[ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy
+44
Guantanamo
zepretender
vinc62
Flemzord
kenzozo
JMSVELKOS
brolee93
mickaelkiki
Fabio
scofild
phil10
bibidu13
frederic.tirloir
taxi19240
snach21
GUILLOTES
aloux72
Pepiito83
VTR
jig68
Darkcore
mohican22
jackHD
jifonk57
tchitchi
yamrr1
jejehtc
davfunk
cscscs
jeanmi971
sebinfamous
Rusherman
zeno
Gizmodu74
guict
alexd83
stynger
Bamlot
claude01
ali htchd2
angelus141083
elfrager
48 participants
description[ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy Empty[ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy
[ROM 4.0.4/XXLRT]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE >[04-10-12]
Hi folks,
it is ICS-Time
Find my ROM here and enjoy (hopefully)
I would like to thank some people:
kalagas for his beautiful theme
nobnut for all his support, his theme and for being a real friend here on xda!!!
Phoenyx for dedicated Rocket-server and setting this all up!!
Mahmood and bangsti for superfast mirrors!
my testers trinev, faouz, ThaiDai, alex22808, xaoc747
Derniers changements
Changelog ROCKET ROM-V12-XXLRT:
based on official XXLRT Firmware
Modem XXLRK
deodexed, zipaligned and rooted by me
Kernel Notecore 14.1 NO OC (thanks gavin)
new Dark Theme based on trinevs beautiful work!!! (screenshots in post #2) --> you have to enable battery percentage in 'Settings-Display' to show battery percentage!!!!
added multiple CSC-Files
added extended Settings Menu with additional settings: FastDormancy Toggle/QuickPanel/CPU Spy/CPU Monitor/CSC change/SecretCodes (Thanks to Crash 1976 !!!)
fixed CRT-Off Animation
4 Way Power Menu included
Full SIP (VOIP) support
native Call-Rec
added TW-Launcher from Goa (lots of you like it....)
AppWidgetPicker added
15 Toggle-MOD (thx to wanam!)
SVoice-App SGS3 (no homebutton lag!)
Rolle Tube (for downloading vids on youtube)
modded SMS-App (No contact limit + No MMS convert + Sent time shown instead of received time)
added no ascending ringtone
transparent Weather Widget
services.jar patched for using supercharger scripts
updated host-file to block ads
LiveWallpapers Galaxy S3
Swype included
Google keyboard included
Auto BackUp EFS / sdcard / efs.autobackup.img
added Playstation Certification
added BEATS Audio (thx Awesome!)
added Sony Walkman Player
added Bravia Engine (doubt it helps lot, but does not harm ...)
lots of improvements for speed and smoothness!!!
Anciens Changelogs :
ROCKET ROM - v12
Mirror 1 - ROCKET ROM - v12
Mirror 2 - ROCKET ROM - v12
Mirror 3 - ROCKET ROM - v12
HOTFIX for S Memo-App
Installation
--> IMPORTANT: First boot (after FullWipe!) may take up to 5 minutes! FullWipe recommended, but not necessary if coming from RR v10 or v11 (see installation instruction)
Installation instructions:
a) coming from a rooted GB-ROM:
- download Abyss Kernel 4.2 from here: http://www.mediafire.com/?c65mndvpk6ocbaa
- put zip-file on your USB-storage
- boot in Recovery
- Flash Abyss Kernel 4.2!!!
- FullWipe
- Flash ROM
- reboot system
- ...you are done
==> there have been reported problems with a constantly rebooting system when doing installation coming from a GB-ROM as posted above! So the safe and 100% successful way is installing LPY Stock-ROM, root Stock ROM and then go on as described below under point b2). Do not ask for a tutorial on how to install and root LPY Stock ROM....it is describe enough here in Forum!
b1) coming from RocketROM v1 - v4_1 or other rooted LPY-ROM or rooted ICS Stock ROM (No Wipe):
- boot in Recovery
- Wipe Caches and Dalvik only!!! Don't FullWipe!!!
- Flash ROM
- reboot system
-...you are done
b2) coming from other rooted LPY-ROM or rooted ICS Stock ROM (FullWipe):
- boot in Recovery
- boot back in Recovery (find it under 'advanced')
- now FullWipe!!!
- Flash ROM
- reboot system
-...you are done
c) coming from Chinese Leak or Derivates with Chinese Leak kernel:
- boot in Recovery
- now FullWipe!!!
- Flash ROM
- reboot system
-...you are done
d) coming from CM9, ROMs based on CM9 or other ICS AOSP ROM:
- boot in Recovery
- FullWipe
- Flash ROM
- reboot system
-...you are done
Nandroid Backup and Restore:
You are able to do Full Nandroid Backups on CF-Root Kernel. But you have to restore them using Abyss Kernel 4.2!!!
