description[ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802 Empty[ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802
Rom présentée par  R0i_
What is FrozenDark Project?
Basically DarkSideTeam team is trying to develop a Cyanogenmod based rom and adding more things from other databases to try to improve even more and as far as possible what Cyanogenmod offers.
The base will be shared by github so everyone can compile and work on it if you want.
Images
[ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802 Pwmg  [ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802 S1tp
[ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802 66o2  [ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802 Lmdb
Installation
International Lg g2 code 802.
Faire un backup de votre Rom actuelle!
Télécharger la rom et les Gapps
• Copier le zip de la ROM et les Gapps sur la Sd interne
• Rebooter dans le Recovery
• Factory reset (hautement recommandé)
• Flasher la  ROM puis les Gapps
• Wiper les caches, Rebooter to System
• Enjoy!
Build 2
CyanogenMod Snapshot updated version of the day January 4, 2014.
Tweaks in Build.prop reset the improvement of performance, battery, coverage, and the like.
Added option to resize the NavBar in settings / interface.
QuickRemote added.
Changed the wallpaper as the former did not like much.
Removed audio libraries snd_soc_msm_Taiko of Build1.
Requires Clean install with 4 wipes
Build 1
Base Cyanogenmod.
Kernel stock of Cyanogenmod.
Removed app Cyanogenmod: CMAccounts, CMWalppaper and more
Bootanimation Google Nexus
Added Tweaks in Build.prop.
Added new audio libraries snd_soc_msm_Taiko
Added automatic connection manager 2g/3g (TeloRadio).
Coming more customization options and performance improvements.
Téléchargements
Fix Wifi for Build 2
[url=http://www.mediafire.com/download/tj2r943h38judav/FrozenDark Project LG G2 D802 Edition Build2.zip]FrozenDark Project LG G2 D802 Edition Build 2[/url]
[url=http://www.mediafire.com/download/2hf7yl0e28a7kz9/FrozenDark Project LG G2 D802 Edition.zip]FrozenDark Project LG G2 D802 Edition Build 1[/url]
Les gapps/
Les gapps sur Goo.im
ou les Gapps BANKS - si vous avez des soucis avec les Gapps précédents
Adds-ons
[ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802 Tuqs
Autres infos
Source sur Xda
Source sur darksideteam
description[ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802 EmptyRe: [ROM KITKAT 4.4][4.4.2]FrozenDark Project LG G2 D802 Edition Build 2[Auto 2g/3g] LG G2 D802
Réserved Wink
