[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1)
+184
Jackob 51
durion62
fashionweed
likan03
gescc
abdel75015
cyrius3
voileuxcool
RollOfTheDice
eoliens
Diouc
padpaniq
palcojazz
faillure
Sirusse
butterflystephy
tack
darknetwork
alexis.200789
shosh
TeteDeNoob
mimio37
flavietristan
HTC1559
heg428
xtb62
Yonathân
B@ron_S@medi
jifonk57
abouassia13
maillot 974
hd2stone
djspartex
nina89
wikilman
Fredoah
Seed111
looping92
Inj3ct0r
plexus
Shad77
BiV
korlochan
pascal32
devil51
mekoar
wolfen01
kreekpack
mithos07
alphaplus
Lulucz
KEROZ3N
cmpuissance3
MaTaool
pierrickf
stratdogs
Dawid64
djtunex
franck44
Rusherman
Alphomega
beybey001
Chnoup
mat6817
lolovtt
alan42
karko1988
jake42
nedim
Pilou73
Bouricko_666
simer
valeryhugo
link130
Daviduck
ZeroCooL
cyril2smc
funkysoul
HIND
valzz360
tony8877
puppetmaster
poucinette
Leptitking
proxima
+Stunty+
sobersong
pOma
steve78
darkyork
freezy973
WiLi
thephoenix972
Vynke_974
Toots
Yuen
dedelamenace
sboiiing
lben64
Sheard
ali htchd2
goze91
bullrott
fana75
evydou
shadow007
Bylkaroc1
dwaithc
TaGueli
zeta73160
benrennes
bigbangidfm
Sonee97360
Simon65
toubabou
guidonar
chrystos
rafxiphone
Saft
cedric074
zitoun
styling
yoyo312
bibis08200
bobstgely
Gegedj
Trikap
greg64
icobi
lauky
kostilus
blades
smobydick
chob
Twipeep
jujug
davidhebert
SpartanSteal117
link-40
WhiTe-WiiDoW-FR
jay991
Zack
Duma
elmika
yonni
rickou
spyoner971
fabiano
michd
Eazyy
adishats
JEZ69
snakeplisken
DiabloCorps
T0maT0
flouch
yepiyo
Amedinho
mack13
leleup
marus
croftman
bramss
le.doms
philippeb
matuvu
geebee
liroy06
Azu
1bert
croustibat
csercl
kevin69800
barjel
jeanmarce
Fabio
biotoxic937
188 participants
description[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 9 EmptyRe: [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1)
ben normal , car tu n'as pas de rom encore sur ton leo !!
Regarde là : http://htc-touch-hd.1fr1.net/t37686-tuto-comment-flasher-une-rom-nand-android-sur-le-hd2
C'est tout bien expliquer pourtant !!!
Apres ça ,je vois pas comment je pourrait t'aider !!
oui mais sur le forum il es écrit que lorsqu'on installe magdlr un menu apparet
et la on doit choisir ce qu'on veut faire mais je n'ai pas ce menu
Ok , tu veut voir le menu ??
Eteint le phone ou plutot vire la battery !!!
1/ tu appuis brevement sur power ,sa vibre ,puis tu reste appuyer à nouveau sur power , jusqu a l'apparition du MAGDLR
Voilà , tu est sur ton fameux menu , tu peut maintenant flasher une rom
PS/ à condition d'avoir une rom radio supportant les 576 mo de RAM , style 2.15.50.14
VOILOU
je le fais pas exprès mais le menu n’apparaît pas pourtant je fais ce que tu me dis :s
je pense que je vais arrêter de m'acharner dessus il veut pas c'est tous ^^
Quand tu flashe le MAGDLR ,tu lance le Romupdateutility .exe et tu as une fenetre qui apparait ,tu fait next ,next et sa flashe ???
Faut mettre ton phone en booloader pour flasher le MAGDLR !!
il es bien en bootloader quand je le flash
oui je fais toujours next un moment il me dis update je le fai uil me met la version quil m'installe et il flash
Ben c'est ça la manip , c'est bon , et quand il reboote , laisse ton pouce appuyer sur le bouton "raccrocher" , tu doit avoir le menu qui apparait !!
"Allumez votre HD2 en maintenant appuyé le bouton ON, le menu MAGLDR apparait."
Copier du tuto de flash NAND à l'instant
Very Happy
non toujours rien :@
je vais pas t'embeter plus longtemps je remet ma rom officiel et j'essaye demain a tête reposé ^^
Flashe en tant qu' Admin sur ton ordi ( clic droit sur le romupdateutility )
Desactive ton Anti-virus au cas ou avant cela , mais là c'est bizarre ton soucis !
edit/ ok , vois ça demain, si tu solutionne pas toujours ,faut qu un cuisto ,te guide pas a pas , pour la procedure ,mais le tuto ICI est fait pour , donc continu tes quetions dans ce fil de discussion ou celui là , pour trouver tes réponses !!
Perso ,je suis a plus de 100 flash ,j'ai tous tester Nand , sd ,.zip , et sa toujours fonctionner !
Tu as le bon HSPL ? C'EST BIEN LE 2.08 , et non pas le 2.08.0000 !!! sinon c'est pour ça que sa foire
A bientot et bon courage pour la suite Wink
oui oui il es bien en 2.08
Merci a bientôt
sujet fusionné
merci de poser vos questions dans les topics appropriés Wink
désolé DEDO
voici des info en plus
version système 5.2.21869 (21869.5.0.82)
manila 2.5.20121433.0
ROM 1.72.73.3 (82124) FRE
radio 2.07.51.22_2
protocole 15.32.50.07U
est ce que je dois changer quelque chose ??
il es bien en HSPL 2.08
mais une ROM radio plus récente, la 2.15 est recommandée.
tu pense que c'est la cause de mon problème ??
je testerai ce soir je suis au boulot
merci a vous tous de m'avoir aidé
VM54 tu a vu juste
maintenant android marche sur mon HD
VM54 tu a vu juste
cool, amuses toi bien maintenant! Wink
désolé j'ai une derniere petite question
ma carte SD je ne l'avais pas mise en EXT4
est ce que je dois tous recommencer ou est ce que je peu la formater maintenant et la remettre dans mon appareil après ??
c'est bon j'ai réussit
Bonjour à tous, je viens de flasher android pour la première fois, la rom est super fluide, mais je n'arrives pas à émettre de connections data, et je ne vois nulle part où configurer la 3g comme sur winmo.
quelqu'un pourrai-t-il m'aider?
un truc que je n'est pas compris, la rom radio, on l'install quand?
j'ai deja le 2.08, le fait un task, j'installe le prog pour android, mais la rom elle s installe quand?
tu peux l installer avec le task 29 ou avec custom ruu
