description[NAND/ZIP ICS 4.0.3] ICS GINGERBEAT Boy Alpha Build Based on 2.3.4 [30.01.2012] Empty[NAND/ZIP ICS 4.0.3] ICS GINGERBEAT Boy Alpha Build Based on 2.3.4 [30.01.2012]
This is a Gingerbread Source modified Rom. You will taste this icecream with the help of GingerBEAT boy !!
Its upto you.. you will decide wether this is a Icecream or Ginger !! you will call this ICS GINGERBEAT boy
This Rom is based on Gingerbread sources with Tytung v14 kernel
THE MAIN DIFFERENCE FROM EVERY ICS Rom IS THAT THIS Rom has special tweaks option wer u can allow the theme to change entirely without any lose of data.. but there is only 3 themes available...
But when I get time I'll work in more theme updates...
BASIC FEATURES:
Android ICS 4.0.3
Tweaks setting
Gingerbread speedup
Voltage menu
Statusbar tweaks
Working Hw patch
Wifi tether
Wifi
camera
Ril (call,SMS,data,3G, etc)
FM radio
Audio
Vibration
Internet speed
Touchscreen
Theme ICS(coredroid theme, MiUi style, Sauve )
Toggle Bar Like one in the MiUi Rom !!
Notification Modified
Power menu added(21/01/2012)
Bluetooth fixed (21/02/2012)
Not working :
SMS forward selection
Reboot
USB port
Data drops sometime
Statusbar fc
Initial Release Beta will be soon after fixing...
[NAND/ZIP ICS 4.0.3] ICS GINGERBEAT Boy Alpha Build Based on 2.3.4 [30.01.2012] 37716120703051271884616[NAND/ZIP ICS 4.0.3] ICS GINGERBEAT Boy Alpha Build Based on 2.3.4 [30.01.2012] 39893020703074605215616[NAND/ZIP ICS 4.0.3] ICS GINGERBEAT Boy Alpha Build Based on 2.3.4 [30.01.2012] 39369320703063938550016
Installation
30 janvier 2011
Version : Alpha build with most of small bug present
You can use it for daily..
Spoiler :
Le lien pour télécharger la ROM a dû retard.
"I'm too busy with this week bcoz ma sis is got marriage fixed... no broadband connection at home.. I should upload it when I get into a cyber...
Bydway I noticed the system sometime give fc..."
description[NAND/ZIP ICS 4.0.3] ICS GINGERBEAT Boy Alpha Build Based on 2.3.4 [30.01.2012] EmptyRe: [NAND/ZIP ICS 4.0.3] ICS GINGERBEAT Boy Alpha Build Based on 2.3.4 [30.01.2012]
Pour information, le cooker va avoir dû retard pour mettre en ligne la nouvelle version de ça rom.
Il n'a pas de connexion Internet là où il est.
Dès qu'il met son lien, je mettrai à jour le post.
Bonne soirée.
