars 2014 - v1.6 :
- New base KOT49H.N9005XXUENB4
- Aroma New mods available
- Apps updated
23 février 2014 - v1.5 :
- External SD fix for Titanium backup
- Aroma IOS Theme Option with better statusbar layout
- New Updater_Script with ORIGINAL permissions by Samsung Developers @ _alexndr
- SamsungLink FC fixed
- Transparent Aircommand theme optional in aroma
Kernel Change compared to Rev1.9:
- Only small ramdisk change to remove the Samsung ExternalSD Fix to allow Titanium backup to function as many users prefer that app.
- No other changes so the great stability of Rev1.9 is untouched.
19 février 2014 - v1.4 :
- Clock is back to default right position (use Xblasted to change position)
- CivZ SnapKat 1.7 kernel with Synapse = DynamicFSync , OC 2.88GHz, .....see github compare Rev1.7
- Xblasted added again (If you want to use the 32 different battery % icons you need to set at "stock" in Xblasted)
18 février 2014 - v1.3 :
- Fix Google sync and playstore
- Fix double externalSD in Es file explorer.
- Center clock by default
- CivZ SnapKat 1.6 kernel with Synapse
- 32% Battery Icons (tap the battery icon in statusbar 3x to open the change menu) Using Xblasted Xposedmodule will override this mod and no battery Icon will be shown until you select one in the xposed module
- Removed some xposed modules like Xblasted
17 février 2014 - v1.2 :
- KOT49H.N9005XXUENB3 base
- InktEffect
- Apps/busybox updated
- CivZ SnapKat 1.5 kernel with Synapse
- Arome option to install stock kernel or custom
- EFS automatic backup when you install the rom
- Terminal command to change bootanimation = stock or csutom
18 janvier 2014 - v1.1 :
- 4 Way reboot menu added
- ExternalSD R/W bug fixed
- MMS/SMS mods
- Apps updated
- Some more stuff moved to aroma
- Enabled all angle rotation in framework
16 janvier 2014 - v1.0 :
- First release Rev1.0
- New kernel engine rev2.7: New Frequency table with max speed 2.55GHz
- Faux123 sound control
- Powersuspend driver updated
- Led control (synapse, app included) by yank555
- mdnie control (synapse, app included) by Whathub
- Touch To Wake rev1.2 by yank555
- New Terminal command , see command list.
- Apps updated
26 décembre 2013 - CivZ-FLEXDREAM-Rev2.1_MultiRegion + Engine Rev2.5 :
- New kernel engine rev2.5: New Frequency table with lower dafault voltages & new OC Frequencies: 2.41GHz & 2.53GHz , removed the 2.49GHz frequency
- Faux1234 Voltage control allowing 12.5mV steps.
- Minimum Undervoltage is now 600mV & Max voltage is now 1100mV which is stock max voltage.
- Updated Intellidemand governor | Faux 1234
- CPU boost driver added
- Removed KNOX from aroma asI believe it is not needed in a custom rom.
- OTG USB helper replaced with Paragon NTFS HFS & tested on my 750GB ntfs HDD and working.
- Apps updated
- Aroma script changed back to previous version
- Update REV2.5 Source tarbal
22 décembre 2013 - CivZ-FLEXDREAM-Rev2.0_MultiRegion + Engine Rev2.4 :
- New kernel engine rev2.4: New Frequency table with lower dafault voltages - UC to 96MHz possible
- Dynamic FSYNC with Async @ Faux 1234
- New Powersuspend driver @ Faux1234
- Rom based on MK2 release
- New battery icons added
- Odex script added
- Apps updated
- Aroma script changed for clean install or dirty install, please take time to look at all the options when installing the rom.
- Main goal of kernel and rom are stability / user friendly / battery friendly.
- Kernel is now set at "Permissive" status by default, you can change it to" Enforced" with the terminal command.
- Source tarbal
06 décembre 2013 - CivZ-FLEXDREAM-Rev1.4_MultiRegion + Engine Rev1.9 :
- New kernel engine rev1.9: Unused clockspeeds removed, new patches, Intillidemand governor added (@ Faux123)
- All apps that can be moved to data are moved to data/apps (google apps and some samsung apps) , this way there are never 2 the same apps on the system (system/app and data/app) and you save up to 150-250Mb of storage. And you get the flexibility to easily remove them if you don't wan't the apps.
- Updated apps
- Source tarbal uppdate to 1.9
30 novembre 2013 - CivZ-FLEXDREAM-Rev1.3b_MultiRegion + Engine Rev1.8 :
- New kernel engine rev1.8
- New terminal command to change SELinux state.
- Kernel code cleaned up = easier for me to change and to follow my changes; working on Github so expect it the following days.
-Trickstermod supported and included in the rom from now on as this is the recommended app to control the kernel. Don't forget to disable KernelTuner!
- Experimental; cifs enabled but still in testing as mounting on Android 4.3 is still a problem: DON'T report this as a bug!
29 novembre 2013 - CivZ-FLEXDREAM-Rev1.2b_MultiRegion + Engine Rev1.6 :
- New kernel engine rev1.6; ExFat problem fixed.
