Bonjour, je vous présente et partage cette ROM pour le I9300. Suite à la demande du développeur, la mise en page reste la même que sur XDA.
Présentation
Chaos ^_^ a écrit:
The reason I start developing Chaos Rom is to join frameworks, mods, themes, apps, and more in one package to make users' life easier. This Rom includes: - 2 DPI - S4 apps - Stock & AOSP contacts - 3 In Call Screens - 4 themes - 4 Calendar apps - 6 Keyboards & Themes - 6 Sound Packs - 6 fonts - 7 Bootanimations - 4 Icons Packs - 10 Battery Styles - Auto 2G-3G Toggle - and almost every app you want. Hopefully in the feature you will be able to re-install any of these options without the need to re-flash the entire ROM. Hope you guys will enjoy this experience with Chaos World! From now on the base for the ROM will be 4.2.2 Jelly Bean since 4.1.2 is almost perfect now, one update per month would be enough for 4.1.2 for updating Kernels, Themes & apps but no major changes will be.
Sujet XDA.
Autorisation
Chaos ^_^ a écrit:
Originally Posted by Shepp Hello,
I'm a member of "forum-generationmobiles.net" and I shall like very much sharing your work on this forum. Consequently I ask you for your authorization, knowing that the links "sources" will return to the topic of the ROM.
Are you ok ?
Cordially.
go ahead but no changes in main posts and credits
No, of course. I just copy the topic and translates part of installation, but I do not modify the main credits and the post. No problem ?
ya no problem dont forget to but link for xda thread
Based on latest Wanam Lite Rom: Rooted, Dedoxed, Zipaligned, Bloat Removed, Ram Leak Fixed, Remove Email Security, No MMS in Call Log, HD Voice (if network provider support it), AOSP Contacts, Call Recording Enable, Per App DPI activated by default, Auto 2G-3G Toggle, ICS Pop-Up app Chooser,Bravia Engine 3, Lock apps in memory, Call button in contacts (csc), No auto converting messages to MMS (csc), Unlimited contact to sms mms (csc), Exit Button in Stock Brwoser (csc), Extended speed Dial to 100 (csc), and more...
Choisissez entre 4 thèmes dans Aroma :
Elegant Theme :
Spoiler :
HoneyComb Theme
Spoiler :
S4 White Theme
Spoiler :
TouchWiz UX S4 Theme
Spoiler :
Choisir entre 4 fond d'ecran d'appel : White S4
Spoiler :
Xpria Z Style
Spoiler :
Full Screen HD
Spoiler :
Stock S4
Spoiler :
Nottach Xposed v12: By Nottach
Spoiler :
CRT-Off Thanks to criscan Multi Lockscreens (Ripple, Ink Effect, Circle, AOSP, Light Effect) Thanks to Arsaw Long press Menu to kill apps 4 way Reboot MultiWindow Control Status Bar - Status Bar: -Status Bar Background Color -Typeface Family --Regular --Light --Condensed --Thin -Typeface Style --Italic --Normal --Bold Clock: -Clock Color -Clock Size --Small --Medium --Large -Clock Position --Hide --Right --Center --Left -AM/PM Style --Hide --Small --Large -Show Date With Clock Battery: -Hide Battery Icon -Battery Icon (Many Options) -Battery Icon Color -Battery Text Color -Battery Text Suffix -Battery Text Size --Small --Medium --Large Carrier Label: -Hide Carrier Label -Custom Carrier Label -Carrier Label Color -Carrier Label Size --Small --Medium --Large Signal Icons: -Signal Icon Set (Many Options) -Signal Level Bar Count (4 - 6) -Signal Icons Color -Persist Data Icon -Hide WiFi In/Out Status Icons: -Hide Smart Stay Icon -Hide Alarm Icon -Smart Alarm Icon (Many Time Triggers) -Hide NFC Icon -NFC Icon (Many Options) -Status Bar Icon Color Notifications: -Hide WiFi Connected Notification -Hide Input Switcher Notification -Hide Blocking Mode Notification
