description[Rom JB 4.3 SENSE 5.5] SkyDragon MAX v 2.0 | APM | HEQS | THEMES | MODS |1.54.401.1 | GSM | HTC ONE MAX   Empty[Rom JB 4.3 SENSE 5.5] SkyDragon MAX v 2.0 | APM | HEQS | THEMES | MODS |1.54.401.1 | GSM | HTC ONE MAX
HTC ONE MAX
Cette Rom est présentée par dragonesdenano
  • Android 4.3 "Jelly Bean"
  • HTC Sense 5.5
  • ROMSoftware Version 1.54.401.1
  • Rom Version: SkyDragon MAX v 2.0
Images
[Rom JB 4.3 SENSE 5.5] SkyDragon MAX v 2.0 | APM | HEQS | THEMES | MODS |1.54.401.1 | GSM | HTC ONE MAX   2jccpj
Derniers changements
20-12-13
Made Using Dsixda Kitchen
Rom Firmware base 1.54.401.1
GSM ROm ( NOT For Sprint/NOT For VRZ )
Using Stock Nadroid Back up From Pradeep!
Credits and thanks to him
Also using Navy Installer Script, Thanks and Credits to Navy
Deodexed using latest Smali/baksmali
Rooted with Latest SuperSU
Sysro/sysrw present
Zipaligned
Debloated such as files in Native OTA etc
Full Languages Added within System!!
Updated Oem Apps
APM Advanced Power Menu
1% Battery Mod
Heqs ( tapping date hide/show Native Eqs )
Credits and thanks To Woodstock for mods!!!!
Heqs Themes Compatible
Tweaked For better Performance and Battery life
Init.d compatibility
Viper4Android Compatiblility
Fast and Smooth
Custom SkyDragon Bootanimation
Custom Font
Custom SkyDragon Wallpaper
And things I forgot!
Thaks to all SkyDragon Team and Betatesters!!!
Thanks Pradeep for fixing Bin stuff!!!
IMPORTANT
Rom has a bug related to SystemUI
Flash this small fix via recovery, after that make a full wipe
Installation
Avertissement pour installer la rom il faut que le One Max soit unlocked, mais même en passant par htcdev cela "brique" le scanner fingerprint
1.Faire un backup de votre rom actuelle.
2.Dans le recovery, Wipe cache,dalvik cache, system, and factory reset
3.Flasher la rom
4.ensuite rebooter et Enjoy ...
SkyDragon v 2 Euro
SkyDragon v 2.0 EURO
Md5 checksum : 916d44b95af8a37d23e7a67b6da1600a
File size : 1,108.24MB
[url=https://www.dropbox.com/s/zbqadmv7kn26p74/SkyDragon v 2.0 FIX.zip]SkyDragon v 2.0 FIX[/url]
Add-ons/Mod
Autres infos
Source sur Xda
description[Rom JB 4.3 SENSE 5.5] SkyDragon MAX v 2.0 | APM | HEQS | THEMES | MODS |1.54.401.1 | GSM | HTC ONE MAX   EmptyRe: [Rom JB 4.3 SENSE 5.5] SkyDragon MAX v 2.0 | APM | HEQS | THEMES | MODS |1.54.401.1 | GSM | HTC ONE MAX
Réserved Wink
Merci pour la fiche car je viens de l'installer ce matin et elle tourne plutôt pas mal du tout. smile
Je pensais partager de retour chez moi.
Pour le scanner bloqué, il semblerait qu'il suffirait de revérouiller le bootloader.
Yes, j'ai crée un petit topic sur le sujet
https://www.forum-generationmobiles.net/t73441-astuce-locked-unlocked-s-off-requis-htc-one-max
Pas testé sur mon HOXL mais a priori cela fonctionne aussi sur le One et certainement sur le Butterfly
J'ai lu qu'il fallait nourrir les sections  rendeer mais pas de soucis pour te laisser à l'avenir (tu as l'appareil Toi :p)
Tu pourras ajouter des captures d'écran et toutes autres choses smile
Oui, je l'ai reçu y a à peine 10 jours,  j'alimenterai pour te soulager. Wink
Mais pas avant quelques jours, Noël oblige. Wink
[Rom JB 4.3 SENSE 5.5] SkyDragon MAX v 2.0 | APM | HEQS | THEMES | MODS |1.54.401.1 | GSM | HTC ONE MAX   Guten%20Appetit
Merci, mais je suis en France et non en Allemagne, même si je m'y trouve pas loin... Lol
je l ai teste mais sur mon one max il ny a rien sur la barre d etat bizarre?
