[MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015]
+5
taz80
gsm0607455890
snach21
9 participants
description[MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015] Empty[MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015]
Voici un pack de "mods" pour les roms en Sense sous Lollypop (dont le mode silencieux) que nous devons à Lyapota.
Merci à lui pour tout ses travaux... Very Happy
  • longpress backkey kill app
  • advanced power menu
  • menu navbar persist
  • battery %
  • change navbar size (48/42/36/32 dpi)
  • sweep 2 sleep
  • kernel tweaks
  • build.prop tweaks
  • clean all recent apps for Google card view style
  • remove search bar from recents
  • centered clock
  • right corner pulldown qs
  • 15 tiles qs
  • disable exchange security
  • display DPI (480 | 440 | 420 | 400 | 370 | 340 | 300 | 200)
  • recent apps button (Settings->display)
  • Prism menu
  • Flashlight QS Tile
  • allow prism landscape
  • increase volume steps (20 for media, 7 for others)
  • system tweaks (hide alarm notify | hide bluetooth notify | hide headphones notify | hide volume notify | hide gps notify | hide clock | hide am/pm | hide nfc icon | hide power saver | clean data cach)
  • data trafic indicator (white | blue | pink | red | green | yellow)
  • longpress volume key (show ambient display | Dwn play(pause)/Up skip to next | Dwn skip to previous/Up skip to next )
  • ambient display (Settings->display)
  • enable 2G only option
  • enable music channel
  • double tap to sleep status bar
  • support voice recording (HTC Dialer -> in call menu, after connection) (start autorec incoming | start autorec outgoing)
  • big caller photo
  • hide battery (always show | hide with label enabled | always hide)
  • flashlight on power longpress
  • disable mask caller photo
  • HTCClock on clock click in header
  • sound effect (S-OFF) (Harman/Kardon | Boomsound)
  • infinity folders
  • fast unlock (password | pin)
  • keyboard volume control cursor (vol+ left/vol- right | vol+ right/vol- left)
  • ambient display params (duration | brightness)
Images
[MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015] Attachment  [MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015] Attachment  [MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015] Attachment
Installation
Vous devez être sur une rom en base 4.16.401.10 /4.16.401.9 / 4.16.1540.8...
Flasher le zip dans twrp
rebooter
  • ajout des derniers Sense Home et HTC LockScreen (without S.ROM yet)
versions antérieures :
#001
Ported to Sense 7 ROM Base
old one :
Pour Sense 7, attention différents packs en fonction de votre version d'Android
modPack #010 (5.0.1)
modPack #010 (5.0.2)
Pas en version Sense pour l'instant.
modPack #009 (5.0.1)
modPack #009 (5.0.2)
modPack #009 (5.0.2 S.ROM)
Versions antérieures :
Pour Sense 6 lyapota_Lollipop_Sense_ModPack_012.zip
md5: e635e5e8769132bbd16551a023d8f660
LeeDrOiD tweaks app
InsertCoin Control app
Source sur Xda
description[MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015] Empty[HTC ONE M8][MOD][Jan 19] modPack for HTC Sense ROM | Android 5.0.1 | Base 4.16.401.9 LOLLYPOP [OM8]
Réserved Wink
description[MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015] EmptyRe: [MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015]
Post1 mis à jour Wink
Post1 mis à jour [MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015] Icon_wink
Bonjour,super sa Wink
Je chope et case twrp Very Happy
Merci bon dimanche
Bon flash smile
Post1 mis à jour
Salut,nouvelle maj Wink
changlog
# 009
Script arôme réécrite (les permissions)
Ajouté
linker patché fichier binaire
clair tweak de cache de données (dirs de cache local claires pour les applications sur le redémarrage du système)
:merci:  pour l'info, post1 mis à jour Wink
Bonjour, super merci beaucoup Wink
Super mod Very Happy
:merci: cela va en faire patienter quelques uns en attendant Xposed
Salut, si xposed vois le jour sur lolipop, c'est pas gagner...
Il semblerait que le dev ait envie qu'il fonctionne....Il a juste annoncé qu'il ne donnerais pas de date et qu'il ferais ca à son rhytme
Salut, maj Wink
et deviner qui remercie.... Miga...
[MOD HTC ONE M8] modPack for HTC Sense 6 ou Sense 7 ROM | Android 5.0.1(2) | Base 4.16.401.10 [11/05/2015] 216290Screenshot20150215172345
Very Happy
ça ne fait pas un peu doublon ça avec la Viper ?
Non je ne crois pas, car y a des mods qui n'y sont pas, comme fermer la liste des applications ouvertes d'un seul coup et d'autres
est ce que c'est paramétrable ou ça te mets tous les tweakss d'un coup ?
jai pas envie d avoir l horloge au milieu par exemple (même si je sais ou régler dans venomtweaks)
Bonjour a tous je suis actuellement sur l'insercoint 6.0.6 lollipop et lorsque je flash ce mod les icones de ma navbar change!
Il redevienne comme sur la version kitkat !
Quelqu'un peu me dire si il y'a un moyen d'éviter cela?merci a tous
Merci pour le partage et merci à Lyapota pour ces mods !
Pour avoir accès à la fonction "clean all recent apps for Google card view style", il faut aussi installer d'autres paramètres non sélectionnables parmi toute la liste optionnelle. Cela supprime l'utilisation du Quicksettings et du Quick Launch dans la ROM ViperOneM8 4.2.0 (ça a supprimé aussi quelques options du menu "Options du téléphone" quand on reste appuyé sur le bouton POWER) .
Dommage, c'est la seule fonction qui m’intéresse dans ce pack ...
Avec un peu de chance cette fonction sera intégrée dans la 4.3.0 !
Salut a tester a mon avis en rom root et stock ..
Je lais tester sur la viper ma merder ma config,j avait pas fait gaffe ..
Pour le bouton 'fermer les applications" elle y est sur la viper sauf faut aller dans venom hub/addons/other/clear alla recent app..installer redémarrer et bingo bay
Salut,ok désolé j'étais pas aller aussi loin dans les reglages de la viper
Tant mieux si tu as réussi coté viper à trouver l'option,mais toujours un backup lors d'un flash d'un zip mod,car sa bugue parfois Wink
depuis des lustres avec les vipers il n'est pas vraiment utilise de rajouter des mods
elles sont tellement customisables que le plus dur et de savoir ou trouver quoi
mais on y trouve toujours tout
en ça le travail d'Alexeandreou pour les traductions est vraiment utile
Salut GSM tout à fait le plus dur est de trouver Wink
Big merci à Alexeandreou pour son job fort utile Wink
