description[Rom JB 4.2.2/Sense5] KickDroidXL v5.2.0 | Battery Savings | Ultra Smooth | HTC ONEXL EVITA Empty[Rom JB 4.2.2/Sense5] KickDroidXL v5.2.0 | Battery Savings | Ultra Smooth | HTC ONEXL EVITA
[Rom JB 4.2.2/Sense5]  KickDroidXL v5.2.0 | Battery Savings | Ultra Smooth HTC ONEXL EVITA
Rom que nous devons à 24ky
  • Android 4.2.2 (Jelly Bean) - latest official HTC One XL 5.08.841.3 (TELSTRA) firmware
  • Android 4.2.2 (Jelly Bean) - latest *STOCK* ROMs without changes and modifications ---> Click Here
  • This is improved version of stock ROM - no visual changes!
  • Very fluid, clean & stable!
  • Full HTC Sense 5.0 Interface
  • For HTC One XL ( Snapdragon CPU ONLY )*
  • Thanks to *for the base firmware @radavs
Stock kernel (the most stable, will change soon )
  • Removed software (CPU) rendering - full Snapdragon S4 (GPU) rendering
  • Fully optimized and tweaked
  • Root access
  • Stock *boot.img ( for now )
  • RAM optimizations
  • Improved virtual memory management
  • Speed optimizations
  • Enabled GPU UI rendering
  • Bloatware applications from Telstra removed
  • All /system applications updated to latest available
  • Disabled kernel debugging for better performance
  • Fully odexed
  • init.d scripts (BusyBox run-parts) support
  • Excellent battery life!
  • Adobe Flash Player support
  • ...and many more!
[Rom JB 4.2.2/Sense5] KickDroidXL v5.2.0 | Battery Savings | Ultra Smooth | HTC ONEXL EVITA New222
KickDroid XL v5.2.0 OTA
  • Fixed Dual Core Mod ( Choice of 3 dual-core profiles to choose from )
  • Sony Xloud ( Runs through init.d script instead of build.prop )
  • DimLed ( Choice of 3, between stock, dimmed, or complete led off )
KickDroid XL v5.0.0
  • Dual Core Mod ( forces cpu1 online while screen on for performance, and when screens off it saves battery )
  • AGPS Patch
  • DimLed Mod
KickDroid XL v4.0.0 ( Halloween Edition )
  • AROMA INSTALLER!!!!!!!!
    - Add Google Apps You Want
    - Add User Apps Of Your Choice
    - Remove Some Stock Apps
    - And A Bunch Of Surprises
  • Zipaligned (Improved RAM management)
  • Zipalign on boot (for user applications on data partition
  • sysro/sysrw commands support
  • Improved EXT4 performance
  • New SuperUser App / Root fixed
  • XReality ( aka newest bravia engine )
  • My New Camera
-Use Vol+ to capture pictures, and use Vol- to record videos.
- Should recording sound @ 256 kbps.
- Bitrate of FHD videos up to 40 Mbps, and for HD videos up to 20 Mbps.
KickDroid XL v5.0.0
Here
KickDroid XL v5.2.0 OTA à flasher sur la 5.0
Here
Sense 5, Android 4.2.2 *
Ici
KickDroid XL v3.6.0 :
Ici
KickDroid Boot.img
Ici
You need:
  • HTC One XL unlocked with htcdev.com (S-ON) or S-OFF
  • Custom recovery
  • Firmware package from : 2.15.0000_5.08.111.2-1.31a.32.45.16_2_10.141.32.34a.zip
Installing the Firmware :
How to flash:
  • Download ROM and place it on your virtual SD card
  • Boot your phone in recovery mode (vol down + power)
  • In main menu, select "install zip from sdcard"
  • Select "choose zip from sdcard" and browse to the location of KickDroid ROM
  • After flashing process is complete, reboot the device
Source sur XDA
description[Rom JB 4.2.2/Sense5] KickDroidXL v5.2.0 | Battery Savings | Ultra Smooth | HTC ONEXL EVITA EmptyRe: [Rom JB 4.2.2/Sense5] KickDroidXL v5.2.0 | Battery Savings | Ultra Smooth | HTC ONEXL EVITA
Réserved Wink
je viens vers la communauté car je n'en peu plus de ce P.....n de one xl !
J'ai galéré à tout mettre en place :
TWRP 2.4
Super cid
S-off
dernier firmware pris chez viper...
J'ai téléchargé cette rom kick ainsi que la rom rage... Dans le recovery, au moment de l'installation j'ai "failed" !!!!!!
Pourtant j'ai réussi à installer la viper. Je ne flash pas le boot.img car je suis s-off.
Qui peut m'aider ?
C'est ta version de TWRP qui ne va pas Wink
Il faut que tu passes sur la dernière version 2.6.3.3. ou sur le Philz touch en version récente...
Oui, merci, je m'en suis rendu compte ce matin ! en repassant à la version 2.3.3....
Tout va enfin !
 Very Happy Very Happy Very Happy
[Rom JB 4.2.2/Sense5] KickDroidXL v5.2.0 | Battery Savings | Ultra Smooth | HTC ONEXL EVITA 750705
je reviens vers vous car la rom est en anglais uniquement. Dans l'absolu ce n'est pas très génant mais je prefère le français.
avez vous une solution ou alors en connaissez-vous une pas gourmande en énergie ? Je privilégie la batterie  Wink
J'ai utilisé Morelocale2 pour franciser un peu mais ce n'est pas parfait...
La demande pour les langues a été faite au DEv, donc may be...
Pour la conso, je fais confiance au kernel de flar2...
Post1 mis à jour...
une V6 full multilanguage devrait arriver Wink
youpi ! Merci
hello ! des news sur la v6 ? elle se laisse désirer la petite .... Very Happy Very Happy
Ben visiblement cela prend du retard...
description[Rom JB 4.2.2/Sense5] KickDroidXL v5.2.0 | Battery Savings | Ultra Smooth | HTC ONEXL EVITA Emptycompatibilité?
Bonjour, est ce que cette rom fonctionne avec le hboot 2.18 ??
je cherche uen rom stable que j'ai pas encore trouvé smile
Normalement pas de soucis, mais je ne me rappelle plus si le français était intégré dans la dernière version...
Vérifie que tu as bien l'usb debbuging d'activé et ouvre une fenêtre de commande sur ton pc (comme pour les commandes fastboot)
connecté en usb
passe les commandes suivantes
adb devices
su
adb reboot bootloader
une fois dans le bootloader
fastboot erase cache
fastboot reboot
et regarde ensuite si tu as toujours ce soucis...