Notification Panel - -Background Color / Image -Clock & Date Shortcut -Clock & Date Longpress Shortcut -Two Line Date -Header Background Color -Header Button Color -Header Button Divider Color -Title Bar Text Color -Title Bar Background Color -Hide No Notifications Title Bar -Notification Background Color -Notification Pressed Color -Hide Notification Divider Lines -Close Handle Color -Hide Close Handle Divider
Quick Settings - -Quick Setting Tiles Per Row -Quick Setting Toggle Icon Color -Quick Setting Toggle Background Color Option -Quick Setting Toggle Pressed Color Option -Hide Quick Setting Labels -Quick Setting Label Color -Hide Quick Setting Indicator Bars -Quick Setting Indicator Bar Color -Collapse Panel On Toggle -Disable Bluetooth Toggle Pop Up -Disable Airplane Mode Toggle Pop Up -Brightness Slider Icon Torch Toggle -Auto-Brightness CheckBox Color -Auto-Brightness Detail -Remove Quick Setting Toggle Gaps
Framework - Power: -Hide Full Battery Notification -Hide Wireless Charging Dialog -Turn On Screen On Plug/ Unplug Network: -Disable Tethering Provisioning Device: -Enable All Rotations -NFC Behavior --Unlocked --Screen On & Locked --Screen Off & Locked -Device Properties Buttons: -Disable Wake On HOME -Long HOME Behavior --Launch An App --Disable --Recents (Icons) --Recents (Thumbnails) --Launch Google Now -Remove Google Now Button From Recents -Double HOME Button App -Long BACK Kills Foreground App --App WhiteList (All Popular Launchers White Listed By Default)
Applications - Messaging: -Raise SMS Recipient Limit -Raise MMS Recipient Limit -Raise SMS To MMS Conversion Limit -Show Screen On Toggle -Enable Landscape Split Mode In Messaging Option -Enable Message Save & Restore -Increase MMS Size Limit -Increase MMS Image Size Limit Phone: -Disable Increasing Ringtone Email: -Exchange security disable option Multi-Window: -Select Additional Multi-Window Apps -Enable Multi-Instance (Does not work with all apps) -Use Dark Theme Google: -Enable Video Hangouts Over Cellular -Google Wallet Network/ Device Hack
System - -Seekbar Color -Overscroll Color
Advanced - -Show All Activities (Be Aware Not All Activities Will Work) -Quick PIN Unlock (Use With Caution)
App - Save and restore features -Restore defaults or a saved configuration -Unlimited backups, easy theme changes -Long press to delete backups
Choisissez entre deux DPI :
320 DPI & 260 DPI
Choisissez entre plusieurs application :
S4 apps: SystemUI, Contacts, Phone, MMS, Music Player, Gallery, Email, Calculator, Radio, Video Player, Keyboard, Job Manager, Calendar, Paper Artist, S-Memo, Setup Wizard, Wallpaper Chooser
White S4 apps: Contacts, Phone, MMS, Music Player, Gallery, Email, Calculator, Video Player, Keyboard, Job Manager
Extra S4 apps: Samsung Account, S-Translator, S-Voice, S-Health, Samsung Link, Group Play, Smart View
Nexus 4.2.2 apps: Launcher, MMS, Camera and Gallery 4.3, Browser, Clock, PlayMusic, Calendar, Calculator, Gmail, Keyboard, Weather Widget
Xperia Z 4.2.2 apps: Launcher, Album, Walkman, Keyboard, Calendar, Notes, Torch, Calculator, Movies, 4X Video Player, Smart Control,Wallpaper Chooser, Multi Static Live Wallpaper, Widgets.
Mega - Project Chaos v2.3 31/JUL/2013 Utilisez le navigateur Chrome pour la télécharger.
