ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 || [9/4/09][HARD SPL 1.14]
+15
D4l3x
DmL
delija
esR-
simd
Giby
Djems
bmathias
doopeworld
Angkor
X3n0n
NeG
joel90
voileuxcool
19 participants
descriptionROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] EmptyROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 || [9/4/09][HARD SPL 1.14]
ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] HomeScreen ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] ManilaPrograms
ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] Contacts2 ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] ManilaPrograms2
ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] ManilaHomeL2
Welcome to my ROM thread!
This ROM is the first one in my series of ROMs for the Touch HD, and it's designed to have the latest and greatest applications and improvements. I also make ROMs for the Touch Pro device and that can be found in this thread.
This ROM is based on the latest stock, shipped Topaz ROM, so it it should solid as a rock. I can assure you, it's much... MUCH faster than any stock ROM on your device.
The ROM is being continuously developed and bug fixed and there's almost daily releases. I've decided to name each release by the date when it was released. For example, 33109 would have been released on March 31, 2000.
The ROM is currently based on the 21042 CEOS core, with all the new goodies from the newly announced Diamond2 (Topaz) device.
The ROM should already be %99 bug free. Bugs you may find, will be related to the Manila interface, mainly the unfinished Facebook features.
- This ROM is a Ferrari, therefore it drinks a lot of gas and burns a lot of rubber (RAM)... so be prepared to charge your phone more often!
Build 40909 Released!
Entirely rewritten from the ground up to use the latest Topaz components from the final, shipped Topaz ROM!
- Manila bugs are all gone (especially the clock time DST issue)
- Topaz dialer with 3G support (no landscape support)
- Added RSS Hub
- Updated Live and Live IM to latest version from 21042 ROM
- Updated ALL applications and packages to 21042 Topaz final versions.
- Fixed previous issues with streaming video playback from certain websites.
- Tnyynt SD Tuner optimizations applied
- ATI D3D driver enabled
- Updated graphics
- Much more...- Fixed double wifi entries
- Fixed (somewhat) the overlapping names in Programs tab
- Added .qtc icons for people that want to switch to the Manila menu
- Fixed .Net CF 3.5
Download from US Server > Regular Version / MS Voice Command Version
Download from EU Server > Regular Version / MS Voice Command Version
If your .rar file is corrupted after downloading from the EU server, please retry your download from the US server... just download from the US server to begin with if it's fast enough
** EnergyROM HD Series 1.0 21042 - Rhodium Manila ** || Build 40309 ||
Build 40309 Released
- Added rotate screen on start menu for manual screen rotatation.. changescreen drives me crazy!!
- Remove debugging services from ROM. SD card access and freezing issues should be resolved now
- All fixes from hotfix rolled in
- Adjusted scroll settings for better scrolling in contacts, outlook, etc ....
- Add windows live search.. uninstallable
- Updated startup animation and wallpaper
- Fixed start menu tweaks shortcut locations.
- Removed Top curtain in TF3D
- MSVC added.
Download from US Server > Regular + MSVC
Download from EU Server > Regular + MSVC
source : http://forum.xda-developers.com/showthread.php?t=499416
Thème S2U2 : Block the Holes VGA by BoB_55
ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] Screen35rf5 ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] Screen02zj7
téléchargement : Block_The_HoleS_VGA.zip - 0.47MB
source: http://www.actualitemobile.com/forum/index.php/topic,637.135.html
descriptionROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] EmptyRe: ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 || [9/4/09][HARD SPL 1.14]
Je la trouve superbe ! Va falloir essayer je pense :p
allez, je me lance :geek1:
ya trop de roms a tester la j installe ma maryone 6.5 !!!! ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] 25167
j ai jamais rien dans mon tel , je change toujour de rom !
j'suis d'accord. A quand la ROM ultime qui va t'interdir d'en changer ?
En même temps chaque cuisto FR ou WWE a son type de ROM, elles sont qusiment toute presque parfaite...apres c'est une histoire de gout.
salut,
c'est klr trop de Rom a testé ^^
Alors je les testé vraiment bien jolie pleins d'appli mais impossible de se connecté a internet, pourtant j'ai bien config le truc mais sa ne marche pas les user agent était bien mis bref a re testé
sinon "This ROM is a Ferrari, therefore it drinks a lot of gas and burns a lot of rubber (RAM)... so be prepared to charge your phone more often! "
Mouai comme les autres après un hard reste jai eu peur en voyant les 34% au démarrage mais après sa monte comme les autres au alentour de 48/50%
Bref a testé vraiment bien je trouve, en attendant la laurentius ^^
Idem, testé, mais avec Internet qui ne marchait pas sous Opéra (comme NeG, malgré les modifs. User Agent), j'ai laissé tomber.
Par contre ROM sympa et jolie.
Le grand retour ici de l'ancien menu. Je l'ai trouvé très fluide.
