description[SGN3][ROM 4.4.2][SM-N9005] [TW] NF4 MultiX v2.2 | Multi DPI & CSC | Aroma | KNOX 0x0 |  Samsung Galaxy Note3 Empty[SGN3][ROM 4.4.2][SM-N9005] [TW] NF4 MultiX v2.2 | Multi DPI & CSC | Aroma | KNOX 0x0 | Samsung Galaxy Note3
[SGN3][ROM 4.4.2][SM-N9005] [TW] NF4 MultiX v2.2 | Multi DPI & CSC | Aroma | KNOX 0x0 |  Samsung Galaxy Note3 Spoiler_MultiX_v22Thread
Le créateur de la rom tkari4
  • AROMA Installer (for almost fully customization)
  • Base: KOT49H.N9005XXUFNF4
  • Modem: not included
  • Stock N9005XXUFNF4 kernel & Lean hlteeur-kk-v3.7 & CivZ-KK_Xplorer-Rev1.8 & Ultimate kernel v.66 *
  • Display languages:
    Spoiler :
  • Call recording can be enabled or disabled *
  • Messaging app hacks: displaying sent time, sms 100 recepients, SMS to MMS auto-converting increased
    Auto convert sms to mms after 7 sms; folder view & save-restore messages enabled
  • OS Scrolling cache disabled
  • Lock screen rotation *
  • Exit menu to stock web browser & home option *
  • Camera flash usable under 15% battery level
  • Disable or enable messaging log in call log *
  • Speedmeter in status bar with toggle in display options
  • All apps enabled in multi & in pen window
  • Note 3 & S5 TW launcher *
  • Launcher rotation *
  • Imaged battery in the statusbar *
  • 3Minit Quicklaunch on notification panel *
  • Disable signature verification *
  • Multi instance *
  • OGBattery Mod *
  • ExtSdCard write issue fix *
  • Call / message block enabled in device settings
  • App Ops enabled in general settings
  • Search window removed from the top of the settings pages can be found in general tab as button
  • Find my mobile & Reactivation lock removed from the settings
  • Launcher themes: Stock Note 3 KK; Stock Note 3 JB; S5
  • Accuweather widget stock Note 3 & S5 *
  • Optical reader *
  • Selectable languages for Optical reader: Brazil; Bulgar; Chinese; Czech; Danish; Dutch; English;
    Estonian; Finnish; Flemmish; French; German; Greek; Indonesian; Italian; Japanese; Korean;
    Norwegian; Polish; Portuguese; Russian; Spanish; Swedish; Turkish; Ukrain
  • Included offline Samsung keyboard files: ar; az; bg; cs; da; de; el; en_us; en-gb; es; fa; fi; fr; hi; hr; hu; hy; id; is;it; ka; kk; ko; mr; ms; nb; nl; pl; pt; ro; ru; sk; sl; sr; sv; th; tr; uk; ur; vi; zh; *
  • Included TTS voices: DE; ES; FR; IT; JA; KO; PT; RU; US; ZH *
  • Included SVOX voices: GB; PT *
  • Hacked Flash player & Dolphin browser *
  • Camera Shutter Sound Menu enabled
  • Sending MMS forced
  • Flaslight quick settings toggle added
  • Download booster (nativ in FNF4)
  • Kids mode installer (nativ from FNF4) *
  • New camera mode Virtual tour (nativ in FNF4)
  • Quad view in multi window enabled
  • Hidden power button under the clock (only if in extras imaged battery mod selected) *
  • Finger Ink effect enabled on the lock screen
  • 4 way reboot*
  • S5 Photo editor *
  • Download booster Note 3 themed
  • Multi Dpi Playstore (all apps visible)
  • Option in Aroma for disable Magazine Home in stock TW Launcher
  • PullUp for stock TW launcher, start what you want at the bottom (as Aroma option)
  • Included CSC:
    Spoiler :
  • KNOX removed
  • Favorite & Moile Wi-Fi hotspot enabled
  • Lockscreen shortcuts are enabled for German & Austral users
  • Spell check (Google keyboard must be installed) *
  • Theme settings under Personalization in Settings
  • One Hand scale app from S5
  • Safe volume warning removed
  • Skip track with volume button mod added (Settings / Sound / Device)
  • Google L theme included for TW launcher
  • Viper4Android *
  • MultiX or Stock theme *
  • 4 Theme for multiwindow launcher (Stock, JB, Black, Transparent) *
  • Icon selection for Settings (Stock, Grey, None) *
  • Black wallpaper in wallpaper chooser
  • 4 kind SystemUI: stock, with imaged battery, with OGBattery, special edition from meawww & OGBattery *
  • Selectable notification panel background opacity: 100, 75, 50, 0 *
  • Selectable quick settings toggle color: blue, green, white *
  • Selectable quick settings toggle background: blue, transparent *
