[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1)
+184
Jackob 51
durion62
fashionweed
likan03
gescc
abdel75015
cyrius3
voileuxcool
RollOfTheDice
eoliens
Diouc
padpaniq
palcojazz
faillure
Sirusse
butterflystephy
tack
darknetwork
alexis.200789
shosh
TeteDeNoob
mimio37
flavietristan
HTC1559
heg428
xtb62
Yonathân
B@ron_S@medi
jifonk57
abouassia13
maillot 974
hd2stone
djspartex
nina89
wikilman
Fredoah
Seed111
looping92
Inj3ct0r
plexus
Shad77
BiV
korlochan
pascal32
devil51
mekoar
wolfen01
kreekpack
mithos07
alphaplus
Lulucz
KEROZ3N
cmpuissance3
MaTaool
pierrickf
stratdogs
Dawid64
djtunex
franck44
Rusherman
Alphomega
beybey001
Chnoup
mat6817
lolovtt
alan42
karko1988
jake42
nedim
Pilou73
Bouricko_666
simer
valeryhugo
link130
Daviduck
ZeroCooL
cyril2smc
funkysoul
HIND
valzz360
tony8877
puppetmaster
poucinette
Leptitking
proxima
+Stunty+
sobersong
pOma
steve78
darkyork
freezy973
WiLi
thephoenix972
Vynke_974
Toots
Yuen
dedelamenace
sboiiing
lben64
Sheard
ali htchd2
goze91
bullrott
fana75
evydou
shadow007
Bylkaroc1
dwaithc
TaGueli
zeta73160
benrennes
bigbangidfm
Sonee97360
Simon65
toubabou
guidonar
chrystos
rafxiphone
Saft
cedric074
zitoun
styling
yoyo312
bibis08200
bobstgely
Gegedj
Trikap
greg64
icobi
lauky
kostilus
blades
smobydick
chob
Twipeep
jujug
davidhebert
SpartanSteal117
link-40
WhiTe-WiiDoW-FR
jay991
Zack
Duma
elmika
yonni
rickou
spyoner971
fabiano
michd
Eazyy
adishats
JEZ69
snakeplisken
DiabloCorps
T0maT0
flouch
yepiyo
Amedinho
mack13
leleup
marus
croftman
bramss
le.doms
philippeb
matuvu
geebee
liroy06
Azu
1bert
croustibat
csercl
kevin69800
barjel
jeanmarce
Fabio
biotoxic937
188 participants
description[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 28 EmptyRe: [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1)
en faite t'installe le recovery.
Tu crée un partition ext sur la carte SD (si tu veux)
Ensuite tu copie le .zip de la ROM sur la SD.
Dans AD Recovery tu fais les 2 wipes (cache partition et data)
Ensuite toujours dans AD Recovery : install zip from sdcard / choose zip from sdcard / et tu choisis la ROM que tu as mis sur la SD.
la ça s'installe et ensuite tu fais reboot now.
Et tu démarre sous Android
(après si tu veux tu peux enlevé le .zip de la ROM de ta carte SD vu qu'elle est installé dans la mémoire interne)
Ok bé tout me semble clair, je m'y met dans 1H smile
Merci beaucoup pour tes explications et ta patience, ça faisait 4 jours que je planchais dessus! smile
De rien Wink
Au pire tu as aussi une super explication dans la partie "Autre information", tuto d'installation par bboypc (spoiler) du lien de la ROM que je t'es passé.
C'est bon, tout c'est bien installé je suis sous android smile
Maintenant quand j'allume mon portable il y a le menu MAGLDR 1.13 qui se lance direct avec le machin gogogo! puis android qui se lance smile
Il y a moyen d'éviter l'apparition du menu MAGLDR à chaque démarrage ou non? smile
Et aussi la ROM DARK (j'ai créé les partitions nécessaires sur ma carte SD) je l'ai mit à la racine de la mciro SD (le dossier .zip en entier (il faut que je l'extract?)) du coup je pense pouvoir la lancer comme tu as dis via le AD recovery sauf que je ne sais pas comment retomber sur le menu pour le choisir..
En lancant le ROM update utility ça relance mon téléphone comme si j'appuyais sur la touche power :/
pour retourner dans MAGLDR, appuies sur power pendant l'allumage du téléphone, tu pourras ensuite aller dans le recovery (8 AD Recovery) puis flasher la rom.
Bonjour j'ai tous suivie a la lettre mais quand j'allume mon HD2 cela s'affiche a mon écran:
Booting Android from NAND
ANDROID LOAD at 11800000
from NAND
yaffs2 part is /boot
load zImage
Load initrd.gz
[k]11808000:237098 [I]12200000:37222
Load done!
GO GO GO!
Mais rien ne se passe, je sais que c'est un bug car il est signalé sur XDA
Quelqu'un pourrait m'éclairer svp [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 28 220270 ?? Car la je suis sans telephone merci
as tu bien installé la version 1.13 de MAGLDR?
Oui j'ai tout les elments comme il faut :/
quelle ROM Radio?
[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 28 880377
Je m excuse d'avance [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 28 493295 mais étant plus nul qu'un débutant et un novice réunit [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 28 686134294
je viens de passer 2 jours à essayer mais je bloque déjà au niveau Task 29
quand je le lance ca me dit plein d'erreur comme quoi il ne trouve pas plusieur fichiers !
je doit être trop con pour réussir alors pensez vous qu'un magasin style "chinois" en région parisienne puisse me le faire ?
Merci d avance :merci:
Looping
[TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 28 803859
Oublie les chinois...
Tu as XP ou Seven/Vista?
Il faut que le tel soit en Bootloader.
Utilise HD2 Tool Kit
HD2 tool kit -----> http://htc-touch-hd.1fr1.net/t46856-outil-hd2-tool-kit-sisi-c-est-la-la-mailleur-place#610368
Merci BIV...Mais je pensais qu'il le trouverait tout seul... Wink
Vu cette phrase, j'ai pensé que cela pourrait être un gain de temps Wink
Merci Ttersu
je suis sous W7 en pc
et mon HD2 etait bien en bootloader ( si c est l ecran tricolore)
et merci a Biv
car il avait raison dans son raisonnement
je vous tiendrais au courant
Encore un grand merci d'avance
Looping
N'oublie pas de lancer le Tool Kit en Admin. Wink
Pas de soucis je suis le seul sur cet ordi
Je ferai une tentative demain et je posterai le resulta
je vais croiser les doigts et les orteils cette nuit lol!!!
il suffit de faire clic droit et executer en tant qu'admin...
Fais gaffe en croisant les doigts de ne pas te tromper pour le clic droit "Exécuter en tant qu'admin" ...
(La précision peut être nécessaire smile)
Mort de Rire
J'ai enfin reussi a mettre cette [TUTO] COMMENT FLASHER UNE ROM NAND ANDROID SUR LE HD2 (archive 1) - Page 28 803587 de rom !!!
Marche impecable mais au niveau de la memoire et t'il possible que toutes les aplis que je télécharge, photo etc... ce mette automatiquement sur la sd??
Quelle ROM?
as-tu fait unne partition EXT sur ta SD?
Non je n'ai pas fait de partition
Et pour la rom je ne sais pas laquelle j'ai mis ^^
Alors, le nom du dossier que tu as DL est le nom de la ROM.
Pour la SD, les photos vont direct dessus...si tu le paramètre ainsi dans l'applie...
Pour les Applies, il te faut une partition EXT3 ou EXT4 (selon la ROM..)
DFT_LEO_MAGLDR113_DAF
C'est le nom de ma rom???