Moi j'attends la Mania HD 2.4 Very Happy
me rappel d'un truc c'est que internet marcher mais avec le cable usb de brancher ?? alors peut être que y'avais une option a cocher et comme je capte rien a l'anglais smile
Je n'ai pas cherché longtemps. J'ai juste récupéré le fond d'écran que je mets maintenant sur mes ROM
lol pareil Wink
[édit] finalement sa marche petite erreur de ma part smile
des bugs relevé ?
pour ma par rien jusqu'à maintenant , (croise les doigts) ^^
Niveau fluidité ça donne quoi ?
La nouvelle interface pour les sms est t'elle présente et fonctionnelle ?
Si j'ai bien compris pas de nouveau menu démarrer ...
MERçi
J'attendais qu'une ROM me fasse envie avant de flasher, ben celle ci m'a donné envie Very Happy
Installé dans l'apres midi, pour le moment, pas de bugs rencontrés, je suis deja a 50% de batterie, apres une install par µSD, un HardReset juste apres l'install, et un peu de tripatouillage pour voir (la battereie devais etre dans les 95% au debut).
Bref, on verra pour la suite (couplée avec la ROM Radio 1.13), mais elle est bien polishé, les apps essentielles sont là d'origine, j'ai juste rajouté le RSS Hub.
Woot la meilleure que j'ai tester depuis que je traine ici (et j'ai tester toutes ou quasi toutes les ROMS dispos par ici).
cheers
Pas de bugs majeurs, très rapide, très belle !!! Je vous conseil de la tester même si elle est en ENG.
Et surtout très fluide !!!
Bonjour, j'ai telecharge cette rom qui pour moi, est de tres loin la meilleur a ce jour.... une petite merveille, par contre deux petits soucis, comment fait on pour faire un hard reset, sachant que dans les parametres l'icone pour le faire n'y est pas, et de deux si quelqu'un a trouve comment faire marche OPERA, je veux bien ses lumieres!!! j'ai tout essaye pour opera, le reinstaller depuis le site internet puis copier les fichiers depuis /opera 9.5 beta vers / windows, mais rien tjs aucun resultat.... Merci d'avance, et bonne continuation a tous.. DOOPEWORLD!
L'icône y est :o Wipe device, avec l'icône de poubelle :o
Pour opera...ben tu le lance... un raccourcis dans internet, et un raccourcis dans la tab navigateur, je ne vois pas ton problème.
Salut X3non, merci pour la premiere reponse.... Mais pour la deuxieme, Opera se lance mais il affiche erreur peut importe l'adresse que je tape, alors que tout marche avec IE... voila mon probleme!
Merci pour l'aide....
Désole, je ne peut t'aider pour opera, vu qu'il fonctionne très bien chez moi :S
RE bonjour, ok solution trouvee pour opera....
Pour Opera :
Ouvrir opera ( ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] Wink). Dans la barre d'adresse, tapez opera:config et allez à users prefs
Descendez jusqu'à Custom user agent, remplacez : (inserer ici la valeur par défaut, j'ai pas noté avant de changer...)
Mettre à la place : HTC-P3700-orange/PPC; 480x640; OpVer 30.126.2.732
Descendez
tout en bas (c'est long) enregistrer, validez, vérifiez que vous n'êtes
pas connecté au net par le wifi ou activesync (le portail orangeworld
n'est accessible qu'en mode data/3G) et rendez vous sur www.orange.fr ou mobile.orange.fr
Voici les différents UserAgent du HTC Touch HD :
Pour Orange :
Opera : HTC_Touch_HD_T8282-orange/PPC; 480x800; OpVer 34.119.2.731 Opera/9.50(Microsoft Windows 5.1; U;fr)
IE Mobile : HTC_Touch_HD_T8282-orange/PPC; 480x800; OpVer 30.126.2.732 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11)
Pour SFR :
Opera : Vodafone/1.0/HTC_Touch_HD_T8282/1.14.163.2 (28253) Opera/9.50 (Windows NT 5.1; U; fr)
HTC Touch HD nu :
Opera : HTC_Touch_HD_T8282 Opera/9.50 (Windows NT 5.1; U; fr)
IE Mobile : HTC_Touch_HD_T8282 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11)
A l'attaque !!! ROM||WWE|| ** EnergyROM HD Series 21042 - Final Topaz Manila ** || Build 40909 ||  [9/4/09][HARD SPL 1.14] Xd
C'est étrange, je suis chez Orange aussi, j'ai juste configuré le UserAgent pour IE, rien de plus, mon opera fonctionne normalement.
Content que ça ait résolu ton problème Wink
Je viens de tester la rom vite fait !
Première impression !
Magnifque !
Super rapide !
Très complète il manque juste le nouveau menu démarrer je trouve )
Pas de bugs rencontré
Bref j'adore !
euh question, cette rom est en effet excellente mais impossible d'installer tomtom (ca mouline et ca avance pas!). aucun souci pour le moment avec d'autre cab!
anyone have an idea? =)
Je viens juste de l'installer. Je n'ai encore rien testé mais déjà au niveau design c'est magnifique.
j'ai eu ca sur une autre rom...apres hard reset et en installant tomtom en premier c passé..