- Tarball kernel source updated to rev1.6
28 novembre 2013 - CivZ-FLEXDREAM-Rev1.2_MultiRegion + Engine Rev1.5 :
- Bug fix for the video player
- New kernel engine rev1.5; various fixes.
- Tarball kernel source updated to rev1.5
28 novembre 2013 - CivZ-FLEXDREAM-Rev1.1_MultiRegion + Engine Rev1.5 :
- Updated lib files for stability
- Updated apps
- Ink effect enabled without the use of spen
- SMS/MMS mods included in apk (forgot this on rev1.0)
24 novembre 2013 - CivZ-FLEXDREAM v1.0 + Engine Rev1.4 :
- Initial Release
- Based on JSS15J.N9005XXUDMJ7
Téléchargements
CivZ_FlexKat_Rev2.5 + SneakyKat_Rev1.5 [XXUEND5] - Lien 1
CivZ_FlexKat_Rev2.5 + SneakyKat_Rev1.5 [XXUEND5] - Lien 2 (Miroir)
(MD5 : F08577F7CF4D957C901313A89C20788C)
Spoiler :
CivZ_FlexKat_Rev2.1 + SnapKat_Rev2.4 [XXUENC2] - Lien 1
CivZ_FlexKat_Rev2.1 + SnapKat_Rev2.4 [XXUENC2] - Lien 2 (Miroir)
(MD5 : D75A175E1263EFBC75EC4A7BE7EDAD2E)
CivZ_FlexKat_Rev1.9 + SnapKat_Rev2.2 [XXUENB7] - Lien 1
CivZ_FlexKat_Rev1.9 + SnapKat_Rev2.2 [XXUENB7] - Lien 2 (Miroir)
(MD5 : a14e71785149c30aa2ccea31b7abc6a9)
CivZ_FlexKat_Rev1.8 + SnapKat_Rev2.1 - Lien 1
CivZ_FlexKat_Rev1.6 + SnapKat_Rev2.0 - Lien 2 (Miroir)
(MD5 : 68BD1AC1CF430D154BCD574714F40CF0)
CivZ_FlexKat_Rev1.6 + SnapKat_Rev2.0 - Lien 1
(MD5 : 681D2E88A9020C75CD0D61300B26C818)
CivZ_FlexKat_Rev1.5 + SnapKat_Rev2.0 - Lien 1
CivZ_FlexKat_Rev1.5 + SnapKat_Rev2.0 - Lien 2 (Miroir)
(MD5 : ECF366D4D395EC4D260EB40E1441A113)
CivZ_FlexKat_Rev1.4-SM-N9005-4.4.2
(MD5 : A23A41D7A88D735C3DF44243449B119E)
CivZ_FlexKat_Rev1.3-SM-N9005-4.4.2
(MD5 : 6604DF3A20A4675AF7FF9D2E6D6665FA)
CivZ_FlexKat_Rev1.2-SM_N9005-4.4.2
(MD5 : 6D637CFB55C263FB9EC939A8E1BE5075)
CivZ_FlexKat_Rev1.1-SM-N9005-4.4.2-signed
(MD5 : 76EFA6CABD55D173CB8ACF6E2C8F9B28)
CivZ_FlexKat_Rev1.0-SM-N9005-4.4.2-signed
(MD5 : 8853DA398D0785EA1D1F87AD5F446092)
CivZ-FLEXDREAM-Rev2.2_MultiRegion + Engine Rev2.7 - Lien 1
CivZ-FLEXDREAM-Rev2.2_MultiRegion + Engine Rev2.7 - Lien 2 (Miroir)
(MD5 : 9EDD4F9FE190281298593547BBB9F80A)
CivZ-FLEXDREAM-Rev2.1_MultiRegion + Engine Rev2.5 - Lien 1
CivZ-FLEXDREAM-Rev2.1_MultiRegion + Engine Rev2.5 - Lien 2 (Miroir)
(MD5 : 5c0742e18fc266cab8834c3a0179b1cc)
CivZ-FLEXDREAM-Rev2.0_MultiRegion + Engine Rev2.4 - Lien 1
CivZ-FLEXDREAM-Rev2.0_MultiRegion + Engine Rev2.4 - Lien 2 (Miroir)
(MD5 : 9917E87F796218F746353FED7A583BF9)
(MD5 : f8379a390d0e59deaffba1d51058cd76)
CivZ-FLEXDREAM-Rev1.3 - Lien 1
CivZ-FLEXDREAM-Rev1.3 - Lien 2 (Miroir)
(MD5 : 217f36eb372bf840c5ca4db3dae22aef)
CivZ-FLEXDREAM-Rev1.2b - Lien 1
CivZ-FLEXDREAM-Rev1.2b - Lien 2 (Miroir)
(MD5 : 1e79b5f9405fa3cfd93c17cd9d42f50e)
CivZ-FLEXDREAM-Rev1.2_MultiRegion + Engine Rev1.5 - Lien 1
CivZ-FLEXDREAM-Rev1.2_MultiRegion + Engine Rev1.5 - Lien 2 (Miroir)
(MD5 : 38c1f43b65293aa43f4e6de4e84747ab)
CivZ-FLEXDREAM-Rev1.0-SM_N9005.zip
(MD5 : b7d273a24d7e95d0eed2cf9451ce88cd)