Change Log
Change log du 31/07/2013 :
► Project Chaos v2.3...31/JUL/13 - Add Nottach Xposed app - Fix android.process.acore FC - Fix no Holo AOSP contacts - Fix ROM version in setting about
Spoiler :
► Project Chaos v2.3...30/JUL/13 - Add Nottach Xposed app - Fix android.process.acore FC - Fix no Holo AOSP contacts - Fix ROM version in setting about
► Project Chaos v2.2...29/JUL/13 - Add Nottach Xposed v12 (Working) - Add Full Screen HD Call Screen - Add 260 DPI Stock Contacts app (White still not fit) - Add White S-Translator to White Theme - Add S4 Adabt Sound - Add more Samsung Bloat apps to chose: •Easy Launcher (Added to TW-Launcher) •Samsung Hub •Samsung ChatOn •Trip Adviser - Remove Pure Graphics HD - Update TouchWiz UX 2013 S4 theme to v5.1 - Update All apps: •Play Store v4.2.3 •SuperSU v1.45 •EsFile Explorer v3.0.5.1 •Samsung Push v1.1.12 •GreenFiy 1.92 - Some minor fixes in HoneyComb Theme -Themed Video Player Icon
► Project Chaos v2.1...18/JUL/13 - Remove 3minit framework - Add 2G-3G Auto Toggle app (Need Testing) - Add 1% Battery to Stock S3 SystemUI - Add options to choose (Thanks to Dream Themes): •Status Bar Transparent, Black or mix •Drop Down Transparent, Black or stock •Center Clock or Right Clock •Remove Toggles Text - Add Pure Graphics HD - Replace S4 Clock by S3 - Fix Smart Eye Icon (now only shows while searching for eye) - Fix S4 Multiwindow Text - Update TouchWiz UX 2013 S4 theme to v5 - Update All Icons and Themes: •Themed Clear button •Themed Drop Down Bottom bar •Themed Settings Icon •Themed MMS no Messages Icon •Themed Some TW Text •Themed HoneyComb Toggles
► Project Chaos v2.....08/JUL/13 - Update ROM base to ME7 - Add lockscreen effects - Add option to chose Center or Stock Lockscreen Clock position - Add HoneyComp Themed AOSP Contacts - Removed Group Play
Merci à zedomax et GalaxyS3Root.com pour la video !
Video created by SpriCo from www.youtube.com/spricoproductions !
Based on latest Wanam Lite Rom supported by JKay:
Rooted, Dedoxed, Zipaligned, Bloat Removed, Free Ram, HD Voice (if network provider support it), AOSP Contacts, Custom settings for call recording & Full HD Call Screen photo, Per App DPI activated by default, Lock apps in memory, Call button in contacts (csc), Exit button in the default browser (csc), No auto converting messages to MMS (csc), Unlimited contact to sms mms (csc), Exit Button in Stock Brwoser (csc), Enabled Sub Symbols in samsung Keyboard (csc), Extended speed Dial to 100 (csc), Double Tab to chose app, and more...
JKay 14.95: Check JKay thread for more info and support. Chaos Framework (gharrington & Tamerlan Moded by me): CRT-Off Multi Lockscreens (Ripple, Ink Effect, Circle, AOSP/Xperia) Torch on lockscreen Volume to skip songs Long press Menu to kill apps 3 way Reboot MultiWindow Control Fix Auto brightness Hide or show clock Change clock color, Add AM/PM & Add week day Set status bar color & Drop Down Notification Color Choice of Clock Position in AROMA Choice of Stock or 23 toggles in AROMA lock and recent buttons in Drop Down Bar
Choissisez entre 4 Kernels :
Adam Siyah Boeffla Perseus
Choisissez entre deux DPI : 320 DPI & 240 DPI (Big thanks to bala-gamer)
Nexus 4.2 apps MMS, Camera and Gallery, Browser, Clock, PlayMusic, Calendar, Calculator, Gmail, Keyboard.
Note II apps: Camera, SNote, Paper Artist, Keyboard, Pop-Up Broswerr, SPlaner.
