[ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08]
+19
HaaSarD
macadam21
mhsc
Poussinou
DmL
pimoos57
azur1974
rayman95
voileuxcool
oxbo
tribalz.
fred46lot
brolee93
tchitchi
ThierryD37
23 participants
description[ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08] - Page 6 EmptyRe: [ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08]
poste 1 et 2 mis a jour !
nouvelle rom V19C5 core 23534
HD2 ROM V19C5 (Core 23534) ★ OS 2.07.531
http://rapidshare.com/files/35067102...5008.2_WWE.rar
Link HOTFILE:
Upp...
Password: PhamQuang
impossible a charger pour le moment
pas de retours
charge flash demain
EDIT : apres 1 jour d'utilisation pas mal mais entre la evo 1.3 ou celle la ?????
par contre je sais pas si c'est la radio ou la rom mais la conso est tres raisonnable
ROM WM6.5 2.07.531.20C5 - HTC HD2 (Leo)
=== CE OS 5.2.23530 Build
23530.5.5.0
WM6.5 ROM Version V20C5 for HTC HD2 (Leo):
- Based on OS from ROM Leo: 2.07.531.6 WWE TMOUS (NEW)
- OEM from ROM 2.07.531.6 WWE TMOUS
- Manila 2_5_20113626_0
- Build: 23530.5.5.0 group COM5
CHARACTERISTICS OF V20C5 (Core 23530):
- V20C5 with Core 23530 runs pretty fast speed, nice interface and
stability. Function is a stub.
- Use new 2_5_20113626_0, supports both Lanscape screen (horizontal) is
very good.
- Integrated multi-language system fonts (and pretty good TV show) and
with a number of applications other support.
- Integration V20C5 ROM attached 2.08.50.08_2 Radio, the only 576Mb of
RAM.
- Edit icon system register and compact for easy use.
- Integration Office Mobile 2010.
- Integration of MaxManila author Maxycy (XDA) with a lot of great
custom. Thanks Maxycy! Default Manila will not automatically rotate, but
it could be to customize the menu if you want to turn the dial your own
Manila.
LINK TẢI ROM V20C5 (Core 23530 & OS 2.07):
* Link RAPID:
CLICK HERE TO DOWNLOAD
* Link HOTFILE:
Password: PhamQuang
oups j'ai loupé de la maj [ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08] - Page 6 Icon_sad
il faut dire aussi que cette rom est jamais ou presque sur la 1ere page !
je vais la mettre a jour [ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08] - Page 6 Icon_wink
poste 1 mis a jour !
  • HD2 ROM
    V21C5 (Core 23540) ★ OS 2.09.531 (NEW)
  • LINK TẢI ROM V21C5 (Core
    23540 & OS 2.09)
    * Link RAPID:
    * Link MEGAUPLOAD:
    * Link HOTFILE:
    Password: PhamQuang
je ne trouve pas le poste sur xda pour mettre a jour [ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08] - Page 6 Icon_sad
édit: poste 1 mis a jour !
  • HD2 ROM
    V22C5 (Core 23540) ★ OS 2.10.531 (NEW)
Password: PhamQuang
merci rayman pour l'info,le poste sera a jour ce soir !
et hop ca continue
  • HD2 ROM
    V22C2 (Core 21891) ★ OS 2.10.531 (NEW)
Password: PhamQuang
rom 23C5
]LINK TẢI ROM V23C5 (Core
23541 & OS 2.10)
[/size]
ROM WM6.5
2.10.531.22C5 - HTC HD2 (Leo)
=== CE OS 5.2.23540 Build 23540.5.5.0 ===
HD2 ROM V24C5 (C23541) ★ OS 2.10 (NEW)
ROM WM6.5 2.10.531.24C5 - HTC HD2 (Leo)
=== CE OS 5.2.23541 Build 23541.5.5.0 ===
http://hotfile.com/dl/30599976/65d653c/LEO_2.10.531.24C5_B23541.rar.html
poste 1 mis a jour [ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08] - Page 6 Icon_wink
HD2 ROM V25C5 (Core 23542) ★ OS 2.10
(NEW)
ROM WM6.5 2.10.531.25C5 -
HTC HD2 (Leo)
=== CE OS 5.2.23542 Build
23542.5.5.0
http://rapidshare.com/files/358836257/LEO_2.10.531.25C5_B23542.rar
HD2 ROM V25C2 (C21895) / V26C5
(C23544) ★ OS 2.10 (NEW)
]LINK TẢI ROM V25C2 (Core 21895)[
]CLICK HERE TO DOWNLOAD[
]LINK TẢI ROM V26C5 (Core 23544)[
]CLICK HERE TO DOWNLOAD[/
HD2 ROM V27C5 (Core 23545) ★ OS 2.10 (NEW)
http://rapidshare.com/files/361856067/LEO_2.10.531.27C5_B23545.rar
vu que ca interesse personne je signale juste la sortie
ROM WM6.5 2.10.531.28C5 - HTC HD2 (Leo)
=== CE OS 5.2.23547 Build 23547.5.5.0 ===
]LINK TẢI ROM V28C5 (Core 23547 & OS 2.10)[
poste 1 mis a jour!
  • HD2 ROM V29C2 (Core 21896) ★ OS 2.10
    (NEW)
[ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08] - Page 6 Topbanner ]LINK TẢI ROM V29C2 (Core 21896)
Upp...
  • HD2 ROM V30C5 (Core 23551) ★ OS 2.10 (NEW)
  • http://rapidshare.com/files/368708707/LEO_2.10.531.30C5_B23551.rar
CARACTERISTIQUES DES V30C5:
Core V30C5 avec 23.551 cycles d\'essais ont été assez stables, amélioration de la vitesse.
Utiliser les nouvelles 2.5_20121412_1 Manille.
Polices * Système intégré de multi-langue (et émission de télévision très bien) et
avec un certain nombre d\'autres applications de soutien.
V30C5 ROM * OS uniquement intégrée.
Pour exécuter la stabilité et la bonne hd2 installer 2.08.50.08_2 Radio.
Utilisation de la radio sans la machine n\'est pas à éviter les accidents, les redémarrages, ...
ROM après, mais aussi pour la RAM 576 Mo paramètre est.
Pour ceux qui d\'abord le système d\'exploitation 2,10 ROM sur la base de
cette note.
Utilisez le modifier une partie des auteurs ACCUEIL Co0kieMonster et Smaberg sur XDA.
Ajouter CHT applications avec Editor pour personnaliser la maison.
Utilisez l\'icône de l\'application de l\'auteur (XDA) DINIK.
Utilisez un nombre de demandes SVIP Tom_codon.
V30C5 Dialpad a été l\'édition et l\'affichage bien.
Interface et d\'autres fonctions que V29C5 V30C5 pas présenté.
Ouaaaaaaaaaaaaaaa le charabia, ça donne pas envie de la flasher [ROM WM 6.5 / WM 6.5.5][WWE][25.04.2010]roms série PDAVIET [PLUSIEURS BUILD ][SPL 2.08] - Page 6 Lol
belle rom,esthetique efficace comme d'hab avec les viets.pas de bugs j'espere que la conso est correcte
continue a tester
edit : pas mal cette rom.ca change des NRG et sternas.bonne autonomie,efficace.
ou est passé le poste de la V30 c5 sur xda ?
