[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1)
+184
Jackob 51
durion62
fashionweed
likan03
gescc
abdel75015
cyrius3
voileuxcool
RollOfTheDice
eoliens
Diouc
padpaniq
palcojazz
faillure
Sirusse
butterflystephy
tack
darknetwork
alexis.200789
shosh
TeteDeNoob
mimio37
flavietristan
HTC1559
heg428
xtb62
Yonathân
B@ron_S@medi
jifonk57
abouassia13
maillot 974
hd2stone
djspartex
nina89
wikilman
Fredoah
Seed111
looping92
Inj3ct0r
plexus
Shad77
BiV
korlochan
pascal32
devil51
mekoar
wolfen01
kreekpack
mithos07
alphaplus
Lulucz
KEROZ3N
cmpuissance3
MaTaool
pierrickf
stratdogs
Dawid64
djtunex
franck44
Rusherman
Alphomega
beybey001
Chnoup
mat6817
lolovtt
alan42
karko1988
jake42
nedim
Pilou73
Bouricko_666
simer
valeryhugo
link130
Daviduck
ZeroCooL
cyril2smc
funkysoul
HIND
valzz360
tony8877
puppetmaster
poucinette
Leptitking
proxima
+Stunty+
sobersong
pOma
steve78
darkyork
freezy973
WiLi
thephoenix972
Vynke_974
Toots
Yuen
dedelamenace
sboiiing
lben64
Sheard
ali htchd2
goze91
bullrott
fana75
evydou
shadow007
Bylkaroc1
dwaithc
TaGueli
zeta73160
benrennes
bigbangidfm
Sonee97360
Simon65
toubabou
guidonar
chrystos
rafxiphone
Saft
cedric074
zitoun
styling
yoyo312
bibis08200
bobstgely
Gegedj
Trikap
greg64
icobi
lauky
kostilus
blades
smobydick
chob
Twipeep
jujug
davidhebert
SpartanSteal117
link-40
WhiTe-WiiDoW-FR
jay991
Zack
Duma
elmika
yonni
rickou
spyoner971
fabiano
michd
Eazyy
adishats
JEZ69
snakeplisken
DiabloCorps
T0maT0
flouch
yepiyo
Amedinho
mack13
leleup
marus
croftman
bramss
le.doms
philippeb
matuvu
geebee
liroy06
Azu
1bert
croustibat
csercl
kevin69800
barjel
jeanmarce
Fabio
biotoxic937
188 participants
description[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 7 EmptyRe: [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1)
J'étais sous ROM Bouygues Officielle.
HSPL 2.08
Radio 2.15
Task29
Magldr 1.11
ROM MDJ Revolution Superlight
Le tout fait sous Vista (car l'install de la ROM Nand ne passait pas sous XP PRo) en lançant les executables en tant qu'administrateur (clic droit sur les .exe).
Port USB arrière, sans rallonge.
Voilà c'est tout.
Procédure complète faite 3-4 fois pour tester différentes NAND.
Au fait, moi j'ai utilisé Magldr 1.10 et ça fonctionne bien, quelle est la différence avec le 1.11 ?
Juste un petit message pour dire que grâce à ce sujet j'ai pu installer ma première rom NAND aujourd'hui ! cheers
En suivant à la lettre les indications et en prenant son temps sa fonctionne. Wink
Merci beaucoup à vous !
A+
Cela corrige certains bugs qui faisaient rester en "1, 2, 3, 4 Go Go Go"
Je ne me souviens plus de mon message d'erreur, mais en français ça voulait dire qu'il ne pouvait pas ouvrir task 29. Mais le problème est bien résolu, Il fallait l'ouvrir en administrateur!! Android fonctionne à merveille!! pour l'instant aucun beug et très fluide par rapport à windows!! merci!!
Une question qui peut paraitre étrange : est ce qu'on peut naviguer dans le menu du mgcldr avec le bouton vol+ seulement ?
mack13 a écrit:
Bonjour a tous,
J'ai éssayer de faire tout cela mais mon tel beugue une fois que jai ouvert ROMUpdateUtility.exe.
Une fois l'installation faite au redémarrage le téléphone bloque sur HTC vert sur fond blanc.