Misc apps: PIE Control, CSC Enabler, Titanium Backup, Fast Dormancy, Nova Launcher, Apex Launcher, Es File Explorer, Greenify, Flahplayer, Multiwindow Controll
Inverted Apps: MMS, Gmail, Playstore, Calendar, YouTube, PlayMusic, Google Now
Mega - Final Chaos Build 2 - 16/JUN/2013 Utilisez Chrome pour télécharger.
File Rio - Final Chaos Build 2 - 16/JUN/2013 Google Drive - Final Chaos Build 2 - 16/JUN/2013 Thanks to ecoach Torrent - Final Chaos Build 2 - 16/JUN/2013 Thanks to galaxys3lover
only if you have any bootloop after choosing AOSP or PIN lockscreen then please flash this En cas de bootloop après avoir choisi AOSP ou PIN Téléchargez et flashez le fix ci-dessous Lockscreen Fix
Change Log
Spoiler :
► Final Chaos Build 2.....16/JUN/13 - Add AOSP contacts (Holo Dark/Holo White) - Add option to chose Contacts app & Contacts Theme - Update Adam Kernel to 2.5 - Fix Titanium backup not installing - re-arrange AROMA installer
► Final Chaos Build 1.....05/JUN/13 - Update Gmail to 4.5 - Fix AOSP 4.2 Keyboard - Fix non-inverted Playstore - some png re-size for sense theme - complete SystemUI theme for sense 5 theme
► Final Chaos Beta.....02/JUN/13 - Update Sense 5 theme (white settings, icons, theme all toggles, more sense framework, and more ) - Update Boeffla kernel to 2.11 - Update all Google inverted and non-inverted apps - Rearrange AROMA options for easier experience - Add option to remove more bloats (Google Now, Talk, Voice Recorder, Gmail, YouTube) - Replace HoneyComb Bootanimation by Blue Bokeh - Fix Boot-loop when using JKay Framework with S4 Theme - Fix installation of 4 Cyl Turbo and more i cant remember now
► Chaos ROM v8.1.....18/MAY/13 - Fix JKay bootloop when change lockscreen - Fix Chaos settings Fc - Add option to enable 4 cyl turbo engine - Add lock and recent buttons to Drop Down Bar in Chaos framework - Update Google Now and PlayMusic to latest versions and more
► Chaos ROM v8.....16/MAY/13 - Update base to MD2 - Update JKay framework to v14.95 - Update JB Domination to v2.0.1 - Update Play Store to 4.1.6 - Update Boeffla Kernel to v2.11 b6 - Update Mms to 4.2.2 - Replace S3 by S4 Theme - Add 4 cycle turbo engine - Add Inverted Google now - Add Greenify app - Add Flashplayer - Add option to choose e-mail and theme - Add option to disable Auto correction for Note 2 Keyboard - Add option to choose SystemUI theme - Add option to choose between ACID, Beats, or Stock sound mod - Add option to choose Multi Window Theme - Add flare lock screen effects to S4 theme - Add Double click home choose between S-Voice and Google Now - Add ICS style default app chooser - Fix S4 keyboard FC - Fix cracking sound in call (hopefully) and more I can't remember
► Chaos ROM v7.2.....22/APR/13 - Fix JKay framework bootloop
► Chaos ROM v7.1.....20/APR/13 - re-write AROMA Script and updater script for better and easier re-flash process - Update JKay to 14.93.4 - Update PlayStore to 4.0.26 - Update Gmail to 4.3.1 - Update YouTube to 4.4.11
► Chaos ROM v7.....18/APR/13 - New Aroma Options, now you can re-install (apps, themes, icons, sounds, bootanimation, fonts, change DPI, re-enable or disable navigation bar, change lockscreen,,,,etc) without the need to re-flash the entire ROM - Update Base to XXEMC3 - Update JKay to 14.93.3 - Update JB Domination to v1.8 - Update Elegant Theme to v6 - Update Xposed Framework and Apps Setting - Update Inverted Play store, Gmail, YouTube (Thanks to Kryten2k35) - Update Persuse Kernel to Alpha 35 - Add option to choose between AOSP, Elegant, Full HD in call screen - Add options to Choose Icons - Add option to choose Calendar and Keyboard Themes - Add AC!D Audio Engine Integrated With Walkman - Add Beats Like Music Player - Add S4 Accuweather - Add S4 S-Voice - Add S4 Translator - Add more Sense 5 icons - Add Note II White Keyboard Theme (like s4) - And more......