If you try to Restore with CF-Root, your Restore will hang up and you will at least lose Root
Known Issues:
some of you may face the Device not getting in Deep Sleep Mode (I experienced this myself, it is a kernel related bug!). Check this with app 'Spy CPU' from market and just follow these instructions here to get rid of it: http://forum.xda-developers.com/show...45&postcount=9
Lien XDA
description[ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy EmptyRe: [ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy
Merci [ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy 750705
tu peu traduire les known issue
Elfrager:
"Bug connus:
* Fermeture forcé lorsque tu essais de changer la luminosité via les paramètres
* FF lorsque tu compose un numéro pour appeler - passe par les contacts à mon avis-
* FF lorsque tu essais de te servir de ton samsung comme modem pour transmettre ta connexion
*Swipe est uniquement en Anglais
*DPS Manager ne fonctionne pas mais tu peux utiliser le Fix"
voili voilou
Lol merci mais sans moi
1 ou 2 versions sont prévues dans la journée.
salut salut ,
je viens d'installer la rom hier mais malheureusement un peu trop de bug, dommage , on va attendre que sa se règle Very Happy
Dans la journée j'espère Wink
espérons car elle ma l'air prometteuse , pour l'instant je vais essayer d'autre rom pour vois se que sa donne
Je viens d'essayer cette version 1.4
Il y a encore de petits bugs mais ça donne un aperçu déjà.... Wink
Vu que je suis loin d'être un pro de l'install, je vais attendre une version complète qui soit parfaitement fonctionnelle.....
Sur la 1.5 les bug on disparu =)
http://forum.xda-developers.com/showthread.php?t=1507265
dl en cours je testera se week end je pense
je suis pas sur de comprendre comment installer la 1.5...
D'abord installer la 1.4 en recovery , apres full wipe , install 1.5 en recovery et full wipe ?
Je comprend pas pourquoi ils parlent de version chonoise full wipe ... Je dois faire une manip particuliere ou je peux directement flasher depuis ma Rom actuelle ?
Si j'ai bien compris :
1- Full wipe
2- flash v1.4
3-full wipe
4- reboot et connexion du compte google
5-vérifier que la rom est bien rootée
6-flash de la version 1.5 sans wipe
7- reboot.
oula c bien compliquer tout sa on vas peut etre rester sur MIDNOTE2.0
Quand tu dis flash c'est via CWM ? pas odin ?
a mon avis c'est full wipe + install 1.4 + full wipe + compte google + install 1.5
si tu termine par un full wipe ca va pas marcher à mon avis [ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy 46891
depuis ta rom actuelle tu peux tenter le full wipe + install V5, mais a mon avis tu t'exposes à des soucis en ne suivant pas le tuto du cooker.
@alexd83
oui, avec CWM en recovery.
angelus141083 a écrit:
Elfrager:
"Bug connus:
voili voilou
S'lut à tous,
Pour tout ceux qui ont comme-moi installé la ROM :4.0.3/XXLP1][Team Rocket ROM v1.4][open beta ICS v4.0.3] sachez qu’après avoir installé la RR v1.4, il est conseillé d'installé la RR v1.5...pour ceux qui veulent bien sur diminuer les bugs, comme par exemple : le réglage de la luminosité, et aussi d'autres améliorations que je vous laisse découvrir; en plus Very Happy connaissant votre curiosité, cela ne manqueras pas de vous réjouir bounce
Route d'un certains bonheur : http://forum.xda-developers.com/showthread.php?t=1507265
Je ne suis pas mécontent d'avoir installé cette rom, en suivant les conseils se trouvant sur la page de ce lien ci-dessus...
Bon'soirée à tous zen Very Happy [ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy 61393
bon on vas essayer de se lancer car très contant de la MIDNOTE2.0 car je suis en mode flasheur fou déjà 4 flash en 3 jours
POST 1 à jour : V1.5
zeno tu a rencontrer des bug pour l instant ?
On attend vos retours les filles [ROM 4.0.4/XXLRT][04-10-12]RocketROM v12 - ICS - 4.0.4 - XXLRT< FASTER and STABLE > Enjoy 61393
j'arrive à installer la 1.4 avec la méthode indiquée.
j'active el compte gmail, reboot cwm install 1.5
l'install commence et bloque assez vite, rien ne se passe ?
je suis revenu en Chrack v14 du coup en restaurant un backup.
pareil v1.4 s'installe puis quand j'installe la v 1.5 ça bloque au niveau de modem flash quelque chose comme ça.. pourquoi faire compliquer? la MIDENOTE 2.0 j'ai réussi a l'installer sans problème.
Je voudrais aussi demander si quelqu'un aurait la solution aussi pour le recovery.. j'installe le kernel abyss 3.9 puis rebot recovery pour avoir les ecriture en rouge et installer mes roms sous 4.0.3 mais a chaque fois quand j'ai installer la rom ça devient bleu..