  • Disable ascending ringtone *
  • Frequently updated Google apps are moved to data/app
  • Quick pin/password unlock mod *
  • Default animation speed is set to 0.5
  • CSC features in Aroma installer: Secondary symbols, Call button to contacts,
    Disable TW launcher tilt animation, LTE status bar data icon
  • Xposed proof others.xml & feature.xml (use the options in Aroma installer)
  • Multi Dpi Playstore 4.9.13 included
  • UpdateMe 2.0.3 *
  • Screen Mirroring with custom kernel
  • Ac3 audio support
Images et Vidéos
[SGN3][ROM 4.4.2][SM-N9005] [TW] NF4 MultiX v2.2 | Multi DPI & CSC | Aroma | KNOX 0x0 |  Samsung Galaxy Note3 480_dpi
[SGN3][ROM 4.4.2][SM-N9005] [TW] NF4 MultiX v2.2 | Multi DPI & CSC | Aroma | KNOX 0x0 |  Samsung Galaxy Note3 360_logo_2_small_text
Installation
Pré-requis :
- Avoir installé la rom stock Android 4.4.2 [ROM 4.4.2][SM-N9005] Pre-Release Rom Stock Samsung Android KitKat 4.4.2 [XXUENA6]
Installation :
1) Important : Faîtes un Backup EFS (IMEI) via ce tuto [OUTIL][SM-N9005] Backup et Restore EFS (IMEI) pour le SGNIII
2) Démarrez dans le Recovery custom CWM Android KitKat 4.4.2 en maintenant les touches "Volume +", "Power" et "Home" et vérifiez que vous avez la dernière version via ce Regroupement.
3) Faîtes un NANDROID Backup via le Recovery en allant dans "Backup et Restore/Backup" ou "Backup et Restore/Backup to External SD".
4) Faites le "Wipe Data Factory Reset", "Wipe Cache Partition" et dans "Advanced", le "Wipe Dalvik Cache" via le Recovery.
5) Ensuite flashez la ROM.
6) Enfin redémarrez et amusez-vous  Very Happy
Activer le débogage USB :
1) Aller dans "Paramètres/Général/A propos de l'appareil".
2) Tapez 7 fois sur "Numéro de version", un message apparaîtra en disant que "le mode développeur a été activé"
3) Allez dans "Paramètres/Général" et vous verrez au-dessus de "A propos de l'appareil" le nouveau menu "Options de développement".
4) Allez dans ce menu et vous allez pouvoir activer le débogage USB cheers
Changelog
MultiX v2.2 release date: okt.24 .2014
Quote:
  • KNOX is back can be selected from Aroma (should work for 0x0 users)
  • Superuser & busybox (root) added as Aroma option (installation with _alexndr 's script)
  • S5 launcher removed
  • Odexed like the original Firmware
  • Encrypt device option is working
  • Force MMS as an Aroma installer option
  • Home and exit CSC feature as Aroma option, because stock odexed Samsung browser included
  • Google Videos app install location moved to data/app
  • All apps updated
V2.0 :
Install instructions: Only for international N9005
If you are on Jelly Bean (4.3):
  • Must flash the KitKat bootloader first!
  • The easiest way is ODIN v3.07 download stock 4.4.2 firmware from sammobile.com and flash it.
If you are already on Kitkat (4.4.2):
  • Root your phone with CF-Auto-Root
  • Flash Chenglu's CWM recovery
  • Go to CWM recovery (press and hold Home+Volume up+Power button)
  • If you want backup your current Rom.
  • Start the installation
  • Wipe method can be selected in the included Aroma installer, so wipe in recovery not needed.
  • Select what you want to install
  • Start the install
  • If the installer finished reboot
    Attention with the method above no more warranty (KNOX will be changed to 0x1)
Téléchargements
MultiX v2.2:XDA Server ; Wuala ; MEGA
MD5: e9908c30d63686561240098914e74218
MultiX v2.0:XDA Server ; MEGA ; Firedrive ; Google Drive
[b]MD5:
b38b930ba4b34986e144a67a42fd469e
_______________________________________________
MODEMS CLICK HERE
BOOTLOADERS CLICK HERE
[/b]
description[SGN3][ROM 4.4.2][SM-N9005] [TW] NF4 MultiX v2.2 | Multi DPI & CSC | Aroma | KNOX 0x0 |  Samsung Galaxy Note3 EmptyRe: [SGN3][ROM 4.4.2][SM-N9005] [TW] NF4 MultiX v2.2 | Multi DPI & CSC | Aroma | KNOX 0x0 | Samsung Galaxy Note3
Réserved Wink
je l'ai essaye y a 10 jours et elle tourne bien mais y a trop d'options et d'apps installees pour moi mais je me suis base sur sa rom pour recuperer les apps multi-DPI....
Merci pour le retour Wink
multi 2.2 sortie.....version odex mais custom
Merci pour l'info, Post1 mis à jour Wink