► Chaos ROM v6.....9/APR/13 - Update Base to XXEMC2 - Update JB Domination to 1.7.1 - Uodate Elegant Theme to v6 - Update MIUI Theme to v5c - Update JKay to 14.93.1 - Update Xposed Framewor - Update App Settings - Add option to chose from 9 different Battery - and more....
► Chaos ROM v5.....1/APR/13 - Update base to ZSEMC1 - Update SNote to V8 - Update Elegant Theme to v5 - Update Sense Theme to Sense 5 - Update Boaeffla Kernel v2.10 b2 - Update Persues Kernel v34.3 - Update Siyah kernel v1.9.0 - Update all system and user apps - Update Sense launcher and Widget to Sense 5 - Replace Stock Kernel by Adam Kernel - Add MIUI 4 Theme - Add MIUI apps (Launcher, Lockscreen, Music, Camera, Gallery, FileExplorer, Calculator, Clock, Notes) - Add Quick Controls apk (attached with Sense Launcher) - Add PIE Control apk - Add Full HD incoming and outgoing call + Full Customizable Call Recording - Add Small Font - Add MIUI 4 Sounds - Add a simple apk to change Xperia Z LS wallpaper - Add CSC Editor apk - Add Direct Share as an option in AROMA - Add Apex Launcher - Add Xperia Z Email - Add modified Xperia Z Launcher - Add Xperia Like Icons to Xperia Elegant theme - Add Build.prop Tweaks for Battery, Performance, Display, Audio, Wifi...etc - Add option to chose Fonts in AROMA - Add option to chose Sounds in AROMA - Fix FC SecMail - Fix Call recording - Fix DesckClock FC'S when adding new Alarm for 1st time - Fix Arabic language in HoneyComb theme - Fix some of themes issues to fit 240 DPI & Navigation bar - and more....
► Chaos Knights.....11/MAR/13 - Update Build to MB5 - Update JKay to 14.92.9 - Update SNote to V7 - Update SecPhone, now support Bluetooth Headset call recording - Update Stock Kernel to MB5 - Add option to chose Allshre and Samsung account in AROMA - Add Inverted Music Player and Email - Fix Stock clock FC when adding Alarm - Fix SecExchange FC - Fix battery not showing correct percentage - Add Stock Xperia icons and 23 toggles theme to Elegant theme. - Add more stock HoneyComb icons to HoneyComb theme - Remove the ugly blue line from most of apps
► Chaos HD.....3/MAR/13 - Reduce Rom size to 1.1 GB - Update Boeffla Kernel v2.8 - Update Perseus Kernel v33.3 - Add option to chose Bootanimation - Add Xperia Lockscreen for both frameworks, for chaos u can choose between Xperia, Ripple, Circle and ink effect lockscreens (Thanks to Arsaw for Xperia Lock screen) - Fix one % battery mod and clear button theme for all themes - Theme battery in Video player for all themes - Fix first name not showing probably in call log if using soft keys - Theme Xperia soft Keys - Add a call button in contacts (csc) - Add exit button in the default browser (csc) - Add no auto converting messages to MMS (csc) - Add Unlimited contact to sms mms (csc) - Thanks to Tarazan for the great CSC
► Chaos HD Beta.....27/Feb/13 - Downgrade to MA2 more stable with Jkay+JB Domination - Add HD voice (thanks to piguy1982 for the guide) - Add call button in constacts (CSC) - Add Elegant theme - Add Xperia apps - Add Sense clock widget and launcher - Fix honeycomb battery in chaos framework - Update JKay to 14.92 - Update SNote to v6 - TWRP compatible - Fix Allshare FC
