description[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Empty[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit]
Animation météo par satellites
https://www.youtube.com/watch?v=XJpS87Dxhno
GPS Enabled Weather Radar
[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Descri10
- Gets weather radar for current GPS location or using cell towers
(to get location using cell towers uncheck "Use GPS" in Settings)
- Ability to manually enter location
- Click anywhere on the map to move to that location
- Different zoom levels
- Animated radar loop
- Multiple resolutions (VGA,QVGA,WVGA,WQVGA) Portrait/Landscape/Square
- Integrates with Showaco TitaniumWeather 4.2 PlugIn
[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Screen10
[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] %28METTRE-LIEN-D%27IMAGE-COPIER-COLLER-POUR-PLUS-D%27IMAGES%29[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Gpswr_10[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Gpswr_11
[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Gpswr_12[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Gpswr_13[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Gpswr_14[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Gpswr_15
[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Change10
2.5
- Option to show/hide GPS details on radar/satellite location update.
- Shows frame postion when in a loop (as -+----, --+---, etc.).
- Other minor improvements and code clean up.
2.4
- Autoupdate radar based on set interval (5 - 60 min, Settings -> Misc -> Auto update interval).
Tap Update -> Auto Update, then
Update -> Radar - will refresh radar image for current location every n minutes.
or
Update -> Location + Radar - will acquire new position and get radar image for it every n minutes.
- Ability to store/open custom urls. (opens in your default browser)
You can pass application parameters into the urls using custom tags (see Tips & Tricks below)
2.3.1
- Satellite loop is now available for Europe, Africa (15 minute increments) and Asia (30 minute increments).
- Faster update speed.
- Option to show radar/satellite legend.
- Other minor improvements.
2.2.05
- Speed and stability improvements.
- Other minor fixes.
2.2.04
- Added option to cancel radar update.
2.2.03
- Some minor fixes.
2.2.02
- Added a version for WM Standard (non touchscreen).
- Other minor enhancements.
2.2.01
- Fixed a bug where culture specific decimal formatting prevented GPS fix in Raw interface mode.
- Fixed a bug where in some cases radar image was 1 hour older than what the app showed.
- Webservice enhancements.
2.1.01
- Fixed a bug where culture specific decimal formatting did not allow correct Radar/Satellite image to be downloaded.
2.1
- Fixed reg file to import the GPS Radar to the Titanium Weather (thanks MysticGenius)
- Minor fixes
2.0
- New source of Map/Radar/Satellite data
- Support for more locations - USA, Europe, Middle East, Africa, Asia, Brazil, Atlantic Ocean, Indian Ocean
(126W,50N - 66W,24N; 57.4922W,57.4922N - 57.4922E,57.4922S; 57.4923E,59.7901N - 116.7913E,59.7901S)
[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Telech10
ICI
[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Autres10
ICI
Aussi
disponible dans la [SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Yboourv
Sinon, uploadez le Wink!
description[SOFT] GPS ENABLED WEATHER RADAR : Meteo par localisation GPS [Gratuit] Emptylogicielgps wmlogicielgps wmservicegps
NE PAS SUPPRIMER CE POST CONTIENT LES TAGS