Aidez moi svp j'ai plus de téléphone en attendant !! Sad
J'ai le même problème. En fait j'ai installé MAGLD 11.1 et depuis écran blanc avec logo vert. Impossible d'éteindre le tel sans enlever la batterie et impossible d'atteindre le bootloader.
HELP
Merci d'avance
J'ai un problème moi :
à la fin du point 1 au redemarrage, les tel reste coincé sur l'image de pyranna ! comment ca se fait? j'ai pourtant suivi le tuto comme il fallait
Ah ben je suis pas le seul apparement ...
J'ai plus d'accés au tel du tout =x c'est assez embetant =/
Il bloque bien apres linstallation de MAGLD 11.1
je precise que je suis sous rom pyrana
bonjour
comment on fait pour flasher une autre version nand par dessus une autre ?
il faut repasser par une rom windows ?
merci.
non juste eteindre le telp appuyer sur veille jusqua voir apparaitre magld 1.11 ensuite 4 flash etc
chob a écrit:
mack13 a écrit:
Bonjour a tous,
HELP
Merci d'avance
Problème résolu pour moi, vous devez changer votre HSPL pour le HSPL 2.08 (et non le SPL 2.08 !)
voilà =)
description[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 7 EmptyMerci
Merci pour let tuto, bon boulot king
Une petite question, car là, j'ai un doute,
Décompactez l'archive du MAGLDR dans le répertoire de votre choix et lancez "ROMUpdateUtility"
Je place l'archive, dans ma carte sd, par exemple et je le décompresse directement sur mon HD2 ?
merci de votre aide
Non sur le PC, ensuite tu te mets en bootloader, tu connectes le téléphone au PC et tu lances l'executable.
Merci VM, je regarderais ça ce soir, , faudra que je vide un peu ma SD Very Happy
Salut les z'amis!
J'ai un problème de clavier téléphonique , en effet, sous une nand froyo 2.3, tout fonctionnait sauf quand je téléphone, le clavier est invisible, l'écran reste noir, et je suis obligé d'enlever la batterie pour redémarer android.
Je croyais que c'etait dû à la nand android, mais je viens de remarquer que ça le fait aussi sous la nand cyanogen, étonnant!!
Je décide donc de revenir sous WM 6.5 pour faire un task 29. Mais c'est là que ça bloque, je n'y arrive pas. je suis le tuto de la 1ere page à la partie numéro 5 mais sans réussite.
1ere question: d'ou peut venir ce problème d' "appel tout noir"
2ème question: comment repasser en WM pour faire un task 29?
edit: j'ai réussi mon task 29 en repassant par le bootloader (volume bas) mais même après ça j'ai mon soucis sur le clavier téléphonique sur la froyo 2.3...grrr
Bonjour, tout d'abord merci pour le tuto. J'ai un problème, après avoir fait le magldr, j'obtient le message "wait for usb......usb" et quand je lance le fichier DAF sur l'ordi il me marque
"Error happen
Error description : USB init failed
Info : ./RSPL/RSPL.cpp (723) "
Merci de votre aide !!!
Ah et je vois aussi quand magldr se lance qu'il marque rapidement en rouge (avant le wait for usb....) :"SD Kernel open failed"
Moi aussi j'ai déjà eu se message, j'ai refait un task29 puis à nouveau MAGLDR, essaye peut etre.
ok merci ! en fait c'est bon j'ai reussi en chzngeant d'ordinateur
Bonjour, tout le monde...
Question:
Je suis sous ROM WinMo Officielle HTC 3.14 Radio 2.15.50.14 donc SPL 3.03
Je souhaite me lancer dans l'installation d'android sur ma NAND (build: MDJ CyanogenMod7 2.5)
Comment faire pour installer le HSPL 2.08 ??
Faut-il que je flashe une ROM officielle antérieure à la 3.14 pour pouvoir installer le HSPL 2.08 ?? [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 7 887500
Moi j'ai une rom officiel également mais j'ai ni SPL ni HSPL car je faisait les mise a jour a partir du site HTC et donc pas besoin de l'installer.
Par contre j'ai lu sur le tuto qu'il faut avoir HSPL pour installer une rom nand android mais comment on le trouve ce HSPL et comment on l'installe ? Là je voit pas trop...
Merci pour votre aide [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 7 61393