► Chaos Theory......20/Feb/13 - Update JKay to 14.91.3 - Update to latest Xposed Framework - Add Glass effect (Transparient Pop-Up) as an option in AROMA (can be applied to all themes) - Add Unlimited Contacts, No MMS Convert, Sent Time to SecMms.apk - Replace JB Domination SystemUI by JKay AOSP Theme Until a new version of JB Domination released - Replace Nexus 7 Bootanimation by Stock Bootanimation (for Stock Theme) - Remove Page Indicator from TW Launcher - Theme in call Dialer to black - Fix search in dialer for contacts (csc) - Fix Note II keyboard Dictionary (chose language u want to use it in swipe from Samsung Keyboard Settings and Download it) - Fix call recording button not removing even if chosen in Custom Settings - Fix JKay with Stock Theme
► Chaos ReleaseD.....15/Feb/13 - Initial Release
[/center]
1.Télécharger Chaos Rom et placez-le sur votre carte SD interne. Si vous flashez de la carte SD externe, veuillez ne pas signaler les problèmes. 2. Démarrer votre téléphone en recovery. 3. Faites un backup de votre ROM actuel !! 4. Selectionnez "Install zip from sdcard". 5. Selectionnez "Choose zip from sdcard" et lancer Chaos Rom. 6. Selectionnez le wipe dans AROMA. Full Wipe c'est toujours mieux. 7. Une fois "done", redémarrez votre Téléphone et Enjoy
Conseils
- Install via latest CWM Touch if you used TWRP you may loose the theme. - If AROMA stucks, reboot and start again. However if the installation process reach the stage "Let Chaos Begin" just reboot. - if you want to re-install any theme, icons, sounds, fonts, bootanimation, Navigation bar or change DPI, Just SKIP installing SYSTEM and SKIP installing APPS - if you want to change apps also just SKIP installing SYSTEM and i do recomend to re-flash Theme and icons - You have to backup your sms because it will be deleted by default and backup your contacts in case you get any android.acore.process FC, then you have to clear contacts and contacts storage data. - For any misalignment in any application in 240 DPI mod (Sense Launcher, Video Player), go to Xposed apps settings and chose the application you want to fix, then go to DPI and set it to 320. - To chose any lockscreen wallpaper make sure to select Samsung Gallery during installation (chosen by default). - If you want to change the lock screen in Chaos framework, go to settings > Lockscreen > Lockscreen options > tick the AOSP lockscreen option (for both AOSP or Xperia Z). - To show time, date, AM/PM, or to change their colors, just navigate to time and date settings. - To set statusbar transparency/color, or drop down transparency/color, navigate to display settings.
Credit
Le développeur m'a demandé de garder les crédits :
This Rom is nothing without this people mods, frameworks, kernels and modded apps, many thanks to all of them: - Wanam - bala-gamer - Vertumus - rovo89 - _JKay_ - gharrington - Tamerlan2009 - gokhanmoral - ThilinaC - Arsaw - ksr007 - AndiP - houssam10001 - AndreiLux - pinguy1982 - Darius_AWS - shahar2k9 - hyperX- - freddy1991 - xlory - mythtrandyr - tarzan11 - ksr007 - leonardoaraujo - galaxys3lover - Kryten2k35 - Gineer roji - XdroidPerfec - fkofilee - and8res - pglmro - titooo7 If I forget somebody please PM me!
Rom Support
If you like Chaos Rom, rate it and add Rom banner to your signature to support it! "
Bonjour, désolé de pas avoir fini la publication. ROM très intéressante. Promis, je me dépêche dès que possible de compléter le sujet.
La ROM me parait très intéressante et je ferais le nécessaire pour la tester au plus vite.
