[ROM WM 6.5.5][WWE][17.02.2010] - Eugenia ROM Project V1,1 1GHz+576MB Hack [PLUSIEURS BUILD]
+28
ZeroCooL
Tarteens
UniVertel
djems007
pimoos57
doog
dartagnan95
yoyo312
seppi
Silouan
moldirty
Gill
hamdi93
Stail
ThierryD37
Defprelude
nonoz1000
jackHD
JClaude
Poussinou
Emmepi
Roupette
Damage inc
voileuxcool
32 participants
description[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Empty[ROM WM 6.5.5][WWE][17.02.2010] - Eugenia ROM Project V1,1 1GHz+576MB Hack [PLUSIEURS BUILD]
Eugenia ROM Project for HTC HD2
[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Descri10
Welcome to the Eugenia ROM Development for HTC Leo (HD2) thread.
The FIRST HTC Leo cooked ROM!
Main goals:
*- Speed and stability, all in one solution;
*- Device ever updated, with latest packages;
*- Giving the BEST applications for having the BEST experience with your device;
*- Bleeding edge Operating System.
Versions of the ROM:
Full: Complete set of HTC applications and other added utilities.
Lite: All HTC applications, except HTC Sense.
Lite Essentials: Only the essential packages to make your device to work with the latest build of Windows Mobile OS. Fully customizable. Maximum storage.
HTC Reworked: Tweaked HTC stock ROM, with speed and storage enhancements, without any added external application.
Features:
*- USB host functionalities
*- CPU scales to a maximum of 1GHz instead of 768MHz WILL BE INCLUDED IN RC RELEASE
*- Chainfire D3D Patch
*- Camera patched for Extra SuperFine quality
*- Better video recording, MP4 VGA bitrate raised!
[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Screen10
[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] 01mhome[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] 02mcal
[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Change10
*- Released V1.1!
*- SYS/XIP 23534 (Full, Lite, Lite Essentials)
*- SYS/XIP 21890 (HTC Reworked, WWE)
*- New Outlook interface / New Office Mobile 2010!
*- Phone Canvas problem fixed. Now showing the correct informations and
the correct photos when receiving a call!
*- Extendir integrated in XIP.
*- 1GHz Hack integrated!
*- 576MB RAM unlocked!
*- eReader tab in HTC Sense.
*- Better Opera Mobile experience!
*- Opera Mobile can now open 9 tabs without slowdowns.
*- Opera Mobile speed tweaks and optimizations integrated.
*- Added some other speed optimizations, without stability problems.
[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Telech10
Available languages: WWE / ITA (soon).
Downloads:
Eugenia Project for HTC HD2 V1.1, WWE Full: Part1 - Part2
Eugenia Project for HTC HD2 V1.1, WWE Lite Essentials: Download
Eugenia Project for HTC HD2 V1.1, ITA Full: Part1 - Part2
Eugenia Project for HTC HD2 V1.1, ITA Lite Essentials: Download
Note: For unlocking the full 576MB RAM availability you need to install 2.06.50.04 Radio ROM!
[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Autres10
astuce:
-pour rassembler les 2 archives, utilisez ''hjsplit''
Aussi disponible dans la [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Yboourv Sinon, uploadez la Wink!
description[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] EmptyRe: [ROM WM 6.5.5][WWE][17.02.2010] - Eugenia ROM Project V1,1 1GHz+576MB Hack [PLUSIEURS BUILD]
réservé
*- CPU scales to a maximum of 1GHz instead of 712MHz
en voyant ceci,ça veut dire qu'il est bridé actuellement ?
édit: a voir il a thread sur xda pour la meme question que la mienne
http://forum.xda-developers.com/showthread.php?t=602225&page=2
a voir le hd2 est bridé a 712mhz, c'est pour cela que certain disent que les performances sont moins bonnes que sur le acer f1 ou le tg01 !
Il est bridé peut être pour une durée de batterie plus longue! (c'est ce qu'ils ont fait avec le liquid d'acer)
peut etre mais autant exploiter a fond le processeur !
nan?
Si!!! Wink
T'habites a nancy ...
[ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] 595664
nan?
Je suis d'accords avec toi !
pourtant roupette au début même avant que le hd2 sorte, on pensai qu'il n'était pas bridé [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_sad
nan?
Dans ce cas là, pas la peine de mettre 1Ghz comme argument de vente... 712 Mhz aurait suffit et ils en auraient certainement moins vendu...
Ha ben si je m'attendais à ça [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] 73683
Il n'existe pas un soft capable de mesurer la fréquence réelle du proce ?
Encore des bruits de couloir ... [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_rolleyes
J'ai eu le TG01 et maintenant le HD2.
J'ai toujours réglé mon TG01 à pleine puissance et je peux vous dire que le HD2 est aussi rapide voire même plus sur certaines applications que le TG01.
De plus j'aimerais connaître de quelle façon la vitesse du processeur a été mesurée vu que le snapdragon a la particularité de varier sa vitesse automatiquement en fonction des ressources sollicitées. C'est grâce à ça que ce processeur est puissant et économe.
EDIT:
Pour étayer ce que je disais un post plus haut voici une discussion sur xda qui tient les mêmes propos :
@JClaude,
Merci pour la remarque pertinente ! [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_wink
Par contre, si tu pouvais éditer tes posts en cliquant sur "modifier" et non écrire des messages à la suite des autres, ça serait sympa !
J'ai donc édité ton post !
A + [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_wink
Bah rappelez-vous bien... se ne serait pas la 1ère machine à avoir un CPU bridé chez HTC... à titre d'exemple l'excellent Qtek9000 annoncé à 512 Mhz et qui tournait au début à seulement 400 et il y en a eu d'autres... [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_wink
Aucun problème Sony, je tiendrai compte de ta remarque. [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_wink
Je pense qu'il y a mieux à discuter que la vitesse bridée ou non du processeur, c'est la fonction USB Host.
Pour l'avoir utilisé sur le TG01, je peux vous dire que c'est de la balle ! [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_cheers
Aura-t-on notre cadeau de Noel de la part de Cmonex ?
Plus que 2-3 jours à attendre !!!
Bah faut pas trop de précipitation... mieux vaut tard que jamais et puis à Noël il y a d'autres priorités [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_santa
Pour moi l'idéal serait une sortie dimanche 27... mais bon ça n'engage que moi [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] 180484
on verra bien une fois le hard spl sortie [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Icon_wink
Ca bouge un poil chez XDA : http://forum.xda-developers.com/showthread.php?t=589642&page=24
Moi, je dis que le top sera la fonction usb host. Car si elle marche c'est une super fonction pour l'utilisation nomade.Avec un petit adapteur, on pourra aller chercher dans n'importe quel periph faisant fonction clé usb.
Example le Diamond en vitesse minimal 300 Mhertz; vitesse maxi origine 520 Mhertz et après overcolcking 624 Mhertz !!!!!!
C'est pour tout public donc ils font une moyenne et voila!
Ensuite au bon vouloir de chacun d'accroitre la puissance.
présentation post 1 à jour
Oui, voileuxcool, mais le dernier lien sur la Taverne est inutile, car cette ROM n'y est pas téléchargeable (aucune autre ROM cookée pour HD2, non plus, d'ailleurs) [ROM WM 6.5.5][WWE][17.02.2010]  - Eugenia ROM Project  V1,1  1GHz+576MB Hack [PLUSIEURS BUILD] Lol
ouaip