Edit, et voici :
J'y ai passé pas mal de temps, mais pas grave. J'ai réussi à vous la faire partager. Niveau personnalisation, elle à l'air au top. J'ai hâte de l'essayer, moi qui aime tout modifier .
merci pour le partage je la test depuis hier en version 2.1 et aujourd hui en version 2.3 pas mal de petit fc selon ceux qu on installe avec le aroma le mode transparent ne fonctionne pas et occasionne un fc du processus android en tous cas sur la version 2.1 pas testé sur la 2.3
Petite question concernant ton topic, pourquoi y'a-t-il plusieurs fois la même information dans les posts que tu as crée ? Par exemple pour le lien de la rom il est dans le post 1 et le post 2.
Parce que j'avais pas eu le temps de faire le post 2, sachant que le lien de téléchargement sur XDA et dans le post 2. Il est vrai que j'ai oublié de le supprimer.
Ensuite, tout dépend de ce que t'appel plusieurs fois la même information. Mais j'ai respecté au maximum le topic du développeur, suite à sa demande.
De plus, les anciennes versions sont encore disponible d'où des informations un peu identiques, mais j'ai pensé judicieux de tout mettre.
Sinon pour ce qui est de la ROM, elle est en cours test (la version 2.3) depuis hier soir ou ce matin, ça dépend comment vous voyez minuit passé x). Donc je l'ai laissé ce charger toute la nuit.
Première impression :
Je fais déjà un petit retour dès truc qui ce remarque au premier contact. La chose qui ce remarque très vite est cette fluidité @Bias, désolé mais je l'a trouve plus réactif dans ses animations et dans le lancement des tâches que la MIUI. Même lorsque la RAM est utilisée presque à fond. Donc déjà très bien.
Ensuite, personnalisation avec Aroma Installer, bon rien de compliqué, vous installez les différent thèmes/icônes/mods/apps/widget que vous désirez et le tour est joué. Mais le thèmes Xperia est juste magnifique. Moi qui adore personnaliser mon téléphone, je suis pas déçu. De plus elle accroche bien au premier contact. C'est la seule qui arrive à me faire quitter MIUI tellement elle est classe et réactif.
Bon bien sûr, j'ai l'imperium à tester. Je la testerais ASAP.
Pour le reste je ferais un retour plus complet, mais déjà là, c'est du positif.
@mhsc, Après installation de la v2.3, j'ai pas installé la barre des notif transparente, du coup je n'ai aucun problème. Pas de FC ni rien.
A voir ou essayer, si dans la v2.3 cela ce produit encore. Dommage qu'on peut pas modifier le thèmes sans Aroma (j'ai pas eu le temps de fouyer, ça ce trouve c'est possible).
Oh le gros pavé :o
EDIT : Conclusion :
Après trois jours d'utilisation, je suis retourné sur la MIUI.
Alors, ROM plutôt au top niveau autonomie et également en fluidité. En revanche, du moins pour la puissance du S3, je trouve qu'il RAM assez rapidement, lorsque plusieurs applications tourne. C'est surtout lorsqu'on switch d'une à l'autre.
Bug rencontré : Quelque freeze rencontrés lorsque Deezer était lancé. Impossible de descendre la barre de notification. Appui sur le bouton "home", au moins 45 seconde avant une réaction. Je trouve ça dommage, pour un ROM qui a une belle fluidité.
En gros fallait pas trop lui en demander et ça passait. Par contre j'ai pas test avec le GPS activé, ni le BT où autres. Juste le Wi-FI et les datas était dans la partie des tests. Désolé.
Ensuite, niveau autonomie, bien évidemment avec mon utilisation personnel, donc à savoir, datas désactivé toutes la journée. De plus, Wi-fi 3h le soir et 5 conversations SMS environ le soir. Donc, j'ai pu tenir deux jours. Chargé à 100% vers 7h du matin. 21h environ 53%. Donc très facile pour tenir deux jours, avec mon utilisation. J'utilisais le kernel Adam pour le test de cette ROM.
Voilà, j'ai fini mon gros pavé de retour. x)
privacy_tipPermission de ce forum:
